Fan and Fan Clutch for 70 Charger 440? #1258377
06/27/12 06:06 PM
06/27/12 06:06 PM
Texas
E
ef8Cuda340 Offline OP
E
Texas
I am looking for a fan and fan clutch for my 70 Charger R/T 440. Can someone help me with a part number or source? It can be a reproduction or aftemarket supplier.
thanks!
Re: Fan and Fan Clutch for 70 Charger 440? [Re: ef8Cuda340] #1258378
06/27/12 06:08 PM
06/27/12 06:08 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
A/C? Axle package? Broadcast sheet? 22" vs. 26" Are you looking for the factory "stock" set-up or something that works?
Re: Fan and Fan Clutch for 70 Charger 440? [Re: 6bblgt] #1258379
06/27/12 11:14 PM
06/27/12 11:14 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Non A/C 18-spline Dana 60 Car...What package does that make it?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Fan and Fan Clutch for 70 Charger 440? [Re: AlexP] #1258380
06/27/12 11:29 PM
06/27/12 11:29 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
A 70 Charger 440 4 speed would not have a fan clutch. This set-up uses a fixed 7 blade fan (2863224) with a spacer.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Fan and Fan Clutch for 70 Charger 440? [Re: ef8Cuda340] #1258381
06/27/12 11:42 PM
06/27/12 11:42 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
If you want to go with a clutch fan setup, Mopar Performance has one. Part# is P4120758. It should be available from your local dealer as well as online suppliers. Here is link to one from Summit.
http://www.summitracing.com/parts/DCC-4120758/
Re: Fan and Fan Clutch for 70 Charger 440? [Re: 70gtx440dana] #1258382
06/28/12 12:03 AM
06/28/12 12:03 AM
california
Mr D21 Offline
Mr D21  Offline
california
are you sure it doesnt take an 070 fan clutch ?
Re: Fan and Fan Clutch for 70 Charger 440? [Re: AlexP] #1258383
06/28/12 01:11 AM
06/28/12 01:11 AM
Texas
E
E
Texas
Thanks Alex,
Yes it is a 4spd, 440, Ca emmission, Trak Pak car without A/C.
Re: Fan and Fan Clutch for 70 Charger 440? [Re: moparfan53] #1258384
06/28/12 01:13 AM
06/28/12 01:13 AM
Texas
E
E
Texas
If this is the same one advertised by Mancini, they told me today that it is not for this application, but for 73 or later B-bodies.
Re: Fan and Fan Clutch for 70 Charger 440? [Re: ef8Cuda340] #1258385
06/28/12 02:06 AM
06/28/12 02:06 AM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
here is what you need pt 2863216 fits 68 thru 72 bce body v8 with h51 181/2 in. fan 2 1/4 inch spacer
Re: Fan and Fan Clutch for 70 Charger 440? [Re: ef8Cuda340] #1258386
06/28/12 02:39 AM
06/28/12 02:39 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
WOW!
1970 b-body (probably the same for '70 e-body, but I didn't check )
440 4-spd:
***** 4bbl & 6bbl w/3.54s (A33) =
2998956 26" radiator + 2863216 7-bade 18-1/2" dia. fan + 2806070 torque drive clutch fan + 2998326 fan shroud (the big $$ same as max cooling/HEMI parts)
***** 4bbl & 6bbl w/4.10s (A34) =
440 auto:
----- 4bbl w/3.23s & A/C =
2998961 26" radiator + 2863216 7-bade 18-1/2" dia. fan + 2658456 thermal clutch fan + 2998326 fan shroud
***** 4bbl & 6bbl w/3.23s & non-A/C = 2998960 22" radiator + 2863224 7-bade 18" dia. fan + 1851959 1.06" spacer + 2998328 fan shroud
----- 4bbl w/3.55s & A/C (A36) =
***** 4bbl & 6bbl w/3.55s & non-A/C (A36) =
***** 4bbl & 6bbl w/4.10s (A32) =
Some Superbirds are an exception to the above numbers, during production of the Superbirds they changed from the 216/070 to fixed fans on some engine/trans combos to aid airflow/cooling due to the small grill opening.
Re: Fan and Fan Clutch for 70 Charger 440? [Re: ef8Cuda340] #1258387
06/28/12 03:23 AM
06/28/12 03:23 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I put the Mopar performance viscous clutch fan package on the '69 Coronet. The clutch on this has a thermostat control (my old Mopar Performance one did not have the thermostatically controlled clutch?)
Re: Fan and Fan Clutch for 70 Charger 440? [Re: 451Mopar] #1258388
06/28/12 03:42 AM
06/28/12 03:42 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The Mopar Performance 4120756 kit consists of:
4140063 5-blade 18" dia. fan
4095704 thermal fan clutch
the 4095704 fan clutch is 3-3/16" tall VS. 3462112 ('71 version of the "070") fan clutch is 3" tall
the 4140063 5-blade 18" dia. fan VS. 2863216 7-blade 18-1/2" dia. fan
The '70 b-body is tight in front of the water pump, I'm not sure if that 3/16" will hit the radiator?
Re: Fan and Fan Clutch for 70 Charger 440? [Re: 268RTs4ME] #1258389
06/28/12 03:50 AM
06/28/12 03:50 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
That's the correct number fan, but a 2-1/4" spacer would put it thru the radiator.
The 2-1/4" reference in GG's "white book" is for PITCH, basically the twist or depth of the fan blades.
Re: Fan and Fan Clutch for 70 Charger 440? [Re: 6bblgt] #1258390
06/28/12 11:19 AM
06/28/12 11:19 AM
Lansing, MI
Lansing, MI
WOW!
440 4-spd:
440 auto:
I would like some more 70 B body 440 4 speed owners to chime in on this topic. My 70 GTX 440 4 speed with A33 axle package does not have the torque drive fan listed on the build sheet. It has N51 maximum cooling noted but does not have N65 Torque drive fan on the sheet. I am under the impression that all 70 440 4 speed cars came with a fixed cooling fan versus the fan clutch. I look forward to hearing more on this topic.
Re: Fan and Fan Clutch for 70 Charger 440? [Re: 70gtx440dana] #1258391
06/28/12 12:29 PM
06/28/12 12:29 PM
Lansing, MI
Lansing, MI
WOW!
440 4-spd:
440 auto:
I stand corrected ......216 fan and 070 clutch it is. Here is a snap shot of the codes on my 70 GTX 440 4 speed with A33 axle:
Re: Fan and Fan Clutch for 70 Charger 440? [Re: 70gtx440dana] #1258392
06/28/12 01:24 PM
06/28/12 01:24 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Every 1970 U-code 4-spd B&E-body I have owned came with the 070 clutch.
Re: Fan and Fan Clutch for 70 Charger 440? [Re: 70440+6bbl] #1258393
06/29/12 10:34 AM
06/29/12 10:34 AM
Texas
E
E
Texas
Now that I have the right numbers, where do i get a reproduction or aftermarket one that will work. I have a used one (PN 2863216 7-blade), but is pitted and bent and i am afraid to get one from ebay that isn't like mine but with a fresh coat of paint).
Thanks for the great information.
Re: Fan and Fan Clutch for 70 Charger 440? [Re: ef8Cuda340] #1258394
06/29/12 10:44 AM
06/29/12 10:44 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
That is the first I have heard of the 73 or later thing. Over the past few years I have used it myself as well as seen it used on several big block 68-70 B bodies.
Here is the description from the Mopar Performance catalog.
EDIT: I posted this before I saw your post above. If you are looking for the original style/size fan then this kit is not what you want.
EDIT (again): 6bblgt may be right about a clearance problem on a 70. I just noticed that the MP fan blade has a larger pitch than the original as well as the longer clutch unit.
Re: Fan and Fan Clutch for 70 Charger 440? [Re: moparfan53] #1258395
06/29/12 01:21 PM
06/29/12 01:21 PM
Texas
E
E
Texas
It doesn't have to be an origanal one, just has to fit and work like an orginal one. I am open to any suggestions, other vendors besides Hayden, and except electric fans.
While on the subject, any thoughts on using a flex fan?
