Camshaft plate (rear) install question (360) #1232908
05/13/12 06:46 PM
05/13/12 06:46 PM
central CT
cudazappa Offline OP
central CT
I have a convex piece of metal that goes in the rear of the block behind the camshaft. How does it get installed? Its rather loose in the bore. Do I put it in convex till it bottoms out and hit it with a hammer? Or should it be tight fitting and I should be tapping it in (concave looking at it).
I have 2 of them and they're both this way (Fel-Pro)
1971 Challenger
Re: Camshaft plate (rear) install question (360) [Re: cudazappa] #1232909
05/13/12 08:01 PM
05/13/12 08:01 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Put it in the bore with a LITTLE silicone around the edges and smack it with hammer. It'll expand out and fit tight in the block.
Re: Camshaft plate (rear) install question (360) [Re: Challenger 1] #1232910
05/15/12 01:05 AM
05/15/12 01:05 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
My machinist and the experienced fellow that helped me do the rotating assemble both did not like that thing one bit, had me go and get the one that looks a lot like a standard expansion plug, only with a narrow lip.He put them all in with permatex #2 also.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
