B/E exhaust manifolds on a 67 C body? #1232229
05/12/12 06:07 PM
05/12/12 06:07 PM
Connecticut
biginchmotor Offline OP
Connecticut
I have a 67 Fury that I am working on. I need a set of exhaust manifolds as the originals are long gone. 440 car. Not concerned about original this or that, just thinking if someone has tried a set of B or E exhaust manifolds on their C body. Car has power steering. Thanks John.
Re: B/E exhaust manifolds on a 67 C body? [Re: biginchmotor] #1232230
05/12/12 07:05 PM
05/12/12 07:05 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
The passenger sides are configured the same, so any B body manifold HP or not should work fine.
The left side manifolds are different. B body manifolds CAN work in a c body but it puts the outlet very close the steering column and requires a tight bend.
C body HP manifolds aren't hard to find. I believe there's some in the engine classifieds here right now.
Re: B/E exhaust manifolds on a 67 C body? [Re: 440newport] #1232231
05/12/12 09:56 PM
05/12/12 09:56 PM
Connecticut
Connecticut
Thanks for the reply, are the C body exhaust manifolds specific to C body cars? Any part numbers to look for in particular? Thanks John.
Re: B/E exhaust manifolds on a 67 C body? [Re: biginchmotor] #1232232
05/12/12 11:18 PM
05/12/12 11:18 PM
440newport Offline
440newport  Offline
I'm not an expert on these, but I know the driver side is. I don't know all the part numbers but the most common left HP manifold is 2863409.
Re: B/E exhaust manifolds on a 67 C body? [Re: 440newport] #1232233
05/12/12 11:28 PM
05/12/12 11:28 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Right side manifold is the same. I put a pair of b-body manifolds in my old 69 Polara. The only problem was the head pipes I had didn't fit the "C" real well, but if you have a muffler shop make them up, you'll be fine.
Re: B/E exhaust manifolds on a 67 C body? [Re: biginchmotor] #1232234
05/13/12 08:54 AM
05/13/12 08:54 AM
Andrews,In. U.S.of A.
67_Satellite Offline
Ran the high perf. B body manifolds in a 66 Newport for years. As stated, the driver side needed a fabricated head pipe ,there won't be a factory repop to fit. Local muffler shop had no problem making one. The bend wasn't really all that tight to make it clear,and I doubt it cost much power if any. It was nowhere near as tight a restriction as an A body manifold has in the manifold itself.
Re: B/E exhaust manifolds on a 67 C body? [Re: 67_Satellite] #1232235
05/13/12 08:59 PM
05/13/12 08:59 PM
Central NC
gch Offline
gch  Offline
Central NC
I have a C body drivers side HP manifold I will likely never use.Shipping sucks as they are heavy but if you want it let me know and we can work something out.
