E-body hood hinges - year over year changes #1244827
06/03/12 02:34 PM
06/03/12 02:34 PM
Toronto (YYZ) Ontario
YYZ Offline OP
YYZ  Offline OP
What/when were the changes in Cuda/Challenger hood hinges over the years?
Aside from '70 having more coils in the springs - when in production did the interlocking tooth design get stopped?
Thanks in advance
Re: E-body hood hinges - year over year changes [Re: YYZ] #1244828
06/03/12 07:23 PM
06/03/12 07:23 PM
WI
RestoRick Offline
RestoRick  Offline
WI
The basics of E-body hood hinge ID-
1970: teeth style; narrow top strap; all same size rivet on peened side. They had a couple minor variations in the base up stop- 1. none 2. welded on tab. 3. stamped in base. Also two different style short straps over the teeth area were used.
1971-72: teeth style; wider top strap; rear rivet on top strap is larger on peened side. Late ones started using '73-4 style base with the slider slots not used.
1973-74: pivot pin/knee action (no teeth); wide top strap.
That should cover it.
Rick
Re: E-body hood hinges - year over year changes [Re: RestoRick] #1244829
06/20/12 08:41 AM
06/20/12 08:41 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Are the non-tooth design interchangeable with the tooth design? And do they look similar externally?
Presumably the non-teeth design don't suffer the wear problems of the teeth design?
Re: E-body hood hinges - year over year changes [Re: Gavin] #1244830
06/20/12 09:02 AM
06/20/12 09:02 AM
WI
RestoRick Offline
RestoRick  Offline
WI
Yes, tooth vs. non-tooth are interchangeable.
If you know what you're looking at, it's very easy to notice the difference.
The newer non-tooth design is a more durable design. The pins in the swiveling part do get sloppy, but not as quickly as the teeth mesh gets loose on the tooth style.
One point worth mentioning is that the '71-4 B-body hinge will bolt up to an E-body, but has a shorter vertical adjustment slot in the base and a slightly different shaped base, so getting proper hood alignment can be a problem.
Re: E-body hood hinges - year over year changes [Re: RestoRick] #1244831
06/20/12 11:24 AM
06/20/12 11:24 AM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
Don't the 70's also have narrower slots where they attach to the hood because the bolts used to mount hood are a smaller diameter?
When you work on Spaceships for a living, how bad can a workday be?
Re: E-body hood hinges - year over year changes [Re: dart440] #1244832
06/20/12 01:42 PM
06/20/12 01:42 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Yes, slightly narrower, but they're wide enough for the larger 3/8" bolts used on '71-up hoods.
Re: E-body hood hinges - year over year changes [Re: RestoRick] #1244833
06/20/12 10:39 PM
06/20/12 10:39 PM
Northern Virginia
Moparmaniacc Offline
Northern Virginia
Sorry YYZ, but I can only assume you were asking cuz you might need new ones? So here goes a hijack Do you have to push down on the hood by the hinges to get the front of the hood to close? On my '70, I do! Guess I need new hinges, should I go with '73 or '74 hinge?
Re: E-body hood hinges - year over year changes [Re: Moparmaniacc] #1244834
06/21/12 08:23 AM
06/21/12 08:23 AM
WI
RestoRick Offline
RestoRick  Offline
WI
It's primarily a cosmetic issue.. yes, the 73-4 hinge is a better design, but the original tooth design 70 hinge won't give you any trouble on a weekend cruiser. Also, when they're rebuild the fit of the tooth mesh is better than production tolerance, so you're getting a longer service life than new.
Re: E-body hood hinges - year over year changes [Re: RestoRick] #1244835
06/21/12 08:30 AM
06/21/12 08:30 AM
YYZ Offline OP
YYZ  Offline OP
Well, yes, originally. I found a set of super-nice, tight later style hinges which I had hoped to use in the next project.
But they're not correct, so it's time to scare up some nice toothed cores.
Re: E-body hood hinges - year over year changes [Re: YYZ] #1244836
06/21/12 09:07 AM
06/21/12 09:07 AM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
If you need help with hinges I can help.
performancecarrestorations.com
Re: E-body hood hinges - year over year changes [Re: RestoRick] #1244837
06/01/13 10:09 PM
06/01/13 10:09 PM
Toronto, ON
ehbody Offline
ehbody  Offline
Toronto, ON
Rick
What does narrow top strap vs wider top strap mean? what part is that describing?
Shawn 70 AAR
Re: E-body hood hinges - year over year changes [Re: ehbody] #1244838
06/02/13 07:12 AM
06/02/13 07:12 AM
YYZ Offline OP
YYZ  Offline OP
The top strap is the part that bolts to the hood, rather than the inner fender.
If you need a set of nice '70 only hinges, I have some locally.
