Page 1 of 4 1 2 3 4
My Holley Idles Too High!! #1242553
05/31/12 12:32 AM
05/31/12 12:32 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
I can't seem to get my car to idle down. When I first got it running, it didn't want to stay running at all, would idle high and want to stall. Now it just wants to idle high and I didn't do anything to the carb yet. It idles at 1,400rpm in neutral, 1,100 in drive. The carburetor is a 4150 800 cfm double pumper #4780. Proform main body, no choke tower.
Specifics on the car (if it matters) are:
71 Demon may be around 2900#
340 stock stroke
275cfm iron heads
10.49:1 comp
904 trans w/TB
5500 stall
4.88 gears w/32" tires
So far I have pulled the float inspection screws, could see the fuel level.
Messing with the idle screw does nothing.
Messing with the mixture screws on the metering block does nothing. Does not have mixture screws on the rear metering block (don't know why?)
I sprayed carb cleaner around the intake, around the 1.5" spacer top and bottom, and all over the carb to check for a vacuum leak and the rpms stayed the same...right at 1,400rpm. All the vacuum ports on the carb are blocked.
I have no clue what to do here does anybody have any advice for me? I don't have much experience with Holleys, or carbs in general so I am not sure where to go from here and I am supposed to race in two days.
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: My Holley Idles Too High!! [Re: knyech1] #1242554
05/31/12 12:44 AM
05/31/12 12:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Is there some play in the throttle cable... that
might be your issue
Re: My Holley Idles Too High!! [Re: knyech1] #1242555
05/31/12 12:47 AM
05/31/12 12:47 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
There's a small screw that adjust the secondary throttle blades on the pass. side of the carb. You'll have to hold the arm wide open to adjust it. See if that's your problem.
Power valve?
Re: My Holley Idles Too High!! [Re: MR_P_BODY] #1242556
05/31/12 12:53 AM
05/31/12 12:53 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
might be your issue
There is some play in the throttle cable (Lokar cable with Jeg's dual return spring setup). I could just remove the cable I suppose to eliminate that possibility but since it had play I didn't deem it necessary to do...
Re: My Holley Idles Too High!! [Re: 64Post] #1242557
05/31/12 12:59 AM
05/31/12 12:59 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Power valve?
I did not check that, though I thought about it. I need to adjust that screw till they are just barely open? Not sure how to measure that, or what to do there.
What could be wrong with the power valve? I thought its function was for WOT? It may have been damaged though because a week ago when I was trying to start the car it tried and died, and a little flame came out of the carb. Wasn't a backfire though so I didn't think much of it.
Re: My Holley Idles Too High!! [Re: knyech1] #1242558
05/31/12 01:34 AM
05/31/12 01:34 AM
Louisiana
Red440 Online content
Red440  Online Content
Louisiana
check for vacuum leaks, something maybe loose carb, intake , carb spacer
Re: My Holley Idles Too High!! [Re: Red440] #1242559
05/31/12 01:54 AM
05/31/12 01:54 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
What cam is in the thing? That will be the biggest factor in idle quality.
Also, how is the timing? Initial and total.
Could be mechanical interference somewhere. Disconnect the throttle cable and see if it resets.
Re: My Holley Idles Too High!! [Re: Red440] #1242560
05/31/12 02:00 AM
05/31/12 02:00 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
I sprayed the carb cleaner all over thinking that would expose the leak if there was one, but nothing happened. I will go check and see if something loosened up... ...ok checked the carb and it was tight. Checked the intake for the 4th time now and actually 2 bolts were not quite torqued down. I say torqued down but I can't get a torque wrench on them (RPM Air Gap, the middle two bolts on either side). I tightened them up a bit. Would start the car now, but it's midnight and I don't want to have the police called on me...again. Neighbors don't like young whippersnappers like me having loud cars, trucks and bikes
Will start it tomorrow and let you all know what happens.
Re: My Holley Idles Too High!! [Re: RobX4406] #1242561
05/31/12 02:03 AM
05/31/12 02:03 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
The cam is a solid flat tappet .540 242deg@.050 installed at 104deg
Would love to hear the engine actually idle with it. I tried to set the timing as best I could but with the rpms so fast I can't really read it. Any suggestions?
I will disconnect the cable tomorrow and see if that helps.
Re: My Holley Idles Too High!! [Re: RobX4406] #1242562
05/31/12 02:10 AM
05/31/12 02:10 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Idle ajustment screw on the primary's that would also explain the no response out of the idle quality screws, I would take it off and reset the throttle blades and make sure they are set right with the idle transferr slots in the base plate and check for any mechanical interference, could also be an internal vacuum leak also that wouldn't show up with the carb cleaner trick. was there a vacuum hose left off some where, also does it have power brakes, maybe a faulty booster. I'm still thinking
Re: My Holley Idles Too High!! [Re: knyech1] #1242563
05/31/12 02:11 AM
05/31/12 02:11 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
whats the initial timing? that cam will want it up a bit
Re: My Holley Idles Too High!! [Re: dartman366] #1242564
05/31/12 02:13 AM
05/31/12 02:13 AM
RobX4406 Offline
RobX4406  Offline
Should be able to idle that down to the 950-1000 range if everything is right.
I'll say I'd put about 20-22 initial timing on it. That's where my 340 with a 528 mechanical wanted it.
Re: My Holley Idles Too High!! [Re: dartman366] #1242565
05/31/12 02:15 AM
05/31/12 02:15 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
I will double check for missing vacuum hoses, but they should all be blocked off. I have manual brakes :/
How can I reset the throttle blades? Please bear with me I am kind of carb dumb, didn't know the throttle blades could be reset.
Re: My Holley Idles Too High!! [Re: RobX4406] #1242566
05/31/12 02:18 AM
05/31/12 02:18 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Rebel and RobX, I am not sure how to set initial timing I guess. I thought initial timing had to be set below 1,000rpm and above that your distributor started to advance...I guess I may be wrong. If I am I could tell you what I have it set at tomorrow probably. IIRC I tried to set it at 23deg.
Re: My Holley Idles Too High!! [Re: RobX4406] #1242567
05/31/12 02:20 AM
05/31/12 02:20 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
after re-reading you say the idle screw has no effect, then as mentioned check the secondary stop/idle screw and reset the blades to the transfer slot's and leave the throttle cable off if all works out then readjust the throttle cable to give you a little slack. still thinking
Re: My Holley Idles Too High!! [Re: knyech1] #1242568
05/31/12 02:21 AM
05/31/12 02:21 AM
RobX4406 Offline
RobX4406  Offline
As long as it's not bleeding in mechanical advance at idle, you're setting initial. Don't worry about total at this point. Not sure why you are having trouble seeing it. Pretty easy unless you have a chrome damper or no marks to reference.
23 initial, if correct, is a decent starting point for that set up IMO.
If using a stock damper, hillbilly timing tape it.
Re: My Holley Idles Too High!! [Re: knyech1] #1242569
05/31/12 02:26 AM
05/31/12 02:26 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
It should be set at idle, but thats the problem,,can you check the total to see that you are not out of the ballpark with it by having way too much? lot's of times I have seen too much timing cause a high idle, maybe not as much as yours but elevated.
Re: My Holley Idles Too High!! [Re: dartman366] #1242570
05/31/12 07:15 AM
05/31/12 07:15 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Check your Dist could be advance springs stuck .I didn't see what dist you had does it have a vac advance ?
Turn the Sec screw you will have to have a wierd screwdriver Home made to go up to that screw shut the butterfly more .
One ?? when you rev it ,does it come back down ?
Re: My Holley Idles Too High!! [Re: RobX4406] #1242571
05/31/12 09:28 AM
05/31/12 09:28 AM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Its a nice shiny SFI damper from Summit and it is kind of difficult to read. I will do it in the garage this afternoon and see what it says.
dartman366, how high do I need to have the rpms to make sure I am reading total timing and what should that number be?
10 o to go, my distributor is a factory electronic with vacuum advance, BUT I have the vacuum line blocked off.
When I rev it up it comes right back to 1,400rpm
Re: My Holley Idles Too High!! [Re: knyech1] #1242572
05/31/12 09:43 AM
05/31/12 09:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Get it up to 3000rpm to set the total timing...34*
should be close for testing... then you can tweek
it in on the track.... if it drops right back to 1400
it sounds like its a mech issue... check the secondary
screw to see if its too high.... IF you want to pull
the carb off to set the transfer slot you can...
once its off flip it over(gas will pour out) and
look at the slot at the throttle blades....set the
throttle so that the slot makes a square hole...
if the blades are open too far you are past the idle
circuit so the idle mixture screws wont have any
effect... so get it down on the idle then mess with
the mixture and idle set screw...... you said that
the throttle cable has some slack so that MOST LIKELY
isnt the issue... check the secondary screw... timing
comes first though... then the carb
Page 1 of 4 1 2 3 4
