383 from 70 newport vs 383 from 70 bee #1242947
05/31/12 09:20 PM
05/31/12 09:20 PM
mississauga, ontario, canada
P
patbee383 Offline OP
P
whats the difference? anything? i found A 70 383 engine for my bee but i dont know a lot about engines apparently its out of a 70 newport. seller has done some refreshing,rings bearings, purple cam, oil pump, 906 heads shaved 0.20 thou timing gears, alum intake....price is right just not sure.
1970 Dodge Superbee 2008 Dodge Ram 2500 HEAVY DUTY 2011 Dodge Caravan 2002 Honda Accord?
Re: 383 from 70 newport vs 383 from 70 bee [Re: patbee383] #1242948
05/31/12 09:24 PM
05/31/12 09:24 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
As I recall, the only difference in 1970 between a HP stamped 383 and a non HP 383 was the pistons (compression ratio), camshaft, and possibly the intake if the non HP was a 2bbl.
Re: 383 from 70 newport vs 383 from 70 bee [Re: patbee383] #1242949
05/31/12 09:25 PM
05/31/12 09:25 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
The Newport engine is likely a 2bbl . L code in the vin would confirm that.
Re: 383 from 70 newport vs 383 from 70 bee [Re: formula_s] #1242950
05/31/12 09:29 PM
05/31/12 09:29 PM
P
P
only #'s i could see on engine were 2 13 70 and 246813012
Re: 383 from 70 newport vs 383 from 70 bee [Re: patbee383] #1242951
05/31/12 09:37 PM
05/31/12 09:37 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
That engine is modified so it doesn't really matter now.
Re: 383 from 70 newport vs 383 from 70 bee [Re: Dan Halen] #1242952
06/01/12 09:16 AM
06/01/12 09:16 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what he said. Just make sure what "purple cam" it is. if it's a 484 or 509 you are going to want a 3000 stall and 3.91's otherwise it WILL be a dog.
Coming soon!!!!
Re: 383 from 70 newport vs 383 from 70 bee [Re: Dan Halen] #1242953
06/01/12 09:53 AM
06/01/12 09:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Pretty much except it will be a lower compression engine, something near 8.5 if he is lucky, if the pistons were not changed. The Newport engine would more than likely have been a 2bbl engine.
Re: 383 from 70 newport vs 383 from 70 bee [Re: JohnRR] #1242954
06/01/12 08:30 PM
06/01/12 08:30 PM
P
P
My bee is a 4 speed, being restored by Alan Galant. I am and down to the engine now and i am frantically looking for something and found this ad on kijiji for 383 has 10k on it since refreshing...new bearings,new rings,polished steel crank(standard specs),906 heads with valve job, heads shaved 0.20 thou, purple street strip cam(lumpy idle)edelbrock double roller timing chain,high volume oil pump etc. etc. i went to look at it...it looks like an engine, lol
my research says 383 all cast same place only difference from hp to non hp is cam and lifters and intake (2 or 4 barrel)try to stay as origanal as possible or i could put cthe 73 440 that was in it back in. but for about 1200 i might chance this 383?
Re: 383 from 70 newport vs 383 from 70 bee [Re: patbee383] #1242955
06/01/12 08:52 PM
06/01/12 08:52 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
a 383 block is a block is a block, same goes for the heads. As others have mentioned, it's been apart and rebuilt so it's an unknown. If you're on a budget, for that price I would try it rather than putting the 440 back in. Worst case you have the block to build it correctly down the road.
Alan's has done nice work on the car, I'm sure you'll be pleased.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 383 from 70 newport vs 383 from 70 bee [Re: DPelletier] #1242956
06/01/12 09:07 PM
06/01/12 09:07 PM
P
P
More than pleased with his attention to detail! just stressin over engine decision but like you said for the money its probably worth a shot my only concern is the cam he has in it, but i can deal with that. Option #2 is a 383 alan has lined up but it needs to be completely gone through, probably 2500 to 3500 by the time thats done!Thanks for the reply, heard Alan mention your name a few times, hopefully we can get our bee's side by side some day!
Re: 383 from 70 newport vs 383 from 70 bee [Re: Mr.Yuck] #1242957
06/01/12 10:38 PM
06/01/12 10:38 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
And if it is a 484 or 509 i'd change it before I installed the engine.
Re: 383 from 70 newport vs 383 from 70 bee [Re: pushbutton] #1242958
06/02/12 08:59 AM
06/02/12 08:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Just make sure that the crank is drilled deep enough to fit the pilot bushing and the trans and you should be good to go .
Did you hear the engine run ?
Re: 383 from 70 newport vs 383 from 70 bee [Re: JohnRR] #1242959
06/02/12 01:01 PM
06/02/12 01:01 PM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
Stock the differences would have been lower compression pistons if 2 bbl. Cam, 383 Magnum Bee would have got a 440 Magnum cam, and the 383 Magnum probably came with a windage tray too.
Re: 383 from 70 newport vs 383 from 70 bee [Re: Silverbullet2] #1242960
06/02/12 02:00 PM
06/02/12 02:00 PM
P
P
Didnt hear it run, he assured me its fine, he had just pulled it out of his 69 charger(opted for a 440) He will also give me the cam and lifters from a 440 that was in the 383, said he labeled where everything cam out of, plus a bunch of small parts...starter, headers etc. going back tomorrow, going to check pad behind distributor for numbers (didnt know where it was located on a 383) and try to swing a good deal.
Re: 383 from 70 newport vs 383 from 70 bee [Re: patbee383] #1242961
06/02/12 02:25 PM
06/02/12 02:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I wouldn't waste time or effort on the used cam for the other engine but that me .
I don't know how trusting you are but unless the guy will stand behind it till you have it running I would be leary of taking his word that it's ok. I passed on an engine that someone used that line on , it came with a taillight warranty , once my taillights were out of his sight so was any warranty . Good thing I did , I ran into the person that did end up buying it and it turned out to need to be bored and rebuilt, he salvaged very little from it and got nothing back from the seller.
