Page 1 of 3 1 2 3
heat riser passage block off methods #1264721
07/09/12 01:59 PM
07/09/12 01:59 PM
Carstairs, Alberta, Canada
dave571 Offline OP
dave571  Offline OP
Interested in what has worked for others.
Application is an iron 383 manifold
I've been contemplating using large quantities of JB weld.
I know they make a gasket that does it, but it'll take too long to get.
Share your story
Re: heat riser passage block off methods [Re: dave571] #1264722
07/09/12 02:02 PM
07/09/12 02:02 PM
USA
b54406barrel Offline
USA
Kind of hate to admit it but, I used the ends off a string bean can the first time. Which was about 45 years ago.
Re: heat riser passage block off methods [Re: dave571] #1264723
07/09/12 06:47 PM
07/09/12 06:47 PM
wadded up ball of aluminum foil
Re: heat riser passage block off methods [Re: RapidRobert] #1264724
07/10/12 09:22 AM
07/10/12 09:22 AM
scratchnfotraction Offline
I have a buddy do this on his 400 just a couple weeks ago, he was tuning it as it had developed a miss... must have been the shreded alum foil that was being spit out the open header.
yes,he has the heads off now doing a VJ on them.
***best way on a BB is to get the felpro HP valley pan with the heat blocked off and use the 4 thin gaskets with it.***
on my SB I have used soup can lids to cut patches out. the MP-block offs are a tad to thick and mine intake bolts kept comeing loose.
I have some thin metal block offs on there now from a radio cover/shell and the 440 has the felpro HP valley pan.
results vary,good luck.
Re: heat riser passage block off methods [Re: dave571] #1264725
07/10/12 09:26 AM
07/10/12 09:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
In a pinch I made little covers from some brass shim stock and have used pieces from an old valley tray , put them in the little recess where the opening is and it worked fine . I don't think run of the mill JB weld will survive in that spot but I have never tried it. .
Re: heat riser passage block off methods [Re: scratchnfotraction] #1264726
07/10/12 09:27 AM
07/10/12 09:27 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
turn it off, turn it on.
Re: heat riser passage block off methods [Re: lewtot184] #1264727
07/10/12 10:23 AM
07/10/12 10:23 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Is that something you made, Lewis? If so, what do you have in mind for connecting to it?
Re: heat riser passage block off methods [Re: Fury Fan] #1264728
07/10/12 10:34 AM
07/10/12 10:34 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Mopar Performance had offered an intake manifold gasket with two thick (.040-.050) shims to block the heat crossover on small blocks.
I never used this kit due the the shims being so thick. What I do is find a large aerosol can and cut my own shims. The ones I have used where about .011 thick. I have done this MANY times and never had a problem.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: heat riser passage block off methods [Re: Fury Fan] #1264729
07/10/12 01:50 PM
07/10/12 01:50 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i made it. i don't connect anything to it. just manually open and close as needed.
Re: heat riser passage block off methods [Re: lewtot184] #1264730
07/10/12 04:45 PM
07/10/12 04:45 PM
now thats thrifty...
Re: heat riser passage block off methods [Re: dave571] #1264731
07/10/12 06:22 PM
07/10/12 06:22 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
Balled up big wads of aluminum foil and stuffed them down in there. Crude and effective, kind of keeping with these old Mopars' spirit.
Re: heat riser passage block off methods [Re: IronWolf] #1264732
07/10/12 08:22 PM
07/10/12 08:22 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Thin aluminum plates epoxied to the heads is what I do if I don't Hard Bloc them shut
Re: heat riser passage block off methods [Re: BulletBob] #1264733
07/10/12 09:31 PM
07/10/12 09:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I usually use JB Weld to close them up. Been running a Performer that way for about 10 years now.
Mix up half a tube each, pour it in one side, tape off the opening, set the intake so that the taped off opening is setting on the workbench, let it harden. Use the remaining JB Weld on the other side once side one is done, remove tape, install.
Don't be the exception.
Re: heat riser passage block off methods [Re: Supercuda] #1264734
07/10/12 09:35 PM
07/10/12 09:35 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
i jammed a ball of aluminum foil in it then topped it off with jb weld.
Re: heat riser passage block off methods [Re: JAMESDART] #1264735
07/12/12 07:19 PM
07/12/12 07:19 PM
dave571 Offline OP
dave571  Offline OP
Some good ideas. thanks guys!
Re: heat riser passage block off methods [Re: IronWolf] #1264736
07/12/12 07:27 PM
07/12/12 07:27 PM
I remember someone on this board post about stuffing it with 100 dollor bills along with that alum foil,so it would pay hiim for the rebuilding of the heads.
ask my buddy that is waiting for his 4oo BB heads back from the machine shop after spitting the alum out the header collectors
results will vary.
Re: heat riser passage block off methods [Re: scratchnfotraction] #1264737
07/12/12 08:45 PM
07/12/12 08:45 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
Watch it!!
Re: heat riser passage block off methods [Re: scratchnfotraction] #1264738
07/13/12 09:03 AM
07/13/12 09:03 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I remember that one too, and I've quoted that in threads like this. The original guy that said it I believe goes by the name 'Paymelater' or something like that, which is funny too.
Re: heat riser passage block off methods [Re: dave571] #1264739
07/13/12 09:10 AM
07/13/12 09:10 AM
Central New York
bfury Offline
bfury  Offline
Central New York
Back in the day, we used to shove balls of aluminum foil into the head and then cover with a thin patch of sheet metal. Then we would wire the crossover valve in the manifold open or drill it out, tap the holes and put bolts in. Always worked fine. With todays gas, this is a must to do since the added heat evaporates the fuel.
No Stock
Re: heat riser passage block off methods *DELETED* [Re: IronWolf] #1264740
07/13/12 09:11 AM
07/13/12 09:11 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Post deleted by tboomer
Page 1 of 3 1 2 3
