Re: How do you secure your factory seat to meet N.H.R.A
[Re: MAXEDWEDGE]
#1258800
06/28/12 01:41 PM
06/28/12 01:41 PM
Posts: 7,506 Az
Crizila
Az
This is what I did. Made it adjustable to go with the seat rail adjusters. Seat is in the most rear position.
Fastest 300
[Re: MAXEDWEDGE]
#1258802
06/28/12 02:16 PM
06/28/12 02:16 PM
Posts: 505 Northampton Pa
65 NSS 500
Northampton Pa
What point is that required is it 11.99 or 10.99. Just curios,
1965 Coronet 500
340 40+ Passon 4sp
12.90 2.6 60' street tires
[Re: lowflyingdart]
#1258804
06/28/12 03:11 PM
06/28/12 03:11 PM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
How do you secure a true factory seat, a bench or a bucket?
Plynouth VIP '67 TT IC EFI
[Re: dvw]
#1258807
06/28/12 10:46 PM
06/28/12 10:46 PM
Posts: 9,849 MI, usa
dvw
MI, usa
[Re: MAXEDWEDGE]
#1258810
06/29/12 02:15 PM
06/29/12 02:15 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
Not stock seats but I went with Kirkeys in my Challenger. Just showing some ideas as towhat we did for mounts. 1st pic.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1258812
06/29/12 02:18 PM
06/29/12 02:18 PM
6PKRTSE
Motor City
2ND pic was the driver side. This is the passenger side mount to the cage.
[Re: 6PKRTSE]
#1258813
06/29/12 02:19 PM
06/29/12 02:19 PM
6PKRTSE
Motor City
All painted & ready to go.
[Re: jyrki]
#1258814
06/29/12 06:29 PM
06/29/12 06:29 PM
Posts: 1,062 Amherst,NY
challengermike
Amherst,NY
A factory seat doesnt need to be hooked to the cage. Only aftermerket or a non factory seat.
[Re: challengermike]
#1258815
06/29/12 07:40 PM
06/29/12 07:40 PM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
Been running this set up in NSS as fast as low 10's and it passes tech everywhere I've been.
[Re: actionange]
#1258817
07/04/12 10:06 AM
07/04/12 10:06 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Ok here is my two cents... for what it's worth, I am a seating engineer so I feel like my opinion is probably worth something...
No offense, but "passes" and "safe" are two different things. The main reason the rule is there is because of any impacts that could happen from the rear (or rear angle) the roll bar needs to support the seat.
Even modern seats with high strength steel back frames, and high strength dual recliner mechanisms aren't very good at moderate speed rear impacts.
Our old junk (or even the new race seats) certainly won't do it either.
Remember the belts can take all of the load in a front crash. The seat has to take all of the load in any rear crash.
Check out this old video. FMVSS 301 is a fuel tank integrity test, but watch the seats/occupants about 5 seconds in. Obviously the seat is doing nearly NOTHING in the crash. And this is only at 30mph!!
http://www.youtube.com/watch?v=sxr_IwQkGv0
The other thing is that there is significant rebound after a frontal crash that the seat need to take too. Even an offset frontal crash (with side load) does bad things to these old seats... Look at these old 60's crash video's...you can see why you want the seat tied to the bar, or at least make sure the bar is below the top of the back to keep it from folding over. You can see in some of these clips that the seat actually has a bar welded behind it (Watch the rear impact at 1:52). The seat stays upright in a rear crash, and keeps the occupants safe. A perfect example why the bar needs to be below the top of the seat back.
http://www.youtube.com/watch?v=siT-SIfOnQw&feature=related
Imagine spinning your super stocker around, or getting nailed by another fast car if you/he crossed the centerline? That cross bar would be right through your back. The bar should be below the top of the seat back to make sure it won't collapse completely, that's why they want it tied. Connecting it also keeps the seat from rocking in a side impact too.
