fuel supply #1234368
05/16/12 12:54 PM
05/16/12 12:54 PM
Fairhope, Alabama
BeeSuper Offline OP
BeeSuper  Offline OP
Fairhope, Alabama
Any recommendations for a complete fuel system, tank to engine. 440-6 now but was 383. 5/16 line and original tank. Car is far from original so no concerns trying to stay factory. Would it be bad to eliminate the fuel tank and just install a fuel cell in the trunk, add electric pump and all new 3/8 plumbing? Any one tried the "bargain" Summit or Jeggs pumps or should I stay with name brand stuff?
Re: fuel supply [Re: BeeSuper] #1234369
05/16/12 01:19 PM
05/16/12 01:19 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Either get a cell or have a sump installed in your factory tank for fuel storage. I can't really tell you what size pump to get but use at least a 1/2" line with a return regulator (I wish I would have / I am currently running 3/8" line with a dead head reg). 3/8" line will probably be o.k. for you engine now but you know you will upgrade in the future and extra fuel is better than not enough. This is all coming from what the experts here have written.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: fuel supply [Re: bigsbigelow] #1234370
05/16/12 01:42 PM
05/16/12 01:42 PM
Fairhope, Alabama
BeeSuper Offline OP
BeeSuper  Offline OP
Fairhope, Alabama
Thanks for the info, the parts catalog is overwhelming with fuel supply options, it makes me dizzy.
Re: fuel supply [Re: BeeSuper] #1234371
05/16/12 02:00 PM
05/16/12 02:00 PM
bigsbigelow Offline
bigsbigelow  Offline
I know how you feel. As far the fuel pump goes, it seems that a lot of people use and like the Mallory 140 pump. I have a Quick Fuel brand pump but they don't make it any more. Any way, my pump is rated at 140 gph and I have a good feeling it is actually a "re-branded" Mallory 140.
Re: fuel supply [Re: bigsbigelow] #1234372
05/16/12 02:27 PM
05/16/12 02:27 PM
Fairhope, Alabama
BeeSuper Offline OP
BeeSuper  Offline OP
Fairhope, Alabama
I am leaning towards the Quick fuel also. Jeggs has one for $191 with 1/2" inlet/ outlet that flows 175gph with a few nice features. Now to find a bypass style regulator, a 1/2" pickup, lines, fittings, filter, clamps... Where does the money go?
Re: fuel supply [Re: BeeSuper] #1234373
05/16/12 03:38 PM
05/16/12 03:38 PM
bigsbigelow Offline
bigsbigelow  Offline
Earl's SS "Push-Lock" style fuel line is awesome, btw.
Re: fuel supply [Re: BeeSuper] #1234374
05/16/12 04:25 PM
05/16/12 04:25 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
fuel systems often come down to a matter of personal choice and imho most guys go overboard cause racers like crows are attracted to shiny stuff.
first thing you need to figure out is how much HP you intend to feed, then if you want to go electric or not.
i often use Dwayne Porters car as an example. afaik he had a completely stock fuel system with the exception of a carter high volume mechanical pump. this was the performance of that setup
11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs
personally if you wanted to run an electric pump on your car i would use a mallory 140 as i do not care for the sliding vane pumps, "bargains" rarely are a bargain. although it's more expense and work a return style system is the best. that said using Dwayne's car as an example you can see that a monster system is not required.
Re: fuel supply [Re: BeeSuper] #1234375
05/16/12 05:49 PM
05/16/12 05:49 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
What is the car used for? What car? 440/6 pak I would assume more for the street than the track?
A properly laid out system with a fuel cell for the street is expensive and takes a lot of knowledge for satisfactory street operation. A race system is different than a street system, imo.
Like smelling gas around your car...because the fuel cell is not vented right for storage in your garage.
A return line should be mandatory no matter what you wind up with. Good luck, take your time choosing and choose wisely.
Re: fuel supply [Re: Challenger 1] #1234376
05/16/12 05:54 PM
05/16/12 05:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I bought a Firecore 140 pump from Rick here on Moparts and it works great. Ron
Re: fuel supply [Re: Challenger 1] #1234377
05/17/12 02:52 PM
05/17/12 02:52 PM
Fairhope, Alabama
BeeSuper Offline OP
BeeSuper  Offline OP
Fairhope, Alabama
Thanks Guys for all the input. My plan is, street driven 500" stroker (because I have to build something). According to what I have read, 600-650 HP with Edelbrock performer heads, solid lift cam on the high side, a good rocker set up, (harland sharp), tti headers, MSD, and stock six pack intake. I wan't electric on the pump with a bypass regulator and return. Found out that I can change to larger pickup and use stock tank. I know 1/2 may be overkill but I have to redo the 5/16" old stuff any way, Should I just go with 3/8"(-6AN)? As far as the pump, I like the Aeromotive street /strip, the holley HP 150 or the edelbrock quiet flow. The holley comes with a regulator, I am assuming a "dead head type" not with a bypass/ return. Too many choices. The car is a 69 Bee, originally a 383, now all A-12.
Re: fuel supply [Re: BeeSuper] #1234378
05/17/12 02:59 PM
05/17/12 02:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Me personally, I would not want all of the extra plumbing going to the reg. then back to the cell so I would get a pump that bypasses directly to the cell instead. I chased my tail and et`s for years till Iinstalled a REAL pump like the Magnafuel 300 and my et`s dropped and I`d rather have TOO much fuel than not enuff...............A 140 pump w/a 500 in. motor?...........
Re: fuel supply [Re: Thumperdart] #1234379
05/17/12 03:09 PM
05/17/12 03:09 PM
Az
Crizila Offline
Crizila  Offline
Az
If you plan on staying in the 11 - 11.50 ET range, stock tank will work. Holley 150HP pump. 3/8" line to dead head regulator. -6 to carbs. Simple, not too costly, and will give you plenty of juice to run in the mid to low 11's. That set up will flow about 1 gallon in 30 seconds - measured at the carb inlet lines ( 2 -6 lines in my case).
Fastest 300
Re: fuel supply [Re: Crizila] #1234380
05/17/12 03:32 PM
05/17/12 03:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s fine IF you stay there but who does that......
Re: fuel supply [Re: BeeSuper] #1234381
05/17/12 04:01 PM
05/17/12 04:01 PM
bigsbigelow Offline
bigsbigelow  Offline
Something else I have been reading about is a fuel log setup with a return regulator regulating a "main" fuel supply line at a high pressure (20-30 lbs) with dead head regs branching off of the log for the motor and/or nitrous system. This system would need a good pump that can reach high pressures. The point is to try and eliminate pressure drops. I don't know if you plan on running spray but this may be another option you want to look into. I hope I haven't added more confusion.
Re: fuel supply [Re: Thumperdart] #1234382
05/17/12 04:42 PM
05/17/12 04:42 PM
Fairhope, Alabama
BeeSuper Offline OP
BeeSuper  Offline OP
Fairhope, Alabama
Thanks Guys. Will study all and try to make an informed decision. 11's sounds good, 10's sound better. I know there will always be bigger, better, badder, but I just gotta spank the stock late model stuff, especially those 5.0 Mustangs.
Re: fuel supply [Re: bigsbigelow] #1234383
05/17/12 04:47 PM
05/17/12 04:47 PM
Fairhope, Alabama
BeeSuper Offline OP
BeeSuper  Offline OP
Fairhope, Alabama
Sounds good. No spray, just motor. Had spray on previous street car, brand "x", for my use it was just too much hassle.
Re: fuel supply [Re: BeeSuper] #1234384
05/17/12 05:14 PM
05/17/12 05:14 PM
Middletown, Ohio
Joes66dart Offline
Joes66dart  Offline
Middletown, Ohio
We started off with a holey blue pump and 1/2" line to a holley regulator and two #6 to the carb. Car ran 11.70s. After chasing a fuel pressure problem for half a season we got smart and went to a BG400 pump #10 line to a product engineering regulator with two #8's to the carb and the car went 11.50's. We picked up 2 tenths just by changing fuel system and never had a fuel pressure issue again. The new system has enough flow to feed an 800 hp power bullet (not that I will ever have that much power but i got the fuel system to run it). We figured overkill was better than running out of fuel on the big end!
Re: fuel supply [Re: Joes66dart] #1234385
05/17/12 05:34 PM
05/17/12 05:34 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
For what it's worth I run a new factory style tank with a 3/8" supply and 5/16 return line and use an original style vapor separator and a carter "street" pump. It works just fine. I shift the car at 6k RPM on the street when I am having fun with it and it also made 400HP/420FT LBS at the wheels on a Chassis dyno. 470"/400 block stroker with a 950 carb. I have had no issues with it over the last 4 years and I do have a Carter strip 120gph pump new in the box if I ever need it. I believe Labratt runs a mechanical holley pump on his car and he is in the low 11's.
Re: fuel supply [Re: BeeSuper] #1234386
05/17/12 05:58 PM
05/17/12 05:58 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
i use a 140 mallory. magna fuel reg- dead headed. #10 line from sump to reg, #6 from reg to carb. no fuel problems. street/strip. about 700 ponies, runs 9.60 all day. no fuel issues what so ever.
Re: fuel supply [Re: rickraw] #1234387
05/17/12 07:39 PM
05/17/12 07:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What`s the car weigh?
