Finally
#1246759
06/07/12 08:41 AM
06/07/12 08:41 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Finally getting over to Dynotech today to order my driveshaft for the Rampage... all of 40" long... should be ready to fire it up next week... if all the wiring is right... will be checking all that in the next couple of days... just a few things to do yet... still waiting on a couple of things... a fitting to move the oil filter towards the front of the engine bay.... gotta get the wife to help me bleed the brakes... just some minor stuff then its back to finishing up the interior... will start the body work in a few weeks but wont paint it till I de-bug the thing.... starting to get excited
Re: Finally
[Re: Red440]
#1246761
06/07/12 10:51 AM
06/07/12 10:51 AM
Posts: 1,377 Ohio
Todd
Ohio
Re: Finally
[Re: MR_P_BODY]
#1246763
06/07/12 11:17 AM
06/07/12 11:17 AM
Posts: 7,506 Az
Crizila
Az
What size shaft / u-joints will you be using? DOM, aluminum?
Fastest 300
Re: Finally
[Re: Crizila]
#1246764
06/07/12 01:13 PM
06/07/12 01:13 PM
MR_P_BODY
Based on their suggestion I went with a 3.5" DOM shaft with 1350 joints.... that cost $340 done and balanced... I'll pick it up next Tuesday
Re: Finally
[Re: MR_P_BODY]
#1246767
06/07/12 02:42 PM
06/07/12 02:42 PM
Posts: 12,390 Taxes & Virus's R-US, NY
Dragula
Hey, just a little help on the brake bleeding, pull the cap off the master cylinder, and loosen one bleader at a time and let gravity do its thing...You would be surprised at how well that works. Sometimes you don't even have to wait that long. Last one I did, took less than 2 min and brake fluid was comming out after changing out the rear wheel cylinder in my diesel the other week.
I had one car, for the life of me, I could not get a good pedal on no matter how much I bled them, pulled the cap off, filled the master up all the way to the brim, let it sit thru lunch and diner, and bingo...
Re: Finally
[Re: Dragula]
#1246768
06/07/12 02:45 PM
06/07/12 02:45 PM
dartman366
Mt. Vernon, Ohio
I usually do it that way too and it works suprisingly well, I did buy a mity-vac for those stubborn job's.
Re: Finally
[Re: Dragula]
#1246770
06/07/12 04:27 PM
06/07/12 04:27 PM
MR_P_BODY
Got a real good pedal... my buddy stopped by so I had him help me... of course it had a couple of loose line nuts but after tightening them up it bleed out nice... that master feels real nice(thought it might be on the small size) but its perfect... I put a gauge on the pedal to measure the foot load and at 100# your gonna be locked up big time and it has a nice travel..... very happy
Re: Finally
[Re: Dragula]
#1246771
06/07/12 05:39 PM
06/07/12 05:39 PM
Guitar Jones
That method works great on stock location master cylinders but if the master is below the calipers it ain't gonna work.
Re: Finally
[Re: Guitar Jones]
#1246772
06/07/12 06:29 PM
06/07/12 06:29 PM
MR_P_BODY
Very true... but my master is on the firewall... with the couple of loose nuts it did gravity flow (of course on the floor... I hate that brake fluid) and when the wife brought home another QT of fluid it took all of 5 minutes and it was done(thank you wifey)
Re: Finally
[Re: slantzilla]
#1246775
06/07/12 09:36 PM
06/07/12 09:36 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Nice! can't wait to see this thing out. I'll be hitting up dynotech for a driveshaft soon, hopefully.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
Re: Finally
[Re: Darryls-Demon]
#1246777
06/07/12 09:59 PM
06/07/12 09:59 PM
MR_P_BODY
Looking forward to meeting you and seeing your car at drag week this year Mike, what class will you be running? Spots will open up so Iam sure you will get in this year.
I'm not gonna bother trying to get in this year... but will be in it next year... I am looking forward to it
Re: Finally
[Re: MR_P_BODY]
#1246778
06/08/12 12:38 AM
06/08/12 12:38 AM
Posts: 795 Glendale Az
Darryls-Demon
Glendale Az
If MoparBilly can make it, you can too.
