Re: M/T 29.5 13.5x15
[Re: '72CudaRacer]
#1260388
07/01/12 09:55 PM
07/01/12 09:55 PM
Posts: 425 OH, USA
GORacing
super street
super street
OH, USA
Thanks Brian. I really appreciate the response. With Phoenix's on back order I put the Mickeys on. The first run it spun with 13 3/4 psi 1.53 60'. First round with 12.5 psi it dropped to 1.47 with alittle spin. Then with 12 psi it was 1.45. I didn't want to go lower till I talked to someone. Again, thanks for the response. -Gary
74 Roadrunner
360 cid on alky
best 60' 1.442
best ET 10.820 @ 123.23
[Re: Cab_Burge]
#1260390
07/02/12 07:08 PM
07/02/12 07:08 PM
Posts: 425 OH, USA
GORacing
super street
super street
OH, USA
Thanks Cab. I appreciate your input.
74 Roadrunner
360 cid on alky
best 60' 1.442
[Re: FastmOp]
#1260392
07/04/12 10:01 AM
07/04/12 10:01 AM
Posts: 425 OH, USA
GORacing
super street
super street
OH, USA
M/T tech dept called me back, and said not to look for any consistency until I have 4-5 passes on them. He also stated that with my car being as heavy as it is not to go under 12 lbs. He was figuring that the pressure should be between 13-14.5 psi. I guess time will tell. Testing on the 13th. I'll get'em figured out. Thanks everyone for the input. - Gary
74 Roadrunner
360 cid on alky
best 60' 1.442
[Re: GORacing]
#1260395
07/05/12 09:39 AM
07/05/12 09:39 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Gary,are you referring to the slick or the ET street?I ordered a set of e/t streets and the holiday got in the ![](/ubbthreads/images/graemlins/tongue.gif) way
