Re: Fan and Fan Clutch for 70 Charger 440?
[Re: AlexP]
#1258383
06/28/12 01:11 AM
06/28/12 01:11 AM
Posts: 202 Texas
ef8Cuda340
Texas
Non A/C 18-spline Dana 60 Car...What package does that make it?
Thanks Alex,
Yes it is a 4spd, 440, Ca emmission, Trak Pak car without A/C.
[Re: moparfan53]
#1258384
06/28/12 01:13 AM
06/28/12 01:13 AM
Posts: 202 Texas
ef8Cuda340
Texas
If you want to go with a clutch fan setup, Mopar Performance has one. Part# is P4120758. It should be available from your local dealer as well as online suppliers. Here is link to one from Summit.
http://www.summitracing.com/parts/DCC-4120758/
If this is the same one advertised by Mancini, they told me today that it is not for this application, but for 73 or later B-bodies.
[Re: ef8Cuda340]
#1258386
06/28/12 02:39 AM
06/28/12 02:39 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
WOW! 1970 b-body (probably the same for '70 e-body, but I didn't check ) 440 4-spd: ***** 4bbl & 6bbl w/3.54s (A33) = 2998956 26" radiator + 2863216 7-bade 18-1/2" dia. fan + 2806070 torque drive clutch fan + 2998326 fan shroud (the big $$ same as max cooling/HEMI parts) ***** 4bbl & 6bbl w/4.10s (A34) = 2998956 26" radiator + 2863216 7-bade 18-1/2" dia. fan + 2806070 torque drive clutch fan + 2998326 fan shroud (the big $$ same as max cooling/HEMI parts)440 auto: ----- 4bbl w/3.23s & A/C = 2998961 26" radiator + 2863216 7-bade 18-1/2" dia. fan + 2658456 thermal clutch fan + 2998326 fan shroud ***** 4bbl & 6bbl w/3.23s & non-A/C = 2998960 22" radiator + 2863224 7-bade 18" dia. fan + 1851959 1.06" spacer + 2998328 fan shroud ----- 4bbl w/3.55s & A/C (A36) = ?? ***** 4bbl & 6bbl w/3.55s & non-A/C (A36) = 2998956 26" radiator + 2863216 7-bade 18-1/2" dia. fan + 2806070 torque drive clutch fan + 2998326 fan shroud (the big $$ same as max cooling/HEMI parts)***** 4bbl & 6bbl w/4.10s (A32) = 2998956 26" radiator + 2863216 7-bade 18-1/2" dia. fan + 2806070 torque drive clutch fan + 2998326 fan shroud (the big $$ same as max cooling/HEMI parts) Some Superbirds are an exception to the above numbers, during production of the Superbirds they changed from the 216/070 to fixed fans on some engine/trans combos to aid airflow/cooling due to the small grill opening.
[Re: 451Mopar]
#1258388
06/28/12 03:42 AM
06/28/12 03:42 AM
6bblgt
Las Vegas, NV
The Mopar Performance 4120756 kit consists of: 4140063 5-blade 18" dia. fan 4095704 thermal fan clutch the 4095704 fan clutch is 3-3/16" tall VS. 3462112 ('71 version of the "070") fan clutch is 3" tall the 4140063 5-blade 18" dia. fan VS. 2863216 7-blade 18-1/2" dia. fan The '70 b-body is tight in front of the water pump, I'm not sure if that 3/16" will hit the radiator?
[Re: 268RTs4ME]
#1258389
06/28/12 03:50 AM
06/28/12 03:50 AM
6bblgt
Las Vegas, NV
here is what you need pt 2863216 fits 68 thru 72 bce body v8 with h51 181/2 in. fan 2 1/4 inch spacer
That's the correct number fan, but a 2-1/4" spacer would put it thru the radiator.
The 2-1/4" reference in GG's "white book" is for PITCH, basically the twist or depth of the fan blades.
