Autozone radiator in 73 Dodge truck
#1243428
06/01/12 08:38 AM
06/01/12 08:38 AM
Posts: 1,878 Detroit, MI
GetAwayDriver
Detroit, MI
Just bought a new parts store radiator for my 73 work truck (400). Installed and found the inlet on the opposite (left) side. The new Rad has an emissions fitting on the right boss where the '73 would normally have its hose. I figure they probably made a design change at some point in the 70s when they started adding emissions to trucks. Thus if I ordered a hose for a '78 big block, it should fit both the thermostat side (since that never changed) and the radiator side. Make sense?
Re: Autozone radiator in 73 Dodge truck
[Re: dhkennedy]
#1243432
06/03/12 02:40 AM
06/03/12 02:40 AM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
Actually you got a radiator for a smallblock. 73 and later big blocks A/C or not had BOTH outlets on the passenger side. You could get a flex hose and use the new rad or get the correct one.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
[Re: GetAwayDriver]
#1243435
06/09/12 03:18 AM
06/09/12 03:18 AM
MoPar Jamie
Sarcoxie, MO, USA
When I built one of my big block trucks I used a flex hose to run behind the compressor to clear everything. Thats pretty much your only option in this case. My '72 Monaco is going to get one as well but there is no compressor to clear.
- MoPar Jamie
