High RPM at crusing speed!!!!! #125792
09/24/08 06:27 PM
09/24/08 06:27 PM
Northeast Ohio
B9ChargerSE440 Offline OP
Northeast Ohio
I need help!! i just got my car on the road and i have a 1972 charger with a 727 trans. with a high stall converter and cheetah manual valve body. and going down the road at 45 mph its running around 2000 or 2200 rpms. and its in third gear for sure! HELP!!
Re: High RPM at crusing speed!!!!! [Re: B9ChargerSE440] #125793
09/24/08 06:51 PM
09/24/08 06:51 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
And your issue is?
Assuming your tire diameter is 26-27" and you have a 3.55-3.91 rear gear ratio your rpms are right where they should be.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: High RPM at crusing speed!!!!! [Re: B9ChargerSE440] #125794
09/24/08 06:54 PM
09/24/08 06:54 PM
Northeast Ohio
Northeast Ohio
I have 31" tires with 3.23 gears.
Re: High RPM at crusing speed!!!!! [Re: B9ChargerSE440] #125795
09/24/08 07:03 PM
09/24/08 07:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
With that combo you should be doing 60 mph at 2100 rpm's and 45 mph should be around 1580 rpm's.
Either your speedo drive pinion is incorrect (should be a 27 tooth) or your speedo or tach is incorrect.
Also, high stall converters and low numeric ratio rear ends often don't play well together, you might be experiencing some converter slip or a combination of all of the above.
Re: High RPM at crusing speed!!!!! [Re: John_Kunkel] #125796
09/24/08 07:28 PM
09/24/08 07:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
This might help. Use 90% as convertor efficency. http://vexer.com/68rt/speed.html
Re: High RPM at crusing speed!!!!! [Re: stumpy] #125797
09/24/08 07:43 PM
09/24/08 07:43 PM
Northeast Ohio
Northeast Ohio
Would it be possible that i need a smaller stall tourque converter??? right now i have a 2800 to 3200 converter i think. and my cam is a .501
Re: High RPM at crusing speed!!!!! [Re: B9ChargerSE440] #125798
09/24/08 07:57 PM
09/24/08 07:57 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
convertor slippage i bet. is that a 292 comp magnum cam in that? if so, any less convertor than you have now will probably make the car sluggish. my own car with 440 and 292 magnum picked up 3 tenths with a switch from a 2500 stall 11in. to a 3800 10 in. also have a 3.23 gear. 28 inch tire tho. you sure have a tall tire in that thing. might be time to put a lower gear in it.
Re: High RPM at crusing speed!!!!! [Re: forphorty] #125799
09/24/08 09:04 PM
09/24/08 09:04 PM
Northeast Ohio
Northeast Ohio
Yea that was my mistake its a 27" tire i was thinking of my brothers tires that he has!! But yes it is a 292 duration comp magnum cam!! thanks
Re: High RPM at crusing speed!!!!! [Re: B9ChargerSE440] #125800
09/25/08 07:24 AM
09/25/08 07:24 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
Well with 3.23 gears and a 27" tall tire at 45 mph you should be turning 1860 rpm. Now a 27" tire is not a stock diameter for the car so unless you have swapped the drive gear inside the tranny as others have mentioned you are actually going faster than the speedo is indicating which easily could make up the couple of hundred rpm.
Re: High RPM at crusing speed!!!!! [Re: dgc333] #125801
09/25/08 05:43 PM
09/25/08 05:43 PM
Northeast Ohio
Northeast Ohio
Ok thanks!!
