which rear anti sway bar??
#1234318
05/16/12 11:54 AM
05/16/12 11:54 AM
Posts: 11,079 Berlin, N.J.
abodyjoe
Berlin, N.J.
and why? which rear bar do you think is better and why? now sure which to buy. both are adjustable. think i kinda like the hotchkis mount better. just now sure which to go with. Hellwig 6907: http://www.summitracing.com/parts/HEL-6907/?rtype=10Hotchkis 22385R: http://www.summitracing.com/parts/HSS-22385R/ its going into a 70 small block dart. front end is going to be an alter-k-tion with i forget what size bar it has. primary use will be spirited street use and maybe one day i'll get it to vineland and let the ole lady make some laps in it. . rear springs are going to be espo stock height 6 leaf.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
Re: which rear anti sway bar??
[Re: abodyjoe]
#1234321
05/16/12 01:50 PM
05/16/12 01:50 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
welding isn't a problem.
kinda like the way the welded bracket mounts over the other. there is $60 between them. not a big deal. think one will work better then the other? or is there a better option out there that i don't know about?
I think both will function fine.
Another option is the Firm Feel one. It does not have adjustablity. But it is frame mounted. That may help, not help, or make no difference to your exhaust tailpipe clearance. Most of the time it doesn't make a difference with 2 1/2 or under stock routed pipe.
[Re: abodyjoe]
#1234322
05/16/12 02:00 PM
05/16/12 02:00 PM
Posts: 31,050 Oregon
AndyF
Take a look at the Firm Feel bar. www.firmfeel.comThey can make it adjustable if that is what you want.
[Re: abodyjoe]
#1234323
05/16/12 02:15 PM
05/16/12 02:15 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Well Joe just an FYI on the Hellwig, its actually a 3/4" bar not 1". Summit just has it twisted. Im not even sure the Hotchkis is 1" but either way if I had to bet id bet on the Hellwig being lighter. And if you punch in that part # to Amazon you will save a bunch on that Hellwig. I found my Hellwig 6908, which is an Ebody rear bar but still works on an A body and is 7/8" instead of 3/4", for $140 shipped on Amazon. Oh another thing is the Hellwig end links mount to the inside of the frame rails so they work with my car having the springs moved in 3" per side.
Mopar to the bone!!!
[Re: 72Swinger]
#1234324
05/16/12 02:39 PM
05/16/12 02:39 PM
autoxcuda
So Cal
...Im not even sure the Hotchkis is 1" but either way if I had to bet id bet on the Hellwig being lighter. ...
The Hellwig is solid and Hotchkis is hollow. I think they are both 3/4". The Hotchkis will be lighter.
This is a Hotchkis rear sway bar:
[Re: autoxcuda]
#1234326
05/16/12 02:55 PM
05/16/12 02:55 PM
abodyjoe
Berlin, N.J.
yea i believe they are both 3/4". kinda like the way the hotchkis attaches to the frame over the hellwig. think i like how the firm feel mounts even better.
[Re: autoxcuda]
#1234327
05/16/12 02:58 PM
05/16/12 02:58 PM
72Swinger
Nebraska
Steve just weighed the E body Hellwig bar and its 9 lbs and feels like its solid to me.
[Re: AndyF]
#1234328
05/16/12 03:10 PM
05/16/12 03:10 PM
moparAL
Take a look at the Firm Feel bar. www.firmfeel.comThey can make it adjustable if that is what you want. Firm Feel makes nice products but when you talk about a adjustable swaybar, Firmfeel told my friend they can be adjustable by throwing in some softer end link bushings, Come on, YEA... ADJUSTABLE! Correct me if I am wrong. I did that with the factory rear bar 33 years ago when I bought my E body in 1979. Made no difference. When you say adjustable the HOTCHKIS and HELLWIG are TRUELY ADJUSTABLE. If you want to pedal the adjustable feature, do it the correct way, redesign the bar!
