wilwood brakes #1240583
05/27/12 07:57 PM
05/27/12 07:57 PM
superstreet1896 Offline OP
i have one season on these wilwood brakes. rear disc. doing routine maintenance i noticed the hat had a little play in. the left brake had none at all. is this normal.
Re: wilwood brakes [Re: superstreet1896] #1240584
05/27/12 08:47 PM
05/27/12 08:47 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Are yiou saying the hat was loose from the rotor?
Loose fit to the axle?
A gap between the rotor and brake pads?
Lugnuts tight?
Re: wilwood brakes [Re: Clanton] #1240585
05/27/12 09:27 PM
05/27/12 09:27 PM
i think the hat is loose from the rotor. but not sure. dont want to mess with it unless i have to. im thinking ill check the bolts conecting the had and rotor and make sure they are torqued corectly. just wondering if this has happend to anybody else so i know what im looking for
Re: wilwood brakes [Re: superstreet1896] #1240586
05/27/12 09:54 PM
05/27/12 09:54 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
You sure dont want any loose bolts!Did you lictite where needed or safety wire any bolts?
Re: wilwood brakes [Re: superstreet1896] #1240587
05/28/12 01:01 AM
05/28/12 01:01 AM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
put safety wire on them.
Re: wilwood brakes [Re: Plymouth340] #1240588
05/28/12 11:10 AM
05/28/12 11:10 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
My Wilwoods are prehistoric. The hats have never come loose.
Safety wired and Locktited. Though I doubt at the temps rotors run at if the locktite does much.
Doug
Re: wilwood brakes [Re: dvw] #1240589
05/28/12 11:16 AM
05/28/12 11:16 AM
no safety wire, i think i will atleast do that.
Re: wilwood brakes [Re: superstreet1896] #1240590
05/28/12 04:57 PM
05/28/12 04:57 PM
Safety wired and Loc-tite both here!
Re: wilwood brakes [Re: superstreet1896] #1240591
05/29/12 05:16 PM
05/29/12 05:16 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i just finished mine going back togather so i have some pics.
Re: wilwood brakes [Re: Clanton] #1240592
05/29/12 05:21 PM
05/29/12 05:21 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
on the back the only safety wire is on the 2 caliper bolts to eachother that i did after this pic.
Re: wilwood brakes [Re: Clanton] #1240593
05/29/12 06:53 PM
05/29/12 06:53 PM
west coast
P
produster Offline
produster  Offline
P
west coast
What is the p/n on the double caliper rears? Also will a 15" dia rim fit or are you stuck with a 16"?
Re: wilwood brakes [Re: produster] #1240594
05/29/12 11:52 PM
05/29/12 11:52 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I had to make the axle bracket for the dbl caliper.i use the mopar green bearing axle ends but if you use a ford end i think thay have a dbl bracket but i dont have a part #.i think it was Dramperformance that said he would make a dbl bracket if someone wanted.
PS: i use 15" convo pro rim and clear brakes.
