trow out bearing #1236263
05/20/12 05:17 AM
05/20/12 05:17 AM
Santa Clara , ca
ramcuda Offline OP
ramcuda  Offline OP
Santa Clara , ca
ok we are on to the 2nd TO Bering....
Who makes a great Bearing ... even something heavy duty
We have a 69 trans with the 18splin so that uses the bigger TO bearing.
we are running the Borg cover and a DF plate it all McLeod
Now we can buy a new bearing with sleeve or just the bearing.. I dont care ether way I just want one that wont go out in less than 5k miles
So any input helps
1965 Ply "RAMCUDA" got to see it!!!<--- Should sell it/
1970 Superbird <------ Just one big argument/
1980 Jeep CJ5 <--- Just wheel it/
2000 Dakota R/T <--- Should Drive it more/
2001 Dodge Caravan <----- Cant kill it/
2004 Dodge 2500 4dr DIZLE 4x4 <---- LOVE IT !!!
www.moparalley.org
Re: trow out bearing [Re: ramcuda] #1236264
05/20/12 08:18 AM
05/20/12 08:18 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Throw out bearings are not designed for constant spinning as they will heat up, their grease will melt out and the will become noisey and fail.
The only time a throw out bearing wears is when it is spinning. If you are wearing one out in only 5000 miles, you are either riding the clutch, resting your foot on the clutch pedal when you drive or your linkage is out of adjustment causing it not to fully release and continue to spin when the clutch should be fully released.
Re: trow out bearing [Re: ramcuda] #1236265
05/20/12 05:08 PM
05/20/12 05:08 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
When adjusting free play..
Pull off the inspection plate down below and double-check that the bearing is being pulled back from the pressure plate...
Judging free play up top with worn 40 year old linkage has problems..
Just my $0.02...
Re: trow out bearing [Re: Sinitro] #1236266
05/20/12 07:41 PM
05/20/12 07:41 PM
Santa Clara , ca
ramcuda Offline OP
ramcuda  Offline OP
Santa Clara , ca
Ya I know how and why they go out .. i dont ride the clutch or rest my foot...and i have it adjusted to where its not riding the clutch cover..
But she drives the car and has some bad habits that are not clutch friendly ... But you just cant tell some people things.
So I was just looking for something that was just a better that stock..
Sorry to sound like a butt head just tired of problem
www.moparalley.org
Re: trow out bearing [Re: ramcuda] #1236267
05/20/12 09:22 PM
05/20/12 09:22 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Not being a smart a-- but someone driving a stick that either dosent know how to drive one or has bad habits you will always have problems.Only way to fix it is to teach them the correct way to drive,continually replace parts or not let them drive.I use Timken bearings and have never had any problems.Rocky
Chrysler Firepower
Re: trow out bearing [Re: therocks] #1236268
05/21/12 03:29 AM
05/21/12 03:29 AM
Santa Clara , ca
ramcuda Offline OP
ramcuda  Offline OP
Santa Clara , ca
thanks Rocks
www.moparalley.org
Re: trow out bearing [Re: ramcuda] #1236269
05/23/12 03:09 AM
05/23/12 03:09 AM
Santa Clara , ca
ramcuda Offline OP
ramcuda  Offline OP
Santa Clara , ca
Are all 18spline trans take the same TO bearing ?
I see the listing one listed for 440 with a 18 spline
and different one listed for Hemi with 18 spline
I know the Hemi trans have a bigger out put shaft..
so is there a way to tell which one i have with out pulling the trans ?
I think we have a Hemi 18 spline .. I didnt go to buy the first TO but i remember she came home with one that was for a 440 and it didnt fit ..
Again I know very little about 4 speeds ..
Again All
www.moparalley.org
Re: trow out bearing [Re: ramcuda] #1236270
05/23/12 08:09 AM
05/23/12 08:09 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Im 99% sure that Ma used onlt 2 bearings.One was for the 18 spline as they are Hemi boxes.The other is for the 23 spline.Last one I got from AZ had my buddy the parts guy order a Timken for me.It was like 40 bucks.It came in a nice dusty old box and has been in for 8 years.Rocky
Chrysler Firepower
Re: trow out bearing [Re: therocks] #1236271
05/23/12 06:09 PM
05/23/12 06:09 PM
Santa Clara , ca
ramcuda Offline OP
ramcuda  Offline OP
Santa Clara , ca
Thanks again Rock
I just chatted with Wayne and got the low down on 18spline TO ..
the hemi TO have a shorter sleeve .. but it is the same as the 440 18spline ..
So Im good now ... I like autos Sooooo much better ,,,LOL
www.moparalley.org
