Re: Ladder bar x-member. Which is better? round or square?
[Re: Bigbeep]
#1243613
06/02/12 12:22 AM
06/02/12 12:22 AM
Posts: 4,206 New York
polyspheric
New York
Hard to figure. Can you give us a drawing?
Boffin Emeritus
[Re: Bigbeep]
#1243614
06/02/12 12:48 AM
06/02/12 12:48 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You need to brace it at the bottom of the front heim area so you take the torsional twist out... being braced on the top will control forward push but not the torsional twisting... either round or rectangular is fine but round is lighter weight... but if your replacing it might be easier to go back with rectangular(3 X 2 X.125)... he might have .090 wall in it now EDIT also... where they bend the loop area its thinner due to drawing it around on the bender
[Re: Bigbeep]
#1243618
06/03/12 10:42 PM
06/03/12 10:42 PM
MR_P_BODY
Mr P, is this what you mean for a brace from the bottom of the front mount. The tube in red being the support to be added.
Move the red tube to the bottom(forward edge) of the ladder bar bracket.... mount it right in front of the bottom hole on the bracket
