Were 69 cast blocks used in 70 production vehicles? #1249373
06/11/12 08:01 PM
06/11/12 08:01 PM
mississauga, ontario, canada
P
patbee383 Offline OP
P
I have seen some 69 blocks advertised as 70 whats the deal? I found a engine with casting date 10 14 69 pad reads f 383 10 22 HP Can anyone shed some light on this as i am looking for a 70 block.
1970 Dodge Superbee 2008 Dodge Ram 2500 HEAVY DUTY 2011 Dodge Caravan 2002 Honda Accord?
Re: Were 69 cast blocks used in 70 production vehicles? [Re: patbee383] #1249374
06/11/12 08:20 PM
06/11/12 08:20 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
That block was cast in October of 69 and the car it went into was a 1970 model year car.
Engines for the next model year were cast as early as July of the year before (July 1969 casting for a 1970 car). The latest engine I've ever owned was cast in June of its model year.
The letter on the ID pad (in this case F) determines what model year the engine was slated for.
Re: Were 69 cast blocks used in 70 production vehicles? [Re: GTX MATT] #1249375
06/11/12 09:29 PM
06/11/12 09:29 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
F is the series (model year) 1970.
The 1970 model year ran from August 1, 1969 through July 31, 1970.
If you know the VIN on the block one of us may be able to narrow down what type of car it came from for you.
Re: Were 69 cast blocks used in 70 production vehicles? [Re: Alaskan_TA] #1249376
06/11/12 11:03 PM
06/11/12 11:03 PM
P
P
The VIN is OB154691
Re: Were 69 cast blocks used in 70 production vehicles? [Re: patbee383] #1249377
06/11/12 11:28 PM
06/11/12 11:28 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It is from a 1970 Challenger, but I have not heard of the matching car.
Re: Were 69 cast blocks used in 70 production vehicles? [Re: patbee383] #1249378
06/12/12 12:21 AM
06/12/12 12:21 AM
MN
mnguy55 Offline
mnguy55  Offline
MN
My Feb. 1970 production 1970 Charger has a casting date of 10/31/69 on the numbers matching block.
Re: Were 69 cast blocks used in 70 production vehicles? [Re: mnguy55] #1249379
06/12/12 07:19 AM
06/12/12 07:19 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Once a batch of blocks were cast, they were used until they were gone. It didn't matter what year vehicle or type of vehicle they went into. Could have been a pickup, car, boat, or something else. Each was built and stamped at assembly for the particular year it ended up in. When the partial VIN stamping started, the particular car also.
Re: Were 69 cast blocks used in 70 production vehicles? [Re: mnguy55] #1249380
06/12/12 08:25 AM
06/12/12 08:25 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
HA! i also have a 440 block with that casting date. HALLOWEEN!
Re: Were 69 cast blocks used in 70 production vehicles? [Re: patbee383] #1249381
11/20/14 03:37 PM
11/20/14 03:37 PM
ONTARIO, CANADA
McMOPAR*426* Offline
ONTARIO, CANADA
I found the matching car, does anyone know where this 0B154691 383 engine went too?
Re: Were 69 cast blocks used in 70 production vehicles? [Re: McMOPAR*426*] #1249382
11/20/14 03:41 PM
11/20/14 03:41 PM
I was told back in the early 1970s that Mopar would cast a bunch of blocks and store them outside for a period of time to let them age before machining them
Re: Were 69 cast blocks used in 70 production vehicles? [Re: Cab_Burge] #1249383
11/20/14 03:49 PM
11/20/14 03:49 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Hard to build a 70 model year car in august 1969 without an engine... Unless you could cast them on Jan 1 and time machine them back a few months...
Cars for the 1970 model year started appearing in delaer lots around Sept 1 1969.
Re: Were 69 cast blocks used in 70 production vehicles? [Re: McMOPAR*426*] #1249384
11/20/14 04:24 PM
11/20/14 04:24 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
You are both in Ontario Canads. You both joined on November 20th...be it 3 tears apart. Too many coincidences there for it to be too far away. I'd try contacting PatBee383. I know I don't have it...
...FAFO...
Re: Were 69 cast blocks used in 70 production vehicles? [Re: skicker] #1249385
11/20/14 06:04 PM
11/20/14 06:04 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
CabBarge,
That is true but it was primarily done with Hemi blocks.
Re: Were 69 cast blocks used in 70 production vehicles? [Re: ScottSmith_Harms] #1249386
11/20/14 06:11 PM
11/20/14 06:11 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
What's up with this one? cast 9/13/69
Re: Were 69 cast blocks used in 70 production vehicles? [Re: 62maxwgn] #1249387
11/20/14 06:23 PM
11/20/14 06:23 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
What's the EAD on the top pad?
Re: Were 69 cast blocks used in 70 production vehicles? [Re: McMOPAR*426*] #1249388
11/20/14 07:31 PM
11/20/14 07:31 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Patrick Bennett's last post was May 24th 2013. PM him here, email him at the address listed in his profile. google his name in Mississauga...
good luck.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Were 69 cast blocks used in 70 production vehicles? [Re: 6bblgt] #1249389
11/20/14 08:35 PM
11/20/14 08:35 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Makes it more interesting.
Re: Were 69 cast blocks used in 70 production vehicles? [Re: 62maxwgn] #1249390
11/20/14 09:51 PM
11/20/14 09:51 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Model year production started on August 1st so they would need blocks, heads and manifolds cast before that.
I've found number matching 440 blocks cast in 69 through 71 model year.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Were 69 cast blocks used in 70 production vehicles? [Re: 62maxwgn] #1249391
11/21/14 03:21 AM
11/21/14 03:21 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Since it's not a "HP" engine it is from a C-body - C, D, or F is the missing digit.
