Page 2 of 6 1 2 3 4 5 6
Re: Got our late 5.7 Hemi heads today! [Re: topbrent] #1229895
05/10/12 04:46 PM
05/10/12 04:46 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
get hold of kent ritter or chunker @ maincine for the new intaks
Re: Got our late 5.7 Hemi heads today! [Re: jg309] #1229896
05/10/12 07:03 PM
05/10/12 07:03 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Here is my own personal 5.7 eagles with a worked chamber on the left and a stock chamber on the right.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Got our late 5.7 Hemi heads today! [Re: AlexP] #1229897
05/10/12 08:54 PM
05/10/12 08:54 PM
SoCal
Brian Hafliger Online content OP
Brian Hafliger  Online Content OP
SoCal
Any power #'s with these heads?
I ran out of time to flow the other heads today so hopefully tomorrow I'll get to them.
Brian Hafliger
Re: Got our late 5.7 Hemi heads today! [Re: Brian Hafliger] #1229898
05/10/12 09:23 PM
05/10/12 09:23 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Cant wait to see what you and your Dad can do with the 3G HEMI stuff. I just seen your pictures and read the article on your 400 low deck build.
Alex your stuff is a work of art
Re: Got our late 5.7 Hemi heads today! [Re: Brian Hafliger] #1229899
05/10/12 11:42 PM
05/10/12 11:42 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
This post has got my attention!!!
Mike
Re: Got our late 5.7 Hemi heads today! [Re: Brian Hafliger] #1229900
05/11/12 09:13 AM
05/11/12 09:13 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Novawagonmaster over on LXforums is going to crack a 10.99 with an all forged 5.7 in a 4000lb Raceweight Challenger soon enough with the same heads. This is a mid port head (stage 2).
He is within a tenth of his goal.
Re: Got our late 5.7 Hemi heads today! [Re: AlexP] #1229901
05/11/12 11:36 AM
05/11/12 11:36 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Looking forward to reading this one!
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Got our late 5.7 Hemi heads today! [Re: AlexP] #1229902
05/11/12 08:45 PM
05/11/12 08:45 PM
houston texas
gremlinsteve Offline
houston texas
not any more, in fact i have sent a different cam out and there is another set of heads going on that motor. well see what we can get it to soon
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Got our late 5.7 Hemi heads today! [Re: gremlinsteve] #1229903
05/12/12 12:54 AM
05/12/12 12:54 AM
SoCal
SoCal
Sorry guys, long dyno day and no flow #'s on the hemi heads. I will have them tomorrow for sure. I'll have pics of the 6.1 and early 5.7 heads too.
Plan on sonic testing the block tomorrow if I have time.
Brian Hafliger
Re: Got our late 5.7 Hemi heads today! [Re: Brian Hafliger] #1229904
05/13/12 08:16 PM
05/13/12 08:16 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Re: Got our late 5.7 Hemi heads today! [Re: MattW] #1229905
05/13/12 08:28 PM
05/13/12 08:28 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
The 5.7 being a 3.92" bore and the 6.1 being a 4.05" bore, do you see any real drawbacks using a 5.7 block besides the obvious lower cubes? Was wondering if there would be an issue with airflow around valves, especially if stepping up to larger valves like in the 6.1 heads or the newer Apache 6.4 heads.
[image][/image]
Re: Got our late 5.7 Hemi heads today! [Re: sgcuda] #1229906
05/14/12 02:00 AM
05/14/12 02:00 AM
SoCal
SoCal
If you look at what Bischoff did with the 5.7 in the Engine Masters, I'd say it's not nearly as bad as if it were a wedge deal.
I know the EM stuff is very trick, but I have a hard time believing you couldn't make 700+HP with a high compression, large cam'd stroker 5.7.
I'm sure the larger bore engine will be easier to get more power out of, or easier to hit a certain HP #....I know I wouldn't mind having an aluminum 4.125 bore block to go in the duster!!
But we'll focus on the 5.7 blocks for cost and availability reasons.
Brian Hafliger
Re: Got our late 5.7 Hemi heads today! [Re: sgcuda] #1229907
05/14/12 08:56 AM
05/14/12 08:56 AM
NY usa
540challenger Offline
NY usa
There is a guy on the LX forum that has a stroker 5.7 that had ported eagle head running itnto the mid 11'w he switch to a set of ported 6.4 apache heads and went .2 quicker in the 1/4 mile. Keep in mind his block was bored .020 over. A member Matt on this board posted the apache head on a standard bore 5.7 and the intake valve looks close to the cylinder walls
Re: Got our late 5.7 Hemi heads today! [Re: 540challenger] #1229908
05/14/12 07:59 PM
05/14/12 07:59 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Re: Got our late 5.7 Hemi heads today! [Re: 540challenger] #1229909
05/14/12 08:56 PM
05/14/12 08:56 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Dave Kogan aka hemi Dave here on long island did one of those n/a hemi motors, car is over 4000 and it's in the 10's...no info on it other then my bud seeing it in person
Re: Got our late 5.7 Hemi heads today! [Re: fishy340] #1229910
05/15/12 06:06 AM
05/15/12 06:06 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I run a short filled 400 block in the street for several years, just a tad above the bottom of the freezeplugs. Had no oil cooler and no oil temp gauge. And also no problems with a 3.75" stroke. I also run a RB block filled close to the tops of the freeze plugs, 4.15" stroke, no oil cooler or gauge. In that case the oil got propably too hot in continuous driving on the freeway, the oil pressure dropped after about 1/2 hour of driving from 60-70 psi to 30-40 psi level. Swithcing to synthetics made the situation better, there was even some pressure at idle. I kind of figured that as long as the fill stays below the piston ring travel, there is zero problems, and as you raise the level, the more problems. Oil cooler is definitely a good idea, and should let you use even a realtively tall fill in a streeter.
Plynouth VIP '67 TT IC EFI
Re: Got our late 5.7 Hemi heads today! [Re: jyrki] #1229911
05/15/12 08:23 AM
05/15/12 08:23 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
Here are some pics my brother took yesterday showing the port sizes on the eagle heads vs the early 5.7 heads. Crazy the size jump on the eagle. I will start clean up on the eagles and hand port / polish soon. Is there roller rockers avail for these motors yet? The eagles have only 40k miles and the valve tips are beat up awfully bad from the stock rockers.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Got our late 5.7 Hemi heads today! [Re: StandOnIt] #1229912
05/15/12 08:25 AM
05/15/12 08:25 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
Exhaust side. 5.7 eagle head left. early 5.7 head right.
Re: Got our late 5.7 Hemi heads today! [Re: StandOnIt] #1229913
05/15/12 12:38 PM
05/15/12 12:38 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
good comparing pic,thats a huge diference!
as for rockers http://www.harlandsharp.com/hemi.htm
Re: Got our late 5.7 Hemi heads today! [Re: 1Fast340] #1229914
05/15/12 12:51 PM
05/15/12 12:51 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
what years are the early and late heads??
my 5.7 is 2004
