426 hemi main cap studs kit (ARP) #1237039
05/21/12 01:17 PM
05/21/12 01:17 PM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
Hi,
I need new hemi main studs kit. 4 of the old studs flex a lot and I need new ones. Is it the same kit for OEM 426 hemi blocks as my aftermarket MP iron siamese hemi block?
What ARP part # do I need?
1964 Dodge 330 Max Wedge clone
1965 Dodge Hemi A990 clone
Re: 426 hemi main cap studs kit (ARP) [Re: Snoddas] #1237040
05/21/12 01:43 PM
05/21/12 01:43 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
The ARP kit I used for my MP block was #145-5601
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: 426 hemi main cap studs kit (ARP) [Re: Snoddas] #1237041
05/21/12 02:15 PM
05/21/12 02:15 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
not sure of the part numbers and don't know if the kit will fit the hemi. what i can say is that ARP recommended the hemi kit for the wedge megablock i put together for a friend and the studs were not long enough. i had to measure the length and order loose studs. i asked ARP to make a new PN with the lengths i gave them but they never did. the hemi kit would've worked but imho it was not right i wanted full thread engagement.
Re: 426 hemi main cap studs kit (ARP) [Re: jamesc] #1237042
05/21/12 04:41 PM
05/21/12 04:41 PM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
Looked at summit... They seems to have tree different kits for hemi.
145-5601, 145-5602 and 145-5603. The last one íts designed for world block only. The other ones is for 2-bolt main and 4-bolt main.
The 145-5601 is for 2-bolt main?
Re: 426 hemi main cap studs kit (ARP) [Re: Snoddas] #1237043
05/21/12 11:25 PM
05/21/12 11:25 PM
jamesc Offline
jamesc  Offline
just a guess on my part but i'm thinking the 145-5601 only contains the actual main studs while the 145-5602 contains the main and side fasteners. maybe the 145-5603 has the slightly longer studs but i don't know.
i didn't write down the length of the studs i ended up using in the megablock so i can't give the sizes. i know the studs i used were longer than the stock hemi kit. i also didn't use bolts on the main cap sides. i measured and ordered studs, hardened washers and 12 point nuts for the side fasteners.
sorry i can't be of more help but given your location you want to make sure you get the right parts first time. you might try contacting ARP directly or hopefully someone here can answer you question for certain.
Re: 426 hemi main cap studs kit (ARP) [Re: Snoddas] #1237044
05/22/12 12:13 AM
05/22/12 12:13 AM
Mt. Eden Ky.
Mt. Eden Ky.
All I can tell you for sure is the 145-5601 kit is for Hemi, but does not include the cross or side bolts.
1996 Ram 1500 Sport
1968 road runner
Re: 426 hemi main cap studs kit (ARP) [Re: Hemi Allstate] #1237045
05/22/12 01:59 AM
05/22/12 01:59 AM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
Thanks guys. I ended up calling Tim at FHO and he will help me. Its the kit for world block I need. He ask for some detailing on my block and directly could say it was world block casting.
Thanks again
