Turbo cars?? #1265054
07/10/12 12:25 AM
07/10/12 12:25 AM
Ashville, Manitoba, Canada
superbeeman69 Offline OP
super street
super street
I'm a member on the YB forums too but rather than a tech question here, im looking for pics of a turbo set up in a 68-70 B body. Either twins (T3) or a single 88mm or so turbo. I'd like to hear from whoever might have either set up. As in what went where and why. I'm well versed in turbos now on a tech level per say, but not so much with all the piping. Any help would be greatly appreciated!
1970 FM3 Coronet 440, 1971 FJ6 Dude D100
Re: Turbo cars?? [Re: superbeeman69] #1265055
07/10/12 01:21 AM
07/10/12 01:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you go look at the "Sleeper post" you will see a
62 thats a single, I built most of it for Scott but
if you have any questions you might ask Scott.... it
doesnt run a inner cooler but all the rest of the parts
are there... the plumbing is all pretty simple, its
just a matter of fitting it in
Re: Turbo cars?? [Re: MR_P_BODY] #1265056
07/10/12 04:28 AM
07/10/12 04:28 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
This is probably the best one I have seen to date. Belongs to Bo Peebles
http://www.hyperformanceracing.com/photos/peebles/index.htm
"Any fool can know. The point is to understand"
- A. Einstein
Re: Turbo cars?? [Re: EvilB1Dart] #1265057
07/10/12 09:43 AM
07/10/12 09:43 AM
nc
cold85 Offline
cold85  Offline
nc
My favorite mopar ever
Re: Turbo cars?? [Re: superbeeman69] #1265058
07/10/12 10:21 AM
07/10/12 10:21 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
There is a guy on here w/ a twin turbo 69 Charger he's doing it's BAD A$$. I forget his name...somebody will know. I was talking to a buddy of mine he has one BIG (100mm) on his SB tube Omni. He sadi if he did it again he'd go w/ 2 smaller units as they will spool up faster. For my next build I'm going to try hanging two behind the headlight doors.
Coming soon!!!!
Re: Turbo cars?? [Re: Mr.Yuck] #1265059
07/10/12 07:41 PM
07/10/12 07:41 PM
MO.
4rsfed mopar Offline
MO.
The blue charger is my car. I will b dropping in the new engine in a couple of days.Its a big inch hemi with twins 91mm.
Re: Turbo cars?? [Re: 4rsfed mopar] #1265060
07/10/12 08:41 PM
07/10/12 08:41 PM
super street
super street
Wow! Kudos to you sir! Absoloutly gorgeous charger!
I think I'm looking at twin 67 or 72 mm. I don't want glowing orange headers from big EGTs if the housings are too small. Any thoughts or input? What about brand? I'm used to turbonetics stuff. Kevin at CSU will be making my BT carb. Now headers...guess I'm going to have to make my own, especially with all the turbo piping. Using an MSD 6btm and a2000 fuel pump. Any thoughts on a size for air to air intercooler?
Re: Turbo cars?? [Re: 4rsfed mopar] #1265061
07/10/12 08:57 PM
07/10/12 08:57 PM
New Brunswick, Canada
TrxR Offline
TrxR  Offline
4rsfed mopar: What was the old engine combo and what transmission are you using?
Re: Turbo cars?? [Re: TrxR] #1265062
07/10/12 09:11 PM
07/10/12 09:11 PM
Holly, MI
JackGTX440 Offline
JackGTX440  Offline
Holly, MI
I'd like to know on the trans too. I'd assume th400.
Jack Irons Jr. '67 GTX, turbo 6.1 HEMI
Re: Turbo cars?? [Re: 4rsfed mopar] #1265063
07/10/12 09:25 PM
07/10/12 09:25 PM
metro detroit
turner Offline
turner  Offline
metro detroit
Bo tell these guys the numbers you told me at work on that new motor, I know you will put some smiles on some faces........ that is one of the baddest street cars in Michigan.
Re: Turbo cars?? [Re: turner] #1265064
07/10/12 09:34 PM
07/10/12 09:34 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
That is a pretty awesome looking Charger!
Alan Jones
Re: Turbo cars?? [Re: LA360] #1265065
07/10/12 09:47 PM
07/10/12 09:47 PM
MO.
MO.
Old combo was 500 inch wedge with a glide twin 78mm turbos,with a procharger intercooler I think it was rated for 2000hp
Re: Turbo cars?? [Re: 4rsfed mopar] #1265066
07/10/12 09:55 PM
07/10/12 09:55 PM
Holly, MI
JackGTX440 Offline
JackGTX440  Offline
Holly, MI
did this car see much street time with the old combo? how were the street manners with the glide in a b-body? I was considering a glide in my GTX. Everyone kept telling me it was too heavy and to go with a th400...
Re: Turbo cars?? [Re: JackGTX440] #1265067
07/10/12 10:04 PM
07/10/12 10:04 PM
MO.
MO.
It was fine lots of street miles on it.
Re: Turbo cars?? [Re: 4rsfed mopar] #1265068
07/10/12 10:15 PM
07/10/12 10:15 PM
TrxR Offline
TrxR  Offline
I assume it was an aftermarket block with what Indy heads? What was the compression ratio and did it run on pump fuel?
Re: Turbo cars?? [Re: TrxR] #1265069
07/10/12 10:20 PM
07/10/12 10:20 PM
MO.
MO.
Indy block 8 5 to 1 comp yes pump gas and c 16
Re: Turbo cars?? [Re: 4rsfed mopar] #1265070
07/10/12 10:21 PM
07/10/12 10:21 PM
Holly, MI
JackGTX440 Offline
JackGTX440  Offline
Holly, MI
what low gear ratio were you running?
Re: Turbo cars?? [Re: JackGTX440] #1265071
07/10/12 10:23 PM
07/10/12 10:23 PM
MO.
MO.
3.70
Re: Turbo cars?? [Re: 4rsfed mopar] #1265072
07/11/12 01:06 AM
07/11/12 01:06 AM
super street
super street
While were on the topic of the blue charger, what rear end gears and rear tire size?
Re: Turbo cars?? [Re: 4rsfed mopar] #1265073
07/11/12 07:05 AM
07/11/12 07:05 AM
Holly, MI
JackGTX440 Offline
JackGTX440  Offline
Holly, MI
I meant in the power glide.
