2 hook up distributor? #1233865
05/15/12 03:15 PM
05/15/12 03:15 PM
michigan
cudamvw Offline OP
cudamvw  Offline OP
michigan
hi,
putting together a basic 318 '74 vintage. i have a 4145753 distributor from 80-84, no vac advance. it also has 2 separate plug-ins. will this work in my '74? or should i get another?
thanks Moparts!
1970 Challenger convertible 1971 Barracuda convertible 1971 Sebring Plus sunroof X2
Re: 2 hook up distributor? [Re: cudamvw] #1233866
05/15/12 03:19 PM
05/15/12 03:19 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
don't know anything about small blocks but i do know if it does fit, without vac adv on the street it will be very doggish. i'd ditch it.
Re: 2 hook up distributor? [Re: cudamvw] #1233867
05/15/12 03:28 PM
05/15/12 03:28 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
That is a distributor from a car with LEAN BURN , I don't think it has any mechanical advance. Don't try to use it .
Re: 2 hook up distributor? [Re: JohnRR] #1233868
05/15/12 05:54 PM
05/15/12 05:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yep sounds like its the one with 2 pick-up coils that they used a few years on lean burn. Get another dist for sure. Ron
Re: 2 hook up distributor? [Re: 383man] #1233869
05/16/12 08:37 AM
05/16/12 08:37 AM
michigan
cudamvw Offline OP
cudamvw  Offline OP
michigan
thanks for all the replies. that's what i was afraid of. Thanks for the advice.
