Page 1 of 3 1 2 3
New best...The good, the bad, and the ugly. **UPDATE** #1263385
07/07/12 12:13 PM
07/07/12 12:13 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
Was out for the first time of the season last night at Pacific:
The Good:
Car ran a new best and I dipped my toe in the 11-second streetcar pool. 11.92 @ 111+. It hit harder with the new converter and cut over a tenth off my previous best 60' @ 1.65 (previous best 1.78).
As usual at the track, met nice people, and ran into a few friends, and had a great time.
The Bad:
Could just be the heat (over 80 yesterday with heavy air). but it was down on MPH by about 1.5 from previous best. I was suprised with this, because one of the changes I made over the winter was a sealed fresh air system that I thought would be worth a couple of MPH. Maybe I just need to play with jetting (???).
The UGLY:
Had to push the car onto the trailer..... last run resulted in a broken rear end. I just rebuilt this 8-3/4" in the fall, and it had been quiet and acting just fine until the fateful last run. launched and made it about 5 ft before BANG. Some of the guys that pushed me onto the trailer said they thought maybe it was just an axle because it wasnt making any ill sounds as they pushed it (???). I'll get it apart sometime soon and post the carnage.
Re: New best..... The good, the bad, and the ugly. [Re: StealthWedge67] #1263386
07/07/12 12:28 PM
07/07/12 12:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bummer on the bad part... congrats on the 60'...
yes jetting is normal but if the air was bad that
sure didnt help
Re: New best..... The good, the bad, and the ugly. [Re: MR_P_BODY] #1263387
07/07/12 02:49 PM
07/07/12 02:49 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Congrats on the new best and condolences on the broken parts.
Randy
Re: New best..... The good, the bad, and the ugly. [Re: StealthWedge67] #1263388
07/07/12 03:02 PM
07/07/12 03:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
on the new best on the breakage.........what gears and axles are you running?
Re: New best..... The good, the bad, and the ugly. [Re: Thumperdart] #1263389
07/07/12 03:18 PM
07/07/12 03:18 PM
Puyallup, WA
Puyallup, WA
The ring and pinion and differential came from Dr. Diff. I think they're motive gear R&P, & and Eaton S-G unit. Pig is a 742, gears are 3.91's, axles are stock. Car weigh's about 3750.
Re: New best..... The good, the bad, and the ugly. [Re: StealthWedge67] #1263390
07/07/12 03:58 PM
07/07/12 03:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Have you pulled it apart to verify what broke yet? Who set em up?
Re: New best..... The good, the bad, and the ugly. [Re: StealthWedge67] #1263391
07/07/12 04:36 PM
07/07/12 04:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would say your buddies are right on a axle if they
didnt hear any clunking
Re: New best..... The good, the bad, and the ugly. [Re: StealthWedge67] #1263392
07/07/12 05:36 PM
07/07/12 05:36 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
You need to check the trans too....
Nautilus Racing-
Re: New best..... The good, the bad, and the ugly. [Re: Chris2581] #1263393
07/07/12 06:28 PM
07/07/12 06:28 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Most likely an axle, as said if there's no noise when rolling it around. Those axles were probably groaning with pain on each lauch at that weight...LOL!
MAKE SURE you check the sprague in the trans (unless it's a bolt in). Don't ask me how I know...
Don't be discouraged by the lack of gain by adding the fresh air. First thing unless the conditions were exact or you have weather station data you'll have to start from stratch. Also keep in mind that changing the torque converter can change the demands of the fuel system depending on the flash at the hit, shift point recovery and overall slippage. With two major changes since your last run you don't know what each one did/didn't do...all the more reason to start fresh with testing the fuel curve.
Now get that rear apart and let's see what you broke!
Re: New best..... The good, the bad, and the ugly. [Re: StealthWedge67] #1263394
07/07/12 08:36 PM
07/07/12 08:36 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
been there done that. added 6 psi of boost to a 30 years old 3.91 unit and 1st hard pass....booom blew up into about 200 pieces, caps and all. I went with a brand new nodular unit from Randy's.
Coming soon!!!!
Re: New best..... The good, the bad, and the ugly. [Re: StealthWedge67] #1263395
07/07/12 09:17 PM
07/07/12 09:17 PM
NC
440Jim Offline
440Jim  Offline
NC
...axles are stock. Car weigh's about 3750.
At that weight, it is hard on stock 8-3/4 axles. Some factory parts hold up better than others, but on my 3700 lb Cuda running about the same ET (but 1.55 sixty foots) it broke the stock axles the first summer. Now it has Moser's.
Re: New best..... The good, the bad, and the ugly. [Re: 440Jim] #1263396
07/08/12 10:54 PM
07/08/12 10:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Sorry to hear about the breakage and congrats on breaking into the 11's with a new best. Ron
Re: New best..... The good, the bad, and the ugly. [Re: 383man] #1263397
07/09/12 12:17 AM
07/09/12 12:17 AM
Renton Washington
Triple Threat Offline
Renton Washington
Good to see you Friday night, and sorry again about the broken parts. Hopefully it is just an axle and the trans survived as well.
MPH is probably a little down due to the air. It wasn't terrible, but not very good either for around here.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: New best..... The good, the bad, and the ugly. [Re: Triple Threat] #1263398
07/09/12 12:33 AM
07/09/12 12:33 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
Was nice to meet you, sorry I did not have the time to check out your car. Sorry about your rear differential problem...Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: New best..... The good, the bad, and the ugly. [Re: Wicked49670dart] #1263399
07/17/12 01:31 AM
07/17/12 01:31 AM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
did you get a chance to check it out yet?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: New best..... The good, the bad, and the ugly. [Re: Stroker Scamp] #1263400
07/17/12 12:06 PM
07/17/12 12:06 PM
Puyallup, WA
Puyallup, WA
Call me a P-O-S, but would you believe NO?
My daughter is leaving for college in 2 weeks, and we're having a big send-off party. Every extra minute has been taken getting the yards and house ready, as well as spending time with her. The car will wait, She won't..... Time has been spent in order of priority lately.
I'll post as soon as I get the chance. Thanks for checking in.
Re: New best..... The good, the bad, and the ugly. [Re: StealthWedge67] #1263401
07/30/12 01:19 AM
07/30/12 01:19 AM
Puyallup, WA
Puyallup, WA
well, I got the rear end apart today. No such luck with the axles... they were fine. It was the differenial (again). Side gears in the powerlock unit broke just like last year. Looks like I was extremely lucky though, as somehow there are pieces of gear laying in the housing but nothing got into the ring & pinion, so I should be able to re-use my 3.91's (if I choose to go with the 8-3/4 again???... I've got an offer for a Dana on the table as well.)
Re: New best..... The good, the bad, and the ugly. [Re: StealthWedge67] #1263402
07/30/12 01:57 AM
07/30/12 01:57 AM
Renton Washington
Renton Washington
Do it and don't look back, you'll never have to worry again.
-Dustin
Re: New best..... The good, the bad, and the ugly. [Re: Triple Threat] #1263403
07/30/12 02:37 AM
07/30/12 02:37 AM
Puyallup, WA
Puyallup, WA
If it was a B-body Dana, I'd call it a no brainer, but its a Dana 60-2 (smaller axle tubes) out of a Jeep pickup truck. A local moparts member offered it to me for a song, which is great! However, It would need to be narrowed and have new perches mounted, It needs the axles to be redrilled for mopar bolt pattern, and I would also have to shorten my drive line. I can't do any of those things myself, so I'd have to pay to have them done. I know it would be the right direction to go, but I just don't have the $1200 (approx.) it would cost.
I think that if I go with a Detroit Locker style diff in the 8-3/4" instead of the powerlock unit, it should be plenty strong to hold up to my car, and at less than half of what it would cost me to do the Dana. I don't know....
Re: New best..... The good, the bad, and the ugly. [Re: StealthWedge67] #1263404
07/30/12 02:57 AM
07/30/12 02:57 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have had a Detroit Locker in my 63 for almost 4 years and no problems. I dont race alot but I race it a few times a year and its still holding up fine. Course I do plan a Dana in the future when I can afford it. Ron
Page 1 of 3 1 2 3
