489 Sure Grip thrust buttons #1232810
05/13/12 02:25 PM
05/13/12 02:25 PM
hickory nc USA
skyhawk61 Offline OP
hickory nc USA
I just purchased a used 489 case 8 3/4 Sure Grip unit; how can I tell if the thrust buttons are in it? Thanks. DC
Re: 489 Sure Grip thrust buttons [Re: skyhawk61] #1232811
05/13/12 02:30 PM
05/13/12 02:30 PM
Kirkland, Washington
Pacnorthcuda Offline
Can you see all the way through the unit? (where the axle shafts go)
Re: 489 Sure Grip thrust buttons [Re: Pacnorthcuda] #1232812
05/13/12 02:46 PM
05/13/12 02:46 PM
hickory nc USA
hickory nc USA
No, I cannot see all the way through it. I can see what appears to be two shiny discs with a circular wear pattern in the centers. DC
Re: 489 Sure Grip thrust buttons [Re: skyhawk61] #1232813
05/13/12 02:50 PM
05/13/12 02:50 PM
central pa
darted1 Offline
darted1  Offline
central pa
those should be the thrust buttons.
ED M
Re: 489 Sure Grip thrust buttons [Re: darted1] #1232814
05/13/12 02:56 PM
05/13/12 02:56 PM
hickory nc USA
hickory nc USA
Thanks for your help. You know, all these years I've spent knocking around Mopars, I'd never looked into the axle well area of a Sure Grip 8 3/4. DC
Re: 489 Sure Grip thrust buttons [Re: skyhawk61] #1232815
05/13/12 04:20 PM
05/13/12 04:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the 489 has its original cone-type Sure-Grip there are no individual thrust buttons...there is a one-piece thrust block.
