M/T 29.5 13.5x15 #1260386
07/01/12 05:14 PM
07/01/12 05:14 PM
OH, USA
GORacing Offline OP
super street
GORacing  Offline OP
super street
OH, USA
Has anyone run these with any success? If you have what pressure did you run? How hot did you get them?
74 Roadrunner 360 cid on alky best 60' 1.442 best ET 10.820 @ 123.23
Re: M/T 29.5 13.5x15 [Re: GORacing] #1260387
07/01/12 09:06 PM
07/01/12 09:06 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I run M/T 29.5/11.5 on mine. Air pressure at 11.75-12.0 lbs. I do a pretty good burn out, but probably more for the driver and the show. Car leaves wheels up every pass and carries the fronts almost to the 60' on a good run. Car is 3200 lbs, modified SS leaf springs only (no cal tracs, adj shocks, no pinion snubber ect.) Stock front 6 cyl torsion bars. Foot brake, Turbo Action "J" converter.
Brian Dunnigan
Re: M/T 29.5 13.5x15 [Re: '72CudaRacer] #1260388
07/01/12 09:55 PM
07/01/12 09:55 PM
OH, USA
GORacing Offline OP
super street
GORacing  Offline OP
super street
OH, USA
Thanks Brian. I really appreciate the response. With Phoenix's on back order I put the Mickeys on. The first run it spun with 13 3/4 psi 1.53 60'. First round with 12.5 psi it dropped to 1.47 with alittle spin. Then with 12 psi it was 1.45. I didn't want to go lower till I talked to someone. Again, thanks for the response.
-Gary
Re: M/T 29.5 13.5x15 [Re: GORacing] #1260389
07/01/12 10:57 PM
07/01/12 10:57 PM
Use your tire gauge ONLY and try letting them down 1/2 lb at a time until you get your best 60 ft. times don't forget that all tire gauges DO NOT read exactly the same I have three different low pressure tire gauges, 2 Moroso, one high dollar C gauge, you guessed it, they do not read the same on the same tire on the same day one after the other. I keep one in the car and use ONLY it on my tires I don't loan it out, EVER I learned that lesson the hard way twice, loaned two different ones out and they both came back reading 5 lbs or more with no pressure in them, NO MASS It seems to me the last set of M/T drag tires like your using (I use the 13.5x30x15 ET Streets and the 315x60x15 ET Street Radials and the M/T 10.5x31x15W drag slicks on my car now) my car liked below 10 lbs on my gauges for the best 60 ft. times
Re: M/T 29.5 13.5x15 [Re: Cab_Burge] #1260390
07/02/12 07:08 PM
07/02/12 07:08 PM
OH, USA
GORacing Offline OP
super street
GORacing  Offline OP
super street
OH, USA
Thanks Cab. I appreciate your input.
Re: M/T 29.5 13.5x15 [Re: GORacing] #1260391
07/02/12 10:39 PM
07/02/12 10:39 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I run the 29.5x11.5 on a ten inch rim. Been 1.28 sixtys and hi fives in the 1/8.
Start at 13psi and find what it likes.
Re: M/T 29.5 13.5x15 [Re: FastmOp] #1260392
07/04/12 10:01 AM
07/04/12 10:01 AM
OH, USA
GORacing Offline OP
super street
GORacing  Offline OP
super street
OH, USA
M/T tech dept called me back, and said not to look for any consistency until I have 4-5 passes on them. He also stated that with my car being as heavy as it is not to go under 12 lbs. He was figuring that the pressure should be between 13-14.5 psi. I guess time will tell. Testing on the 13th. I'll get'em figured out.
Thanks everyone for the input.
- Gary
Re: M/T 29.5 13.5x15 [Re: GORacing] #1260393
07/04/12 11:39 AM
07/04/12 11:39 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Good luck at testing,i am sure you will get a handle on it fast you have been racing that car for a long time.
Re: M/T 29.5 13.5x15 [Re: Clanton] #1260394
07/05/12 07:32 AM
07/05/12 07:32 AM
OH, USA
GORacing Offline OP
super street
GORacing  Offline OP
super street
OH, USA
Yeah I threw myself a curve ball mid-season switching tire brands. I should have done it at the beginning, but the Phoenixs still had plenty of rubber left. The sidewalls on the other couldn't handle a 3rd season
Re: M/T 29.5 13.5x15 [Re: GORacing] #1260395
07/05/12 09:39 AM
07/05/12 09:39 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Gary,are you referring to the slick or the ET street?I ordered a set of e/t streets and the holiday got in the way
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: M/T 29.5 13.5x15 [Re: hemi-itis] #1260396
07/05/12 10:53 AM
07/05/12 10:53 AM
OH, USA
GORacing Offline OP
super street
GORacing  Offline OP
super street
OH, USA
They are the slicks. I very rarely change anything in my setup once the first pass is made, but Phoenix forced me into a change.
Re: M/T 29.5 13.5x15 [Re: GORacing] #1260397
07/05/12 01:58 PM
07/05/12 01:58 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I really like Phoenix tires too. But theses M/Ts are a great tire. I think once you find the sweet spotyou will be happy.
Hemi-its. I think you need a slick
Re: M/T 29.5 13.5x15 [Re: FastmOp] #1260398
07/06/12 06:15 PM
07/06/12 06:15 PM
OH, USA
GORacing Offline OP
super street
GORacing  Offline OP
super street
OH, USA
I have faith that I can get them to work. Hopefully everything gets ironed out next Friday
