trouble code p1297 #1249264
06/11/12 04:05 PM
06/11/12 04:05 PM
hartsburg mo
biggerredz71 Offline OP
hartsburg mo
I just installed a new 5.9l v-8 in my 98 1500 and it keeps throwing code 1297 map sensor no change from start up,i swapped map sensors from another truck and it did not change a thing.I pulled the intake off and replaced the pan gasket with a good one and it is still throwing this code.Any help would be great. The truck ran great before with the old engine other than a rod knock.
Re: trouble code p1297 [Re: biggerredz71] #1249265
06/11/12 04:14 PM
06/11/12 04:14 PM
Andrewh Offline
Andrewh  Offline
pinch a wire? plug get mangled?
MAP Sensor harness is open or shorted
- MAP Sensor circuit poor electrical connection
- Faulty MAP Sensor
- Faulty ECM
not just bad map.
see if you are getting a signal to it.
Re: trouble code p1297 [Re: Andrewh] #1249266
06/11/12 05:23 PM
06/11/12 05:23 PM
hartsburg mo
hartsburg mo
Well looks like someone had repaired the wireing before and did not do it right,truck runs good now thanks Andrewh.
