Hemi hard start problem #1230897
05/10/12 09:28 AM
05/10/12 09:28 AM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
If my stock 68 Hemi sits for longer than a week, its very hard to start. Lots of cranking and pumping to, I think, refill the float bowls. Is this due to the garbage ethanol enriched fuel we are getting at the pumps these days?? Does this gas evaporate that fast? If I start the car every 4 or 5 days , its fine. Just curious if anyone else is experiencing this problem with pump gas? If so, any solutions??
thanks
Re: Hemi hard start problem [Re: hemi67] #1230898
05/10/12 09:37 AM
05/10/12 09:37 AM
new york
badsixpack Offline
badsixpack  Offline
new york
I have the same problem even with c12 racing fuel. I have no idea what it is, and am tired of chasing my tail. I just spray a little gas in the carbs and it starts right up,no big deal
Re: Hemi hard start problem [Re: badsixpack] #1230899
05/10/12 09:48 AM
05/10/12 09:48 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Its a very common problem so more than likely the answer is yes, it's todays fuel. Fix? Electric fuel pump will usually reduce the start up time to a minimum. Not the best choice if trying to keep everything 100% stock but it works.
Re: Hemi hard start problem [Re: ScottSmith_Harms] #1230900
05/10/12 11:25 AM
05/10/12 11:25 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
It's today's fuels. You didn't have this problem twenty years ago. I take the air cleaner off and use a small bottle of fuel to pour a bit into the carb vent tubes. I don't want the non-stock look of an electric fuel pump.
Sheldon
Re: Hemi hard start problem [Re: RUNCHARGER] #1230901
05/10/12 12:06 PM
05/10/12 12:06 PM
California
mickm Offline
mickm  Offline
California
same here. if it's been about a week, it fires right up in the first few cranks. anything after that and it almost fires and stumbles out, and then takes a lot of cranking.
so, like everyone else, i just pour a little fuel down each carb and go.
Re: Hemi hard start problem [Re: mickm] #1230902
05/10/12 12:26 PM
05/10/12 12:26 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
That isn't a problem specific to Hemis, pretty much anything with a carburetor and a mechanical fuel pump these days has similar issues. It's especially common with winter grade fuel in the spring/summer. If my D100 sits for more than a week I dump a tiny bit of gas down the carb throat, it's usually enough for it to stay running until the float bowl fills up.
Re: Hemi hard start problem [Re: Blusmbl] #1230903
05/10/12 12:38 PM
05/10/12 12:38 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
same problem here - one way to check is to pull the air cleaner and check for a pump shot before cranking.
I am installing a small primer pump this weekend.
Re: Hemi hard start problem [Re: SSAAHemiFan] #1230904
05/10/12 03:18 PM
05/10/12 03:18 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
Thanks for your help guys. I wouldn`t mind the addition of an electric pump as long as I could hide it out of sight and its not too loud. some of them are really noisy.
Re: Hemi hard start problem [Re: hemi67] #1230905
05/10/12 04:05 PM
05/10/12 04:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
it will definitely be out of sight because you have to install it back at the fuel tank pickup point , above the axle is the best place , try to get one that doesn't need a regulator.
Re: Hemi hard start problem [Re: hemi67] #1230906
05/10/12 04:41 PM
05/10/12 04:41 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
If you suspect the fuel, spike it with some 'real' gasoline...
Re: Hemi hard start problem [Re: RSNOMO] #1230907
05/10/12 06:53 PM
05/10/12 06:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
First one has to find REAL gasoline .
