Re: High RPM at crusing speed!!!!!
[Re: B9ChargerSE440]
#125795
09/24/08 07:03 PM
09/24/08 07:03 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
With that combo you should be doing 60 mph at 2100 rpm's and 45 mph should be around 1580 rpm's.
Either your speedo drive pinion is incorrect (should be a 27 tooth) or your speedo or tach is incorrect.
Also, high stall converters and low numeric ratio rear ends often don't play well together, you might be experiencing some converter slip or a combination of all of the above.
