fuel tank filler seal torn #1250365
06/13/12 09:42 AM
06/13/12 09:42 AM
Ohio
P
pengwin Offline OP
pengwin  Offline OP
P
Ohio
When I dropped the tank on my 95 Dakota last weekend to change the fuel pump, I noticed the seal around the filler neck was cracked and torn. Could this cause the truck to run lean?
Re: fuel tank filler seal torn [Re: pengwin] #1250366
06/13/12 10:22 AM
06/13/12 10:22 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Nope. Air fuel ratio doesn't happen in the gastank as long as the pump is working.
Re: fuel tank filler seal torn [Re: radar] #1250367
06/13/12 10:57 AM
06/13/12 10:57 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: fuel tank filler seal torn [Re: 340SHORTY] #1250368
06/13/12 11:36 AM
06/13/12 11:36 AM
Ohio
P
pengwin Offline OP
pengwin  Offline OP
P
Ohio
Thanks. That'll go on the list of things to do, but I won't worry that it has to be done yesterday.
