Edelbrock RPM Heads and Hooker Headers Fit? #1265572
07/11/12 02:22 AM
07/11/12 02:22 AM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
Will this work? Anyone have any experience with this? I've been searching and searching and can't find much. I did find someone on another board who posted some pictures where they had to dimple the headers in a couple places for spark plug access?
I've got the Hooker 1 and 7/8 inch headers, can't remember the part number but I can get it I that helps.
Thanks for any info!
Re: Edelbrock RPM Heads and Hooker Headers Fit? [Re: 67Satty] #1265573
07/11/12 03:00 AM
07/11/12 03:00 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
When I had eddy RPMs my hookers fitted real nice
Re: Edelbrock RPM Heads and Hooker Headers Fit? [Re: 67Satty] #1265574
07/11/12 08:23 AM
07/11/12 08:23 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
You don't mention your combination (B/RB/LA). I went to Performer RPM's 8 years ago on my stroker B engine. To my surprise, my Hooker Headers were tight as far as spark plug clearance. I believe that the #1 cylinder was the biggest problem. The earlier design hookers were designed for heads with straight out spark plug orientation. The RPM's have angled plugs. I had to make a little jig for my press and dimple a few of the tubes. As I mentioned, the #1 cylinder was the biggest problem because the header tube exits the exhaust port at the same angle as the spark plug end. So the spark plug insulator and plug wire tip ran parallel (underneith) with the header tube. That required a bigger dimple to create clearance for the plug wire connector end. I wasn't about to beat my nice polished ceramic coated Hooker header with a ball pean hammer so I made a tube holder out of wood (oak) and a little metal thick wall tube welded to a tube that slid over the tip of my press. I pressed a dimple into the header tube and then test fit and then pressed some more until I had enough clearance to get the plug wire onto the spark plug tip with a decent air gap. I believe that somewhere around 2004, Hooker redesigned their B/RB headers so that they would fit with angled and straight spark plug orientation.
The other issue I ran into was that the exhaust header flange hit the tops of the ARP cylinder head stud kit. I had to trim the nice allen head end of the stud down so it would clear.
I found a picture in my archive ... you can see that the plugs are in the odd numbered cylinder head and the #1 plug wire is attached. I'm pretty sure I took this picture right around the time I was trial fitting the headers to my new Eddy RPM cylinder heads.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Edelbrock RPM Heads and Hooker Headers Fit? [Re: rumblefish72] #1265575
07/11/12 03:48 PM
07/11/12 03:48 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Just curious, are you guys talking about Competition or Super Competition series Hookers? Or both?
Re: Edelbrock RPM Heads and Hooker Headers Fit? [Re: Jwilli500] #1265576
07/11/12 04:46 PM
07/11/12 04:46 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
Friend of mine runs 1 7/8" Hooker headers on his 440 with Edelbrock RPM heads and he had no clearance problems. Thing is, they don't look like the headers in the picture above. No.1 tube runs across the top of the other three tubes on that side.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Edelbrock RPM Heads and Hooker Headers Fit? [Re: Mick70RR] #1265577
07/11/12 05:38 PM
07/11/12 05:38 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Want the straight plugs try Edelbrock e-street cylinder head
http://www.edelbrock.com/automotive_new/mc/cylheads/chrysler/bb_estreet.shtml
Same flow as the RPM but straight plugs
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Edelbrock RPM Heads and Hooker Headers Fit? [Re: Jwilli500] #1265578
07/11/12 05:42 PM
07/11/12 05:42 PM
I was fitting a set of Super Comps ... I believe the part# is 5209. I just looked them up on the Holley Website: http://www.holley.com/5209-1HKR.asp
The picture shows the tubes running the same basic way as the tubes on my year = 2002 headers. My tubes are 2" X 32" and the collector is 3-1/2" diameter. The original post mentioned 3" collectors so we're not talking about the same part#. I seem to remember a footnote on these headers mentioning angled plugs. I looked up part# 5209 and saw footnotes #4 and #200 ... #200 talks about fit issues with B1 heads and angled spark plugs. I thought they did a redesign for angled plugs but I guess not. But ... I also saw another footnote (#205) mentioning Accel shorty plugs. I planned to run NGK plugs ... I'll have to take a look at the shorty plugs ... a short plug would be a big help with my #1 cylinder.
Re: Edelbrock RPM Heads and Hooker Headers Fit? [Re: 67Satty] #1265579
07/11/12 06:27 PM
07/11/12 06:27 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Unless you have them already or are getting them for a great deal, I would go with the TTI's...The fit and quality is better, IMO.
MB
Re: Edelbrock RPM Heads and Hooker Headers Fit? [Re: 67Satty] #1265580
07/11/12 11:09 PM
07/11/12 11:09 PM
Cab_Burge Online work
Cab_Burge  Online Work
Get the part number and list what year car and body style That way someone with a similar car and same header part number may be able to respond halfway intelligently
Re: Edelbrock RPM Heads and Hooker Headers Fit? [Re: 67Satty] #1265581
07/12/12 12:13 AM
07/12/12 12:13 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
5903 1-7/8 Hookers fit after you gently tap two of the tubes. Car is a '67 B-Body with an RB.
Michael
Re: Edelbrock RPM Heads and Hooker Headers Fit? [Re: 67Satty] #1265582
07/15/12 09:07 PM
07/15/12 09:07 PM
San Diego
Redsled Offline
Redsled  Offline
San Diego
I run a set of #5903 Hooker Comps in my 66 Coronet w/a 440 & Eddy RPMS. I dinged the underside of cyl # 2 for 90 deg plug wire clearance,and both sides to get a little room past the torsion bars. They've been on the motor for 10 years w/ no problems. I overdid it a little, it's not as bad as it looks......First time dinging a set of tubes.
Re: Edelbrock RPM Heads and Hooker Headers Fit? [Re: 67Satty] #1265583
07/15/12 09:11 PM
07/15/12 09:11 PM
San Diego
Redsled Offline
Redsled  Offline
San Diego
#2 You can see the 1st contact w/ the torsion bar, and I overdid it a little.
Re: Edelbrock RPM Heads and Hooker Headers Fit? [Re: Redsled] #1265584
07/20/12 10:57 PM
07/20/12 10:57 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
Sorry everyone I've been out of town. The Hooker headers I have are the part number 5903 Hooker Competition headers that are 1 and 7/8" and made to fit both B and E bodies. The car is a 1967 Satellite with a 440 and 727. $600 TTI headers are out of my budget right now.
