Converting to 6 Barrels, Where to buy? #1242843
05/31/12 03:30 PM
05/31/12 03:30 PM
Central ND
440custom Offline OP
Central ND
I'm thinking of taking the plunge and going to a Six Pack on my 440. I see they have 69/70 carbs and then they have 71 Carbs. What's the difference? What's simpler? Also is there a vendor that has the manifold, carbs, installation hardware etc that sells everything in package form at a discounted price so to speak?
The car is a 74 Barracuda with an automatic, 3.23 gears etc with right around a 2500 rpm stall. Motor has a mild hilift comp cam (hyd). 10 to 1 compression, Eddy heads. I have a Holley hi-volume mech fuel pump on it now, that I've read may need a regulator?
I know they take a bit of patience to tune and get sorted, but lets face it, it's pretty neat to pull the air cleaner and see those carbs sitting there! Thanks
Re: Converting to 6 Barrels, Where to buy? [Re: 440custom] #1242844
05/31/12 03:53 PM
05/31/12 03:53 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
well, i got my manifold at a National Auto store and all the carbs from Mancini. keep in mind this was 25 years ago ! today you can get this stuff at any number of vendors including needed linkage, brackets and stuff like that. i would shy away from Year One as while the quality is there the price isn't. do a little shopping around get prices and then do yourself a big favor. call Dixie (member here) and see what he can do.
Re: Converting to 6 Barrels, Where to buy? [Re: mikemee1331] #1242845
05/31/12 03:56 PM
05/31/12 03:56 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Scott
1969 Super Bee, 383/4 speed
Re: Converting to 6 Barrels, Where to buy? [Re: 440custom] #1242846
05/31/12 04:30 PM
05/31/12 04:30 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Call Ben ask and him
http://promaxcarbs.com/
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Converting to 6 Barrels, Where to buy? [Re: 440custom] #1242847
05/31/12 05:31 PM
05/31/12 05:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
There a new 440 6 manifold in the parts section on Moparts, pretty good price, Summit Racing probally has the best carb prices, I'd recommend the 340 Carbs on your 440 set-up, larger air bleeds, same CFM as the 440 carbs, better price also, air cleaner from Mancini Racing or Summit, shop around, sometimes the one stop shop isn't the best deal, linkage can be had from SummitRacing, only air filter elements available right now are the K&N's...
Re: Converting to 6 Barrels, Where to buy? [Re: DAYCLONA] #1242848
05/31/12 06:12 PM
05/31/12 06:12 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Herbs Parts
Herbs has pretty good prices on complete set ups and is great to deal with.
Re: Converting to 6 Barrels, Where to buy? [Re: 440custom] #1242849
05/31/12 06:26 PM
05/31/12 06:26 PM
AndyF Offline
AndyF  Offline
Mancini Racing should have everything you need to go six-pack.
Re: Converting to 6 Barrels, Where to buy? [Re: AndyF] #1242850
06/01/12 11:12 PM
06/01/12 11:12 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Atlantic speed got mine for $2100 shipped... w/ $100 off e-bay coupon
Coming soon!!!!
