Re: Aftermarket A/C for Mopars question
[Re: Fasbird]
#1244033
06/02/12 06:51 PM
06/02/12 06:51 PM
Posts: 2,592 None
71rm23
None
Fasbird- I have a 71 RR. Do you have the A/C heater box? If so, check out Bouchillon performance http://bouchillonperformance.com/I'm leaning towards them for everything forward of the cowl on mine.
[Re: Fasbird]
#1244034
06/02/12 11:03 PM
06/02/12 11:03 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I had factory A/C and converted it to R134 through Classic Auto Air on my 72 Charger.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: gtx6970]
#1244038
06/03/12 12:28 PM
06/03/12 12:28 PM
Posts: 4,912 The Dark Side
Fasbird
The Dark Side
I did a complete vintage air setup in a 1970 Hemi Cuda clone
Using Bouchillon pulleys and engine brackets, sadly they are the parts I'm the least impressed with
Hey Bill!!! How the heck are you doing!!
Sold the 2010 Challenger and bought back my old '71. No one ever said I was smart....
[Re: Fasbird]
#1244039
06/03/12 12:41 PM
06/03/12 12:41 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
[Re: Fasbird]
#1244042
06/03/12 12:51 PM
06/03/12 12:51 PM
OzHemi
Garden Grove, CA
Hey Jeff... It's been a few years since I have been hangin' around Moparts. I must have gotten used to sipping wine while driving the new iron.
maybe I can pursuede 'ol CommPen to make an appearance....
Yep, been a little while for sure..good to see you here slumming it again. And I have a feeling he is still around here somewhere.
[Re: 70RR383]
#1244044
06/03/12 01:00 PM
06/03/12 01:00 PM
Fasbird
The Dark Side
A local guy here just added one to a 71 RoadRunner.I saw it last weekend and it looked good.Under dash vents over the hump.He said it was a very easy install.I did not ask him whos set up it was though.I can find out if interested.
Yes, if you can find out which system he installed. Mine is a big block car. Pics would be cool too, if you have the availability to get. Thanks!
[Re: RJS]
#1244045
06/03/12 01:10 PM
06/03/12 01:10 PM
Fasbird
The Dark Side
When I do it I'm going with Classic Auto Air
Didn't even remember these guys. http://www.classicautoair.com/70_73_Mopar%20E-Body_Air_Conditioning_Mopar_AC.html
Looks like they have adapted the E-Body kit to the 71-74 B-body now. This is worth looking into. However, I will be looking for the "low mount" style brackets for the compressor. With the air grabber, I need to keep all the hosing and components down low. prolly need to have all the hoses custom made.
[Re: Fasbird]
#1244046
06/03/12 01:17 PM
06/03/12 01:17 PM
OzHemi
Garden Grove, CA
When I did the air in the Torana, I needed all custom hoses obviously...I ended up buying the crimping tool and all the hose and fittings I needed and made them all up myself.
Lets you run them exactly how you want and with crimping them yourself..you can sort of design and route them as you go.
(more than a year later and it still blows cold so the crimps worked perfectly in my case. )
[Re: Fasbird]
#1244047
06/03/12 03:54 PM
06/03/12 03:54 PM
Posts: 21,449 It's a dry heat
gtx6970
It's a dry heat
Gary, thats good to hear. I used Vintage Air for the box. It's all electronic controls. That way there are no vacuum lines and/or control cables to worry about. Firewall forward is all Bouchillon and it was mostly a bolt in deal. The kit I used was made for an air car. BUT, I simply made my own bracket to mount the box to it instead of to the car. That way I was able to use all the stock Non A/C car box mounting points , just in case the owner decides to someday put the car back to a stock AAR( Although I seriously doubt that'll happen)
