Ladder bar x-member. Which is better? round or square? #1243607
06/01/12 05:40 PM
06/01/12 05:40 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Any opinions? My friend's car has a home made square tubing one that has broke 3 times now. Looks like it was a nice piece at one time but has been in the car since the early 70's and is just been scabbed up too much to repair again. Just wanting opinions/experience with different types/brands. Thanks, Beep
Re: Ladder bar x-member. Which is better? round or square? [Re: Bigbeep] #1243608
06/01/12 05:49 PM
06/01/12 05:49 PM
okla.
sam64 Offline
sam64  Offline
okla.
if you don't brace either one of them properly they will twist and break at the frame.i use round and diagonal brace to the point of the front ladder bar brackets.
Re: Ladder bar x-member. Which is better? round or square? [Re: sam64] #1243609
06/01/12 06:07 PM
06/01/12 06:07 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
The one in the car is braced right on top of the front rod end of the ladder bar with a diagonal off the main hoop. It actually is an X from the main hoop to the LB mounts. This one keeps cracking in the center of the car. Under the drive shaft or just to the side of it. Hope that reads right. Kind of hard to explain without pics.
Would you think that it should have a gusset from that area to the frame ties? Beep
Re: Ladder bar x-member. Which is better? round or square? [Re: Bigbeep] #1243610
06/01/12 06:22 PM
06/01/12 06:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
That sounds bad for me. I did my new car the same way.
Doug
Re: Ladder bar x-member. Which is better? round or square? [Re: dvw] #1243611
06/01/12 06:28 PM
06/01/12 06:28 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
You have to remember that this was installed in the early 70's. Lots of use and fatique I am sure. Just hoping for some insight if round may be better than square/rectangular? Beep
Re: Ladder bar x-member. Which is better? round or square? [Re: Bigbeep] #1243612
06/01/12 06:38 PM
06/01/12 06:38 PM
okla.
sam64 Offline
sam64  Offline
okla.
i have seen them crack by the frame but not out where you are saying.so i'm not sure what one would look for on that,i would be looking at the whole frame work.
Re: Ladder bar x-member. Which is better? round or square? [Re: Bigbeep] #1243613
06/02/12 12:22 AM
06/02/12 12:22 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Hard to figure. Can you give us a drawing?
Boffin Emeritus
Re: Ladder bar x-member. Which is better? round or square? [Re: Bigbeep] #1243614
06/02/12 12:48 AM
06/02/12 12:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You need to brace it at the bottom of the front heim
area so you take the torsional twist out... being braced
on the top will control forward push but not the torsional
twisting... either round or rectangular is fine but
round is lighter weight... but if your replacing it
might be easier to go back with rectangular(3 X 2 X.125)...
he might have .090 wall in it now
EDIT
also... where they bend the loop area its thinner
due to drawing it around on the bender
Re: Ladder bar x-member. Which is better? round or square? [Re: MR_P_BODY] #1243615
06/03/12 10:12 PM
06/03/12 10:12 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Mr P, is this what you mean for a brace from the bottom of the front mount. The tube in red being the support to be added.
Re: Ladder bar x-member. Which is better? round or square? [Re: Bigbeep] #1243616
06/03/12 10:21 PM
06/03/12 10:21 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
If you use the bottom hole, there is still alot of leverage on that bracket
Alan Jones
Re: Ladder bar x-member. Which is better? round or square? [Re: LA360] #1243617
06/03/12 10:29 PM
06/03/12 10:29 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
I agree. You thinking of bringing the support off the side of the bracket up to the frame tie? Beep
Re: Ladder bar x-member. Which is better? round or square? [Re: Bigbeep] #1243618
06/03/12 10:42 PM
06/03/12 10:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Move the red tube to the bottom(forward edge) of the
ladder bar bracket.... mount it right in front of
the bottom hole on the bracket
Re: Ladder bar x-member. Which is better? round or square? [Re: Bigbeep] #1243619
06/04/12 01:26 AM
06/04/12 01:26 AM
gregsdart Offline
gregsdart  Offline
I have been running a 2 x 3 x .125 wall in the Dart, no added bracing. Not saying it isn't needed, just worked well for me so far. My brackets might be the reason, they are centered on the cross member rather than part way down as per the photo. My brackets are also as close as you can get to the frame rails and still get a nut on the bolt.
I like the 2 x 3 because it helps add stiffness to the chassis.
Re: Ladder bar x-member. Which is better? round or square? [Re: gregsdart] #1243620
06/04/12 09:58 PM
06/04/12 09:58 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Thanks guys, Beep
