'69 GTX Vert K Member into a '66 Coronet 500 Vert??? #1246657
06/07/12 12:15 AM
06/07/12 12:15 AM
Iowa, US
oldsklharo Offline OP
Iowa, US
I have a friend that has a fully loaded K member with both the upper A arms, lower control arms upper lower ball joints with disc brake spindles/bearings, steering box, torsion bars, ect.......all still bolted to it laying on the shop floor.
He just put in a new rack/pinion, tubalor A arm coil over racing set up in his car and has graciously given me his old set up. My question is: will his old set up bolt up to my car with no issues? I'm running a BB383 and he has a 440. Pretty sure that doesn't make a difference but I want to just take mine out and bolt the other in
Whatcha think?
Re: '70 GTX Vert K Member into a '66 Coronet 500 Vert??? [Re: oldsklharo] #1246658
06/07/12 12:21 AM
06/07/12 12:21 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Do it , no issues and it gets you the easier and cheaper to buy idler arm.
383 and 440 use the same mounts so there is no difference , you can also bolt a smallblock to that K and your K , mounts are in the same place .
Re: '70 GTX Vert K Member into a '66 Coronet 500 Vert??? [Re: JohnRR] #1246659
06/07/12 12:26 AM
06/07/12 12:26 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
but it's a trick question no such thing as a '70 GTX convertible.
Re: '70 GTX Vert K Member into a '66 Coronet 500 Vert??? [Re: 6bblgt] #1246660
06/07/12 12:38 AM
06/07/12 12:38 AM
JohnRR Offline
JohnRR  Offline
I missed that part, but now that you mention it I have never seen one either
Re: '70 GTX Vert K Member into a '66 Coronet 500 Vert??? [Re: JohnRR] #1246661
06/07/12 12:47 AM
06/07/12 12:47 AM
Iowa, US
Iowa, US
Ya sorry guys it's a '69
Very cool.....thanks for the info. I even gotl the tie rods and sway bar!!
Thanks, Mike
Re: '70 GTX Vert K Member into a '66 Coronet 500 Vert??? [Re: oldsklharo] #1246662
06/07/12 07:20 AM
06/07/12 07:20 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
Mike, you already have the answer to your question but I had to reply as I actually used a K frame from a 69 GTX in my 66 vert. I was still driving the car with the 318 and wanted to build the K frame ahead of time as I did with the entire new drive train. The 69 has double mounting point for the ildler arm and sway bar tabs. I wanted both of those features. When I installed the engine/trans, I bolted it to the k frame and lowered the body over. Absolutely no issues. How is the project coming by the way?
Re: '70 GTX Vert K Member into a '66 Coronet 500 Vert??? [Re: Hemi ragtop] #1246663
06/08/12 11:10 AM
06/08/12 11:10 AM
Iowa, US
Iowa, US
Very cool......if it's good enough for your beast it's good enough for my baby
I also want the sway bar application plus this is a complete front end with disc brake conversion, all new bushings, new steering sector, tie rods, ect.........
This will be a late fall project as I am enjoying driving the pee out of her right now!
Re: '70 GTX Vert K Member into a '66 Coronet 500 Vert??? [Re: oldsklharo] #1246664
06/08/12 11:26 AM
06/08/12 11:26 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Master cylinder will need to be changed from single to dual as well as for the disc brakes. But you knew that right? Maybe a proportioning valve too.
I have mechanical Aptitude.
I can screw up anything.
Re: '70 GTX Vert K Member into a '66 Coronet 500 Vert??? [Re: bboogieart] #1246665
06/08/12 11:54 AM
06/08/12 11:54 AM
Iowa, US
Iowa, US
Yep, I've already put in a power booster earlier this summer but will pick up a dual master cylinder, proportioning valve and new plumbing when it comes time to bolt up the new member
Re: '70 GTX Vert K Member into a '66 Coronet 500 Vert??? [Re: oldsklharo] #1246666
06/08/12 12:35 PM
06/08/12 12:35 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
With the wheel opening of the Dodge being further forward in the fender than the Plymouth, which can be seen in the different splash shields. Did the factory allow for this in the k-frame or where it mounts to the unibody? I know on the rear they used longer spring hangers for the longer Dodge wheelbase.
1969 Hemi Roadrunner 2nd owner
Re: '70 GTX Vert K Member into a '66 Coronet 500 Vert??? [Re: 69hemibeep] #1246667
06/08/12 12:51 PM
06/08/12 12:51 PM
JohnRR Offline
JohnRR  Offline
Edit .... it's an illusion , the torsion bars and the trans crossmember are the same Dodge and Plymouth b body.
Re: '70 GTX Vert K Member into a '66 Coronet 500 Vert??? [Re: 69hemibeep] #1246668
06/08/12 12:55 PM
06/08/12 12:55 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I never noticed the wheel opening being in a different location, just that it has a different shape.
Same with longer spring hangers on a Dodge, never noticed them being longer. I thought the 1" was added to the passenger floor pan.
Re: '70 GTX Vert K Member into a '66 Coronet 500 Vert??? [Re: B5 Bee] #1246669
06/08/12 12:59 PM
06/08/12 12:59 PM
JohnRR Offline
JohnRR  Offline
They added to the floorpan on an A body but on a Plymouth B body there is a different front hanger vs. the Dodge.
Re: '70 GTX Vert K Member into a '66 Coronet 500 Vert??? [Re: JohnRR] #1246670
06/08/12 01:19 PM
06/08/12 01:19 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Thanks John, so the extended splash shield is just for the shape of the opening.
