SB racing water pump #1234238
05/16/12 01:12 AM
05/16/12 01:12 AM
Kansas
Burnincircles Offline OP
Kansas
Where is the best place to get a gasket that fits the p4876548 SB racing water pump? We had been getting parts from Gaerte, but cant get ahold of them for some reason. I tried Mancini and Hughes. Gonna try Stanton tomorrow. Any other suggestions? THANKS, Bob P.
Re: SB racing water pump [Re: Burnincircles] #1234239
05/16/12 01:22 AM
05/16/12 01:22 AM
Kansas
Kansas
Does anybody have a part number for the gasket?
Re: SB racing water pump [Re: Burnincircles] #1234240
05/16/12 02:21 AM
05/16/12 02:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Is this pump the one for the short deck R block...
all I use is the Mopar black RTV
Re: SB racing water pump [Re: MR_P_BODY] #1234241
05/16/12 09:52 AM
05/16/12 09:52 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Honestly, the last set I recieved on my Proform small block pump turned to mush when the coolant hit them. I had to pull the plate and the pump all back off thinking the rtv was leaking, and it was the gaskets, not the rtv...Now I have blue rtv on it, and no gaskets and no leaks. I wasn't able to order any either when I tried to order some from Hughes. They were out and they said for some time they haven't had any.
Re: SB racing water pump [Re: Dragula] #1234242
05/16/12 10:03 AM
05/16/12 10:03 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
If it is a good flat machined surface, couldnt you use anerobic sealer and no gasket. That stuf is GREAT as long as it is very flat and clean.
Re: SB racing water pump [Re: MR_P_BODY] #1234243
05/16/12 10:05 AM
05/16/12 10:05 AM
Kansas
Kansas
Mr P, I believe this pump could be used on any cast iron block, but you must use the aftermarket "sand cast" front cover. This one is on an aluminum block. It is a Zeus Casting. Mancini said they are discontinued. I was hoping that someone might have one on their shelf. I would prefer a gasket, but it sounds like RTV might be the way to go... THANKS, Bob P.
Re: SB racing water pump [Re: Burnincircles] #1234244
05/16/12 11:12 AM
05/16/12 11:12 AM
K
Kiddart Offline
Kiddart  Offline
K
dont believe everything mancini tells you!! they told me that milodon was discontinuing the one piece oil pan gasket for a 360 block, called milodon and they said no such thing that it was discontinued!! call around heck try jegs or sumit?
Thank you
Kiddart
Re: SB racing water pump [Re: Burnincircles] #1234245
05/16/12 07:11 PM
05/16/12 07:11 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Burnincircles I have a couple different water pump gaskets.
Is this what you are looking for?
Re: SB racing water pump [Re: roadhazard] #1234246
05/16/12 11:58 PM
05/16/12 11:58 PM
Kansas
Kansas
That does appear to be the correct gasket. I would be interested in purchasing one. How can I get ahold of you?
Re: SB racing water pump [Re: Burnincircles] #1234247
05/17/12 12:22 PM
05/17/12 12:22 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Toll Free 1-866-925-7855
Glad to be able to help
Re: SB racing water pump [Re: roadhazard] #1234248
05/17/12 03:47 PM
05/17/12 03:47 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Get two.
They can't be too expensive and next time , you'll have one on hand.
