Re: TTI exhaust systems.any good
[Re: 383man]
#1233440
05/14/12 08:27 PM
05/14/12 08:27 PM
Posts: 3,916 usa
lewtot184
usa
I run the TTI 2" headers and the full 3" exh system out to the rear bumber. I went with the X-pipe and it fit great and was simple to install. Ron
x2, .
[Re: lewtot184]
#1233441
05/14/12 08:46 PM
05/14/12 08:46 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I've installed them on e-bodies before and they fit better than any premade system I've used.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Ramrod39]
#1233445
05/15/12 12:52 AM
05/15/12 12:52 AM
Posts: 4,848 Memphis
HemiRick
Memphis
I have 3 TTI systems the only thing to complain about is the cost. Quality and fit is good to great. The coating on my headers is failing though.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: copper67440]
#1233447
05/15/12 02:17 AM
05/15/12 02:17 AM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
I think its the best off-the-shelf system you can buy, I have the 3" on my Duster and its excellent with high quality hangers. Only way to get better would be to pay a skilled pipe bender to make one to exactly fit your car.
Ride eternal, shiny and chrome
[Re: TB3CUDA]
#1233449
05/15/12 10:43 AM
05/15/12 10:43 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
has anyone bought one of the TTI exhaust systems?i am looking at buying one for my 72 roadrunner with headers.notice the kit listed is for 71-74 b-bodys,all engines and tranny combos.how is the fit and ease of putting it on,any mods had to be done?also looking to cut it for the machine gun tips i have.
No one has answered this part of your question which is HUGE , those that do not have a 1971-74 B body with machine gun tips , I'm sure your replies are appreciated but your answers do not help.
I partially installed a tti system on a 72 satellite , I went by the included instructions and drilled the floor pan for the rear hangers behind the muffler wheere tti wants them, it didn't use the factory mount above the rear axle that the car originally had, I can't remember if there were dimples on the floor for the drivers side mount as I did it a few years ago.
The car didn't have tips, the owner wanted to install them but that hasn't happened yet.
And to jump on the I have tti pipes on a car that does not answer your question bandwagon ....
1969 Dodge Dart with 2.5" pipes, fit like TOTAL CRAP ... actually they didn't really fit I had to cut them up to make them fit, it would have been cheaper to do a mandrel bend pipe from scratch ...
My car has original dual exhaust and I wanted to reuse my stock tips, the pipes did NOT exit in the same place as stock AND the pipes did NOT connect to mufflers located off the stock rear muffler hangers. tti does not make a headpipe for a factory big block A body so I had to have my own made up and tti has you mount their GINORMOUS hangers off the seat belt bolts instead of the stock hanger locations ....
[Re: 72roadrunnergtx]
#1233452
05/15/12 12:12 PM
05/15/12 12:12 PM
JohnRR
I’m running 3” X-pipe TTI system with tips on my 72’ RR/GTX, exhaust system fits well but as mentioned does not use some of the hangers originally used. Besides the need to add a floor mounted muffler hanger brackets as needed, the tail pipes have hanger tabs using a factory style tail pipe hanger forward of where the factory tips/hangers would locate. TTI’s repo tips don’t have hanger tabs and are designed to clamp to their “cut off” turn down tail pipes. The tips exit in the same position as the originals and will require a cut out or modified rear valance to fit perfectly. Other repo tips matching whatever pipe size tail pipe should work as well, may have to choose which hanger configuration. I’m planning to add some resonators to mine after recently going back to manifolds and will be reworking my tips and hangers to accommodate them.
What changes had to be made to the rear valance , I assume your valance was cut for tips ?
#1233454
05/15/12 01:04 PM
05/15/12 01:04 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
Here is a full TTI setup on a 72RR/GTX..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: 72N96RR]
#1233455
05/15/12 01:05 PM
05/15/12 01:05 PM
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
ANOTHER...no rattles..excellent sound...one of the best set ups I have seen in decades..
#1233456
05/15/12 01:35 PM
05/15/12 01:35 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Wow,,...Im surprised.. Usually when a post about TTI comes up, people camplain that it wasnt 50 bucks and didint jump out of the box and install itself. ![](/ubbthreads/images/graemlins/laugh2.gif) Great stuff, very well made and excellent customer service. ![](/ubbthreads/images/graemlins/thumbs.gif) MB
