Connecting rod end play question. #1240648
05/27/12 10:59 PM
05/27/12 10:59 PM
Tennessee
Charger500 Offline OP
Tennessee
I am in the process of building a 493 stroker for street strip use and have a question regarding connecting rod end play. I have an eagle crank, H beam rods and clevite bearings. I had the tolerences checked by the shop when everything was balanced. One set of rods seams tight. I can get a .006 feeler guage between the rods and between the outside of the rods and crank at the same time. I can separate the other rods and get a .014 feeler gauge between them. The assembly seems to rotate without any binding. But, I don't know what the end play should be.
Re: Connecting rod end play question. [Re: Charger500] #1240649
05/28/12 12:01 AM
05/28/12 12:01 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I would have no worries with .014" con rod side clearance if that's what you're asking?
Re: Connecting rod end play question. [Re: Dcuda69] #1240650
05/28/12 12:08 AM
05/28/12 12:08 AM
Tennessee
Tennessee
I was told by one builder that if I could separate the rods and get a gap of .010 to .014 I was good. I can get that with all but one set. That set i get .006 as stated above. Is that acceptable?
Re: Connecting rod end play question. [Re: Charger500] #1240651
05/28/12 12:42 AM
05/28/12 12:42 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
no .006 rod side clearance is too tight. Gotta belt sander? Use it.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Connecting rod end play question. [Re: HemiRick] #1240652
05/28/12 01:34 AM
05/28/12 01:34 AM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
Could be possible that you have the upper and lower rod bearing shells mixed up on one of the rods, that would make your rod bearing hit the radius of the crank instead of the correct way that would have the side of the connecting rod touch the crank.
Re: Connecting rod end play question. [Re: Charger500] #1240653
05/28/12 05:29 AM
05/28/12 05:29 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I had one set of rods tighter than the rest, ended up being the bearing notch in the rod was slightly off and the bearing was pushing against the radius of the crank. I just chamfered the bearing slightly, and it was fine.
Re: Connecting rod end play question. [Re: 451Mopar] #1240654
05/28/12 08:22 AM
05/28/12 08:22 AM
Tennessee
Tennessee
I didn't realize there was a top and bottom. I noticed there was an oil hole in one of the bearings, but didn't realize there was a top and bottom. That could be my problem.
Re: Connecting rod end play question. [Re: Charger500] #1240655
05/28/12 09:44 AM
05/28/12 09:44 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The bearings will either be "narrow" or "chamfered" for crank radius clearance. For one reason or another, I'll bet the bearing is hitting the radius. You should be able to move the rod front to back and when the rod hits the cheek of the crank, there needs to be a distinctive metal to metal slap sound. If the bearing is hitting the radius, it will sound dull, completely different.
Re: Connecting rod end play question. [Re: BSB67] #1240656
05/28/12 10:33 AM
05/28/12 10:33 AM
Tennessee
Tennessee
Thanks for all of the replies. I had several bearings switched top and bottom. Changed them around and everything is perfect. Thanks again.
