New best...The good, the bad, and the ugly. **UPDATE**
#1263385
07/07/12 12:13 PM
07/07/12 12:13 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Was out for the first time of the season last night at Pacific: The Good: Car ran a new best and I dipped my toe in the 11-second streetcar pool. 11.92 @ 111+. It hit harder with the new converter and cut over a tenth off my previous best 60' @ 1.65 (previous best 1.78). As usual at the track, met nice people, and ran into a few friends, and had a great time. The Bad: Could just be the heat (over 80 yesterday with heavy air). but it was down on MPH by about 1.5 from previous best. I was suprised with this, because one of the changes I made over the winter was a sealed fresh air system that I thought would be worth a couple of MPH. Maybe I just need to play with jetting (???). The UGLY: Had to push the car onto the trailer..... last run resulted in a broken rear end. I just rebuilt this 8-3/4" in the fall, and it had been quiet and acting just fine until the fateful last run. launched and made it about 5 ft before BANG. Some of the guys that pushed me onto the trailer said they thought maybe it was just an axle because it wasnt making any ill sounds as they pushed it (???). I'll get it apart sometime soon and post the carnage.
Re: New best..... The good, the bad, and the ugly.
[Re: StealthWedge67]
#1263386
07/07/12 12:28 PM
07/07/12 12:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Bummer on the bad part... congrats on the 60'... yes jetting is normal but if the air was bad that sure didnt help
[Re: Thumperdart]
#1263389
07/07/12 03:18 PM
07/07/12 03:18 PM
StealthWedge67
Puyallup, WA
The ring and pinion and differential came from Dr. Diff. I think they're motive gear R&P, & and Eaton S-G unit. Pig is a 742, gears are 3.91's, axles are stock. Car weigh's about 3750.
#1263391
07/07/12 04:36 PM
07/07/12 04:36 PM
MR_P_BODY
I would say your buddies are right on a axle if they didnt hear any clunking
[Re: Chris2581]
#1263393
07/07/12 06:28 PM
07/07/12 06:28 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Most likely an axle, as said if there's no noise when rolling it around. Those axles were probably groaning with pain on each lauch at that weight...LOL! MAKE SURE you check the sprague in the trans (unless it's a bolt in). Don't ask me how I know... Don't be discouraged by the lack of gain by adding the fresh air. First thing unless the conditions were exact or you have weather station data you'll have to start from stratch. Also keep in mind that changing the torque converter can change the demands of the fuel system depending on the flash at the hit, shift point recovery and overall slippage. With two major changes since your last run you don't know what each one did/didn't do...all the more reason to start fresh with testing the fuel curve. Now get that rear apart and let's see what you broke!
#1263395
07/07/12 09:17 PM
07/07/12 09:17 PM
Posts: 16,931 NC
440Jim
NC
...axles are stock. Car weigh's about 3750.
At that weight, it is hard on stock 8-3/4 axles. Some factory parts hold up better than others, but on my 3700 lb Cuda running about the same ET (but 1.55 sixty foots) it broke the stock axles the first summer. Now it has Moser's.
[Re: 383man]
#1263397
07/09/12 12:17 AM
07/09/12 12:17 AM
Triple Threat
Renton Washington
Good to see you Friday night, and sorry again about the broken parts. Hopefully it is just an axle and the trans survived as well.
MPH is probably a little down due to the air. It wasn't terrible, but not very good either for around here.
[Re: Wicked49670dart]
#1263399
07/17/12 01:31 AM
07/17/12 01:31 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
did you get a chance to check it out yet?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Stroker Scamp]
#1263400
07/17/12 12:06 PM
07/17/12 12:06 PM
StealthWedge67
Puyallup, WA
Call me a P-O-S, but would you believe NO? My daughter is leaving for college in 2 weeks, and we're having a big send-off party. Every extra minute has been taken getting the yards and house ready, as well as spending time with her. The car will wait, She won't..... Time has been spent in order of priority lately. I'll post as soon as I get the chance. Thanks for checking in.
#1263401
07/30/12 01:19 AM
07/30/12 01:19 AM
StealthWedge67
Puyallup, WA
well, I got the rear end apart today. No such luck with the axles... they were fine. It was the differenial (again). Side gears in the powerlock unit broke just like last year. Looks like I was extremely lucky though, as somehow there are pieces of gear laying in the housing but nothing got into the ring & pinion, so I should be able to re-use my 3.91's (if I choose to go with the 8-3/4 again???... I've got an offer for a Dana on the table as well.)
[Re: Triple Threat]
#1263403
07/30/12 02:37 AM
07/30/12 02:37 AM
StealthWedge67
Puyallup, WA
Do it and don't look back, you'll never have to worry again.
If it was a B-body Dana, I'd call it a no brainer, but its a Dana 60-2 (smaller axle tubes) out of a Jeep pickup truck. A local moparts member offered it to me for a song, which is great! However, It would need to be narrowed and have new perches mounted, It needs the axles to be redrilled for mopar bolt pattern, and I would also have to shorten my drive line. I can't do any of those things myself, so I'd have to pay to have them done. I know it would be the right direction to go, but I just don't have the $1200 (approx.) it would cost.
I think that if I go with a Detroit Locker style diff in the 8-3/4" instead of the powerlock unit, it should be plenty strong to hold up to my car, and at less than half of what it would cost me to do the Dana. I don't know....
