2005 Dodge Ram idle problems #1231567
05/11/12 10:38 AM
05/11/12 10:38 AM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
I have a 2005 Dodge Quad cab pickup truck with a 4.7 engine.The problem is at idle.When cold or hot the idle will vary from 600 rpm to 900 rpm.When cold it will sometimes go as high as 1100 rpm.When in gear I can feel it surging up and down.What causes this?Also it seems to be using a lot of gas lately.As always,Thanks for any replies.
Re: 2005 Dodge Ram idle problems [Re: 5carguy] #1231568
05/11/12 07:47 PM
05/11/12 07:47 PM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
I would start by cleaning out the throttle body and check the plugs too
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: 2005 Dodge Ram idle problems [Re: sreinheimer] #1231569
05/11/12 08:54 PM
05/11/12 08:54 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
I would also take a look at the tps.
Re: 2005 Dodge Ram idle problems [Re: mod381] #1231570
05/11/12 08:56 PM
05/11/12 08:56 PM
md
mopars4ever Offline
mopars4ever  Offline
md
My ram idled weird and it was due to a weak battery.
Re: 2005 Dodge Ram idle problems [Re: sreinheimer] #1231571
05/12/12 10:27 AM
05/12/12 10:27 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Remove the throttle body and remove the IAC motor and clean all the ports. If you haven't yet, replace the spark plugs. Those 4.7L eat spark plugs. They NEED changed every 30k. The electrodes wear off fast. When you remove the coils make sure you clean them and apply some dielectric grease around the outside where it contacts the head and small dab inside for the spark plug.
