70 Challenger 383 , Best replacement Carb #124416
09/22/08 12:42 PM
09/22/08 12:42 PM
Los Angeles CA
ChrisD Offline OP
ChrisD  Offline OP
Los Angeles CA
What carb should I get to replace my Holley 4369? I want this car to be a solid driver . The original Holley was restored wrong and just seems to be a piece of crud. What would you suggest as a replacement? Thanks
Re: 70 Challenger 383 , Best replacement Carb [Re: ChrisD] #124417
09/22/08 01:09 PM
09/22/08 01:09 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Replacement Holley or new Edelbrock 600 cfm from Summit (uses old AVS body, etc.)
Re: 70 Challenger 383 , Best replacement Carb [Re: ChrisD] #124418
09/22/08 01:16 PM
09/22/08 01:16 PM
MoreParts Offline
MoreParts  Offline
My 383 uses a very similar 4368 Holley. They flow more than the std Holley's, and when done right are an excellent running carb. I'd try to find something equivalent.
Re: 70 Challenger 383 , Best replacement Carb [Re: MoreParts] #124419
09/22/08 02:35 PM
09/22/08 02:35 PM
Los Angeles CA
ChrisD Offline OP
ChrisD  Offline OP
Los Angeles CA
Re: 70 Challenger 383 , Best replacement Carb [Re: ChrisD] #124420
09/22/08 03:04 PM
09/22/08 03:04 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Here is the application chart for the Summit carb you listed. Holley 0-80457S
Universal No
Make DODGE
Engine Type V8
CID 318
Liter 5.2
Engine Size 5.2L/318
Beginning Year 1967
Ending Year 1969
Engine Family Mopar small block LA
Transmission Automatic
Emissions Legal No
Usage Street
Universal No
Make DODGE
Engine Type V8
CID 318
Liter 5.2
Beginning Year 1967
Ending Year 1969
Transmission Manual
Emissions Legal No
Usage Street
Re: 70 Challenger 383 , Best replacement Carb [Re: ChrisD] #124421
09/22/08 03:04 PM
09/22/08 03:04 PM
MoreParts Offline
MoreParts  Offline
Chris, I think that would work just fine, but I'd let a real Holley expert make that call for you. They have a tech line you can use to for advice. The thing with our original Holley's were they were a bit different than the square bore you have picked there. They had much larger secondaries which bumped their CFM up to around 750cfm.
Is the one your currently running have the larger opening in the secondaries in your throttle plate? That could be part of the problem. Other problems were people liked to drill out some passages for more flow. Wrong gasket kits, and those metering blocks loved to warp causing all sorts of issues. All good reasons to move to a new one if what you have is beyond repair.
Re: 70 Challenger 383 , Best replacement Carb [Re: ChrisD] #124422
09/22/08 03:05 PM
09/22/08 03:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , thats a ford replacement carb , make note of the fuel line inlet , never mind the non adjustable floats .
Re: 70 Challenger 383 , Best replacement Carb [Re: Snoopy] #124423
09/22/08 03:08 PM
09/22/08 03:08 PM
Snoopy Offline
Snoopy  Offline
This is the one they are recommending Holley 64-3013
Re: 70 Challenger 383 , Best replacement Carb [Re: Snoopy] #124424
09/22/08 08:17 PM
09/22/08 08:17 PM
MO
cdp Offline
cdp  Offline
MO
How about the reliable 3310. Mopar Action did a Demo on Ehrenburg's stock 383 Cuda and hot 50 horse out of the box. This article is probably 10-15 years old.
Re: 70 Challenger 383 , Best replacement Carb [Re: cdp] #124425
09/24/08 12:35 PM
09/24/08 12:35 PM
Los Angeles CA
ChrisD Offline OP
ChrisD  Offline OP
Los Angeles CA
electric choke? or manual?
Re: 70 Challenger 383 , Best replacement Carb [Re: ChrisD] #124426
09/24/08 12:51 PM
09/24/08 12:51 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Chris: You should really consider ending that 4369 to Harms Automotive and have Scott work on it. It will not come back as a piece of crud! He is the best there is for reworking/restoring these carbs.
Re: 70 Challenger 383 , Best replacement Carb [Re: m46rat] #124427
09/24/08 01:01 PM
09/24/08 01:01 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
Anyone know how to get a copy of this article?
Re: 70 Challenger 383 , Best replacement Carb [Re: rss] #124428
09/24/08 01:32 PM
09/24/08 01:32 PM
Los Angeles CA
ChrisD Offline OP
ChrisD  Offline OP
Los Angeles CA
I just called Scott. Im thinking of sending him the Carb.
