Re: Should you be able to trust your engine builder?
[Re: Al_Alguire]
#1230185
05/09/12 12:27 PM
05/09/12 12:27 PM
Posts: 12,015 Finally a HUSKER again
Moparnut426
If you are paying your hard earned money to an engine builder for a complete ready to go engine I would expect that things are machined and assembled correctly. In this case that is not what happened. Parts failures happen, but errors and damaged parts caused from incorrect machining, or incorrect assembly or lack of attention to detail are unacceptable. I know when we do work for customers if it is not right we make it right, at the agreed cost. Even if that means we do not make any money on the job. Right is right period.
T add to this, If you have a hired hand who does sub par work, and you as an owner dont have the time to double check everything thats done by your help, and you cant trust them its bye bye time for any workers not trusted. Hard to do, but needs to happen. Your name is on the work.
[Re: 408strokerdart]
#1230186
05/09/12 12:27 PM
05/09/12 12:27 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
This is not at all a slam at you,or at Shady Dell,but have you called him and tried to work out something? Just curious,as many guys seem to come on and slam someone before resolving the issue another way. I would hope/expect him to at least try to help you out IF you followed any instructions he gave you for break in and maintenence. The main broblem I have with the deal is that you stated he ran in an engine and sent it out but never qualified it on his dyno? I know a lot of home built engines are done that way but anybody that builds engines for a living I would think would qualify one before letting it out the door. Just curious. Keith
[Re: Dunnuck Racing]
#1230187
05/09/12 12:57 PM
05/09/12 12:57 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
The same thing has happened to me with a well known builder also.I just changed builders and have been very happy with him.
Who is building your stuff now if you mind me asking?
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: Moparnut426]
#1230188
05/09/12 01:02 PM
05/09/12 01:02 PM
Posts: 3,456 Out West
408strokerdart
Out West
To answer the origional question, Yes, like you would trust your wife or family. As for what happened, WOW, just wow. Sorry to hear about that man. I know there are plenty out here who will tell ya to check and double check anyones work, but a complete and assembled engine that went south in 50 passes, thats sub par in so many ways.
Hope Ryan steps up and helps ya out on this one.
Im sure you dont want a complete refund as this is racing and schiat does happen, but I would think something refunded would come about.
Sorry man, that sucks big time!!
Not looking for any help.....I already bent over for the repairs. The repair work was done right and at a reasonable cost. I am only reporting facts.
#1230190
05/09/12 01:13 PM
05/09/12 01:13 PM
408strokerdart
Out West
Keith
I appreciate your post Keith. The issues that made this bullet self destruct would not have been seen with 3 or 5 dyno pulls.
I've stated this several times and will only post facts. If someone wants to use this information in their decision making, then great....if not, good luck to them.
I will not return my parts to someone (even on their dime) if they already proved they couldn't get it right the first time. These fundamental errors were there from the start.
If you had a fender bender with your red car and the bodyshop repaired it and painted it blue how much faith would you have in them to do it again? Even after they explained how "pretty" the blue was.
[Re: FASTFISH420]
#1230191
05/09/12 01:15 PM
05/09/12 01:15 PM
408strokerdart
Out West
I will be doing the assembly, but have someone else doing the heads/cam package. I should have everything back in my hands within a week.
[Re: Jeepmon]
#1230192
05/09/12 01:19 PM
05/09/12 01:19 PM
408strokerdart
Out West
Accidents and oversights is going to happen.. doesnt matter who you are and what your reputation is..
IMO what most important is those that stand up and take responsibility when they do screw up.. I'd like to know what Shady Dell has said to you about this mishap..
I have not contacted the shop. I know myself to well as to the action I might take if the result was not satisfactory so I choose not to. There is no excuse for the mistakes made. Looks like a high schooler put it together, only with parts he couldn't afford himself.
#1230193
05/09/12 01:28 PM
05/09/12 01:28 PM
Dunnuck Racing
Northern Indiana
I appreciate your post Keith. The issues that made this bullet self destruct would not have been seen with 3 or 5 dyno pulls. I understand what you are saying,but a lot of problems with valvetrain can be found on a dyno that you won't see or feel at the track. That,and he should have had a pretty good idea of how the engine should have run as far as power and tq. curves go,and been able to see an issue before it became a major problem. Just an opinion,but am really sorry to see anybody have major issues. Yes everybody makes mistakes,myself included. It is how we handle these mistakes that seperate us. Keith
#1230194
05/09/12 01:33 PM
05/09/12 01:33 PM
BradH
Are you saying that you haven't even contacted Ryan about this now-public issue and his first knowledge of it will probably be reading it on here?
#1230196
05/09/12 01:58 PM
05/09/12 01:58 PM
Posts: 1,178 Indy
FlyFish
Indy
If you are just stating facts, then please get your own story strait:
https://board.moparts.org/ubbthreads/show...part=1&vc=1
When did you check the lash prior to discovering this?
About 40 passes ago.
At the top of this post you claim to lash your valves ~ every 20 passes.
Everyone makes mistakes, sometimes BIG mistakes, it is how they are dealt with that matters more to me. The fact that you have not even contacted the builder (Shady Dell) and decided to trash them publicly is VERY poor form indeed. Give the man a chance to at least TRY to set things right....there are usually 2 sides to a story.
[Re: BradH]
#1230197
05/09/12 02:08 PM
05/09/12 02:08 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
I think what the OP is saying is that the mistakes made are just flat stupid, and the fact the motor was put together like that seriously undermines the OP's ability to trust anything the builder could do to make things right. I had issue as well with the same builder over several different things with work i had done, but its water under the bridge now.
I give the OP a ton of credit for correctly pointing out what he did.
[Re: FlyFish]
#1230198
05/09/12 02:09 PM
05/09/12 02:09 PM
Moparnut426
I agree about contacting him prior to posting, but this dude isnt worried about sending his stuff back to someone who messed it up in the first place, If he was worried about the cost, which he dosnt seem to be, then take it back to the origional guy. But in this case, he is PISSED, and just wants a running engine again. As for seeing what Ryan will do about it, thats up to him and the customer. I havent seen a peep out of Ryan in a while, I dont know if we will hear anything on this post from him either.
[Re: Moparnut426]
#1230199
05/09/12 02:23 PM
05/09/12 02:23 PM
Posts: 5,080 organ
maximum entropy
organ
there is nothing more frustrating than not being given the opportunity to make something right. this whole thing smells a little funny to me.
[Re: maximum entropy]
#1230200
05/09/12 02:35 PM
05/09/12 02:35 PM
Posts: 1,418 Mcallen, TX
SB449VALIANT
Mcallen, TX
Danggg! This is all bad, i know Ryan pretty good, just call him, thats the best 3 words that i can say......
#1230201
05/09/12 02:35 PM
05/09/12 02:35 PM
B3422W5
Portage,michigan
I dont have a dog in this fight but understand the OP's fellings well.
I own a car dealership and sold a lady a car. It was high milegae and was sold as is to her( 170,000 miles on it) She had problems with it a week later, and i agreed to pay half the service bill to fix it. Sent the car to a place i used at that time,( dont anymore) and to round the corners off, the work we paid to get done wasnt, but the bill was paid anyhow, not knowing the work wasnt completed correctly, and at all. Fast forward a year, the lady( who i thought was all fixed up and happy) continued to have problems and took the car to three different garages, who all stated the work she( and I) had paid for hadnt gotten done.The third place did the work. So she had the work completed, after finding all this out, and wrote me a threatening letter. I read it, called her, and paid the other half of the bill, made her happy. I asked her why didnt you call me way back when instead of dealing with this lingering problem. She said i will never go back to the shop you used, if they are like this, i wouldnt ever trust them again, i agreed wholeheartedly with her. She was so worried i would have the same shop look at it that she decided to handle it on her own.
[Re: B3422W5]
#1230202
05/09/12 02:38 PM
05/09/12 02:38 PM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
Sorry to see this type of situation...it sucks for everyone involved. I've been there before too.
[Re: Moparnut426]
#1230203
05/09/12 02:41 PM
05/09/12 02:41 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
No, I was never contacted about any of this this via phone or email etc... & this would be the first I have read about it, as I was emailed this link from another customer. I do not visit or read moparts anymore so I don't have any knowledge of past posts etc. Only things I am going to say about it is this: If Brian had contacted me when he first had issues, I may have helped him out... he chose not to. On the spring choice, yes I ran it further than .050" from Coil bind... alot of valve springs over the years have been ran further than .050" from CB on open & not immediately caused failures. When I put that motor together in the spring of 2008 that is the spring I chose. I felt it was better to have too much pressure than not enough on a roller that would get turned decent RPM. (low 8000's with a 3.79 crank) Today, we do try to run smaller diameter, lower IH springs that are run tighter to CB if possible on our race builds. Brian supplied the valves for those heads & they gave a very tall installed height, which limited valve spring choices greatly, generally to larger OD, larger CB springs. The smaller OD, high pressure, small wire PAC stuff available today was just entering the market 4 years ago, so to sit back today & look at what is available today VS: 4-5 years ago is apples to oranges. & lastly & this will be my last comments on the subject, but I felt was a pretty relevant one that I have not seen mentioned: Brian supplied the Crane Ultra Pro lifters that failed & if my memory serves me they were USED that he purchased off of ebay or a classified site. He was aware there was risk associated with them, who knows how many passes were on them or what type of engine they came out of (most likely a 410" GM sprint car?) & how much use was on them. To sit there & say that my valve spring choice is what lead to the early failure of the lifters can never be proven... it's speculative at best & especially so when the lifters were used to begin with with an unknown history. I have ran Comp triple springs on several motors over the years including ones that have came back through the shop for freshen etc & have not noticed any unusual valvetrain issues associated with them, even being ran .200" + from CB. That being said, every engine is different in how it will transfer harmonics etc... Sometimes you just "miss" the proper parts selection in the valvetrain.. alot of times this can be caught on the dyno, by watching the raw airflow data & how the motor works at high RPM @ various acceleration speeds... unfortunately that motor never got dynoed. Now... If I am wrong on the lifters being used, then I apologize, I build about 30-35 engines a year.... Spring 2008 to Spring 2012 means well over 100 have passed through my hands in that time & hard to remember every minute detail of all of them, but I do see on his invoice that we did not supply lifters, I know he supplied them & from my recollection they were used units. I am far from perfect, I make mistakes EVERY DAY (I think we all do to some extent) but I try my best... not communicating with your builder when you have issues is not the best way to try to resolve disputes etc. & coming onto a public forum & blasting my valve spring choices again after zero communication/discussion about any of this really tells a story in itself.
