TTI exhaust systems.any good #1233438
05/14/12 07:33 PM
05/14/12 07:33 PM
sw michigan
TB3CUDA Offline OP
TB3CUDA  Offline OP
sw michigan
has anyone bought one of the TTI exhaust systems?i am looking at buying one for my 72 roadrunner with headers.notice the kit listed is for 71-74 b-bodys,all engines and tranny combos.how is the fit and ease of putting it on,any mods had to be done?also looking to cut it for the machine gun tips i have.
Re: TTI exhaust systems.any good [Re: TB3CUDA] #1233439
05/14/12 07:41 PM
05/14/12 07:41 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run the TTI 2" headers and the full 3" exh system out to the rear bumber. I went with the X-pipe and it fit great and was simple to install. Ron
Re: TTI exhaust systems.any good [Re: 383man] #1233440
05/14/12 08:27 PM
05/14/12 08:27 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
x2, .
Re: TTI exhaust systems.any good [Re: lewtot184] #1233441
05/14/12 08:46 PM
05/14/12 08:46 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I've installed them on e-bodies before and they fit better than any premade system I've used.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: TTI exhaust systems.any good [Re: Silver70] #1233442
05/14/12 09:24 PM
05/14/12 09:24 PM
Waterford, MI
JAK Offline
JAK  Offline
Waterford, MI
I installed the 2" ceramic coated headers with 3" X pipe exhaust on my 72 Roadrunner with a 4 speed. Fit is awesome. I am running the Indy Cylinder Heads "SR" heads and a mini starter. If I remember correctly I did have to trim the X pipe length like 3". Make sure you follow TTI's recommendation (coating headers with WD40) when storing your car for an extended amount of time.
Re: TTI exhaust systems.any good [Re: JAK] #1233443
05/14/12 09:31 PM
05/14/12 09:31 PM
IN
ahy Offline
ahy  Offline
IN
I run the 2" system with X pipe on an E. The system was well made and fit was good.
Re: TTI exhaust systems.any good [Re: ahy] #1233444
05/15/12 12:38 AM
05/15/12 12:38 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
2" TTI headers, 3" H pipe system on a '65 Belvedere. Installed everything in my garage with no dinging or swearing. Amazingly good fit.
Re: TTI exhaust systems.any good [Re: Ramrod39] #1233445
05/15/12 12:52 AM
05/15/12 12:52 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I have 3 TTI systems the only thing to complain about is the cost. Quality and fit is good to great. The coating on my headers is failing though.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: TTI exhaust systems.any good [Re: HemiRick] #1233446
05/15/12 01:42 AM
05/15/12 01:42 AM
Dexter, Michigan
copper67440 Offline
mopar addict
copper67440  Offline
mopar addict
Dexter, Michigan
Just put a 3" with an X on my Coronet. It fits really nice. I had to cut and reweld the left side header adaptor, but when i got that figured out it all fit. I have Dynomax Super Turbo mufflers and I love the way it sounds. Absolutly no drone inside. Very satisfied.
Re: TTI exhaust systems.any good [Re: copper67440] #1233447
05/15/12 02:17 AM
05/15/12 02:17 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I think its the best off-the-shelf system you can buy, I have the 3" on my Duster and its excellent with high quality hangers. Only way to get better would be to pay a skilled pipe bender to make one to exactly fit your car.
Ride eternal, shiny and chrome
Re: TTI exhaust systems.any good [Re: TB3CUDA] #1233448
05/15/12 07:55 AM
05/15/12 07:55 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
One of my TTI systems is 14 years old now and still turns heads and don't leak.
Drove it to work today!
Re: TTI exhaust systems.any good [Re: TB3CUDA] #1233449
05/15/12 10:43 AM
05/15/12 10:43 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
No one has answered this part of your question which is HUGE , those that do not have a 1971-74 B body with machine gun tips , I'm sure your replies are appreciated but your answers do not help.
I partially installed a tti system on a 72 satellite , I went by the included instructions and drilled the floor pan for the rear hangers behind the muffler wheere tti wants them, it didn't use the factory mount above the rear axle that the car originally had, I can't remember if there were dimples on the floor for the drivers side mount as I did it a few years ago.
The car didn't have tips, the owner wanted to install them but that hasn't happened yet.
And to jump on the I have tti pipes on a car that does not answer your question bandwagon ....
1969 Dodge Dart with 2.5" pipes, fit like TOTAL CRAP ... actually they didn't really fit I had to cut them up to make them fit, it would have been cheaper to do a mandrel bend pipe from scratch ...
My car has original dual exhaust and I wanted to reuse my stock tips, the pipes did NOT exit in the same place as stock AND the pipes did NOT connect to mufflers located off the stock rear muffler hangers. tti does not make a headpipe for a factory big block A body so I had to have my own made up and tti has you mount their GINORMOUS hangers off the seat belt bolts instead of the stock hanger locations ....
Re: TTI exhaust systems.any good [Re: TB3CUDA] #1233450
05/15/12 10:51 AM
05/15/12 10:51 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
expensive but a great fit
Re: TTI exhaust systems.any good [Re: TB3CUDA] #1233451
05/15/12 11:27 AM
05/15/12 11:27 AM
Shoreline, Washington
72roadrunnergtx Offline
I’m running 3” X-pipe TTI system with tips on my 72’ RR/GTX, exhaust system fits well but as mentioned does not use some of the hangers originally used. Besides the need to add a floor mounted muffler hanger brackets as needed, the tail pipes have hanger tabs using a factory style tail pipe hanger forward of where the factory tips/hangers would locate. TTI’s repo tips don’t have hanger tabs and are designed to clamp to their “cut off” turn down tail pipes. The tips exit in the same position as the originals and will require a cut out or modified rear valance to fit perfectly. Other repo tips matching whatever pipe size tail pipe should work as well, may have to choose which hanger configuration. I’m planning to add some resonators to mine after recently going back to manifolds and will be reworking my tips and hangers to accommodate them.
Re: TTI exhaust systems.any good [Re: 72roadrunnergtx] #1233452
05/15/12 12:12 PM
05/15/12 12:12 PM
JohnRR Offline
JohnRR  Offline
What changes had to be made to the rear valance , I assume your valance was cut for tips ?
Re: TTI exhaust systems.any good [Re: JohnRR] #1233453
05/15/12 12:22 PM
05/15/12 12:22 PM
Valance pictured is an original non-cut-out, the cut-out valance that came with the car was too beat-up. Basically traced and transferred the cutout with flare to the non-cut valance. My point is using a valance without cut-outs or clearance mods of somekind will have the TTI tailpipe and tips contacting the rear valance without modifying the way they hang, out of the box.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: TTI exhaust systems.any good [Re: 72roadrunnergtx] #1233454
05/15/12 01:04 PM
05/15/12 01:04 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
Here is a full TTI setup on a 72RR/GTX..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: TTI exhaust systems.any good [Re: 72N96RR] #1233455
05/15/12 01:05 PM
05/15/12 01:05 PM
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
ANOTHER...no rattles..excellent sound...one of the best set ups I have seen in decades..
Re: TTI exhaust systems.any good [Re: 72roadrunnergtx] #1233456
05/15/12 01:35 PM
05/15/12 01:35 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Wow,,...Im surprised..
Usually when a post about TTI comes up, people camplain that it wasnt 50 bucks and didint jump out of the box and install itself.
Great stuff, very well made and excellent customer service.
MB
Re: TTI exhaust systems.any good [Re: 72N96RR] #1233457
05/15/12 01:41 PM
05/15/12 01:41 PM
Hey Jim,
Are you running tips or turn downs? Are those the 2” primary headers? Have you run into any ground clearance problems at the collectors or the adapter pipes? It does appear you may be running a little higher ride height than I am currently.
"Great stuff, very well made and excellent customer service."
Couldn't agree more.
