Re: E-body hood hinges - year over year changes
[Re: YYZ]
#1244828
06/03/12 06:23 PM
06/03/12 06:23 PM
Posts: 2,304 WI
RestoRick
WI
The basics of E-body hood hinge ID- 1970: teeth style; narrow top strap; all same size rivet on peened side. They had a couple minor variations in the base up stop- 1. none 2. welded on tab. 3. stamped in base. Also two different style short straps over the teeth area were used. 1971-72: teeth style; wider top strap; rear rivet on top strap is larger on peened side. Late ones started using '73-4 style base with the slider slots not used. 1973-74: pivot pin/knee action (no teeth); wide top strap. That should cover it. Rick
[Re: RestoRick]
#1244831
06/20/12 10:24 AM
06/20/12 10:24 AM
Posts: 406 California City, CA
dart440
California City, CA
Don't the 70's also have narrower slots where they attach to the hood because the bolts used to mount hood are a smaller diameter?
When you work on Spaceships for a living, how bad can a workday be?
[Re: YYZ]
#1244836
06/21/12 08:07 AM
06/21/12 08:07 AM
Posts: 1,105 Ont, Canada
moparo
Ont, Canada
If you need help with hinges I can help.
performancecarrestorations.com
