Page 2 of 4 1 2 3 4
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: ScottSmith_Harms] #1255399
06/23/12 12:20 PM
06/23/12 12:20 PM
MA
steve70 Offline
steve70  Offline
MA
I machine a lot of ABS at work and sometimes that requires glueing multiple pieces to get the thickness I need because they don't make the raw stock thicker than 4 inches. The best ABS cement I've found is made by Marsh Laboratories in Pittsburgh PA 412-271-3060. It's really inexpensive and is sold in 1 pint cans. Their stuff is a commercial version of Scott's mix, it's just ABS resin and Methylethyl Ketone.
1970 Challenger T/A 4 speed
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: Big Bad Bee] #1255400
06/23/12 05:01 PM
06/23/12 05:01 PM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
Ice, please do!
Sinitro, You need a road trip to San Berdoo!
Noted..
We go to Vegas frequently and purchase the real stuff of acetone & lacquer thinner there..
Yup..
LA County is banning alot of stuff...
Even my 2-cycle weed wacker is history...
Next..
Maybe I will need to install a Prius driveline in the RoadRunner..
Just my $0.02...
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: DARTH V8Я] #1255401
06/30/12 03:18 PM
06/30/12 03:18 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
Ice, please do!
I should have taken more pics.. but its on a Chevy Vega lol. Anyways I was frustrated with trying to make plastic 'shelves' for grills that I have that were broken.. a real PITA to shape, bond, etc. I'm into make model RC WWII aircraft bigtime, and familular with balsa wood. When finished properly, it harder the thermo/abs plastic, and the balsa has the added bonus of easly shaped to conform to whatever I need.
Thats what I did. Shaped fit a piece of balsa wood, then covered with resine ( that kind one uses with fiberglass mat). I then used a sponge brush to spread out the resine. Its almost self leveling, after it dries theres very minimal sanding to do, and one ends up with a very strong repair that after painted, looks 100% factory.
Pic below dosn't do it justice, but there it is in a nutshell so to speak.
So theres my little contribution to the MoPar community
Ice, thanks for posting. That's a great idea/solution. I have a third grill that I could probably restore using that technique. Balsa really is great to work with and it makes total sense to use it this way.
I’m listening.
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: Big Bad Bee] #1255402
06/30/12 04:38 PM
06/30/12 04:38 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
I have a question
i have a 70 cuda grill still mounted in the header panel
i hit something and bent the heck out of the header panel and distorted the grill and put a few cracks in it
if i unbolt it from the header pannel will the grill return its shape or is it junk????
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: toplescuda] #1255403
06/30/12 05:39 PM
06/30/12 05:39 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
unbolt it....Quicker the better! A heat gun used VERY carefully will sometimes help unwarp them but it's DICEY, especially if you are a rookie with a heat gun. Try letting it sit out in the sun for several days first, it may relax and go back into shape.
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: ScottSmith_Harms] #1255404
06/30/12 05:47 PM
06/30/12 05:47 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Grill has been in this shape for bout 5 years
1971 charger
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: toplescuda] #1255405
06/30/12 10:13 PM
06/30/12 10:13 PM
Spokane Valley, WA
Spokane Valley, WA
I bought a 70 cuda in the same condition. Who knows how long the header was bent. Pushed back about 1.5 inches. I pulled it apart and it did relax.
I’m listening.
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: Big Bad Bee] #1255406
07/01/12 12:57 PM
07/01/12 12:57 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
WOW!
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: Sinitro] #1255407
07/01/12 03:24 PM
07/01/12 03:24 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Awesome.. Great details..
Unfortunately we can't purchase acetone in LA County..
Just my $0.02...
Try San Bernardino Co
NS1AAR
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: Big Bad Bee] #1255408
07/23/12 11:40 AM
07/23/12 11:40 AM
Cambridge, Ontario, Canada
CUDAJAS Offline
CUDAJAS  Offline
cool stuff...what other parts will this work on (or what else is madeof ABS Plastic)???
I have a cracked E-body door panel that I would like to try this on.
Jason
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: CUDAJAS] #1255409
09/29/12 12:49 PM
09/29/12 12:49 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
E-body door panels are made of Polyethylene/Polypropylene blend, the suggested repair process described on this thread (or any other glues for that matter) will not work on any Poly based materials. The only repair means for those types of plastics is heat welding, and the results of that usually leaves scars bigger than the initial problem.
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: ScottSmith_Harms] #1255410
09/29/12 01:57 PM
09/29/12 01:57 PM
MA
steve70 Offline
steve70  Offline
MA
I machine and fabricate a lot of different plastics at work and have had good luck with an adhesive that will work with Polyethylene and Polypropylene. It's called Plexus and can be purchased here http://www.itwplexus.com/. They have a great technical staff on hand if you have any questions.
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: steve70] #1255411
09/29/12 03:34 PM
09/29/12 03:34 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Cool, that must be some new stuff, I've never heard of it. Do you know what it's composed of or how it reacts to the material to form a bond?
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: ScottSmith_Harms] #1255412
09/29/12 03:59 PM
09/29/12 03:59 PM
MA
steve70 Offline
steve70  Offline
MA
Scott,
I work for an OE autmotive supplier and was machining a prototype bass box (about 4 years ago) out of solid Polypropylene instead of the usual ABS and was looking for a way to bond the two halves. I called Plexus and they recommended their Methacrylate adhesive. I had my doubts but it really did the job and I have used it many times since then. The glue joint isn't pretty and would only be usefull on an area that is not visible because it really doesn't "melt" into the material the way MEK would. I don't really know how it works but it contains Methylmethacrylate and Methacrylate Acid.
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: steve70] #1255413
09/29/12 04:06 PM
09/29/12 04:06 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, thank you, the Methylmethacrylate and Methacrylate Acid pretty much explains it, that's some nasty stuff! But I can see how it would get a chemical bond while basically nothing else will, gluing to PE/PP is generally like trying to glue a couple candles together .
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: ScottSmith_Harms] #1255414
09/29/12 04:15 PM
09/29/12 04:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Been working all week repairing 1968-69 Charger gilles using the acetone and old grille pieces as a paste method,, it works perfect
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: gtx6970] #1255415
10/04/12 08:24 AM
10/04/12 08:24 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Yeah, did my 71 Challenger grill a month back, had plenty of small holes drilled in it from previous life (why??!!) and this worked a treat. Been waiting to do this since Scott first mentioned it years ago....
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: Gavin] #1255416
10/04/12 08:46 AM
10/04/12 08:46 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
That's the easy part Lindy, wait until you go to paint it, then the fun begins. I've been using this process for 20 years.
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: Big Bad Bee] #1255417
10/04/12 04:20 PM
10/04/12 04:20 PM
Fort Lauderdale
Dave440 Offline
Dave440  Offline
Fort Lauderdale
Hmmmm..... the timing cover on my Mitsu eclipse is cracked and i bought a few plastic repair products BUT haven't made an attempt yet.
After reading this...I'm wondering if one of the alternative methods might work better to actually fuse the plastic back together as it originally was. My eclipse has the same 2.0 engine as a DOHC avenger or Talon. Anyone know what the cover is made of and what will work best to repair it? I'm GUESSING its made of....polyethylene???
Re: Grill Repair. GREAT SCOTT (Smith)! IT REALLY WORKS!!! [Re: Dave440] #1255418
10/04/12 06:49 PM
10/04/12 06:49 PM
MA
steve70 Offline
steve70  Offline
MA
A lot of plastics parts are marked to show what type of plastic it is so look to see if there a symbol on there. If you have access to some MEK (methyl ethyl ketone) or methylene chloride you can rub some on the plastic with a rag. If the rag melts the plastic then you can use that solvent to repair the part. if it doesn't melt the part than it's probably polypropylene or polyethylene. If it's any type of poly you will need an adhesive called Plexus to make the repair. http://www.itwplexus.com/
For abs repairs I'd recommend the ABS cement from Marsh Laboratories in Pittsburg Pa 412-271-3060. It's really inexpensive and is sold in 1 pint cans.
Page 2 of 4 1 2 3 4
