Re: Engine (Cam) Break-In...Thermostat or Not?
[Re: RUNCHARGER]
#1228348
05/07/12 02:41 AM
05/07/12 02:41 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Its liable to run hotter without the T state because there is nothing to restrict the flow through the rad giving it a chance to cool properly.. Put the stat in !
I am truckless..
[Re: MoparforLife]
#1228350
05/07/12 03:52 PM
05/07/12 03:52 PM
Posts: 1,607 Western Washington
Sixgun
Western Washington
I vote for using a good 180' stat like a stainless NAPA superstat and drilling at least one 1/8 inch hole between the rim and the stat "motor" for air bleed. Testing on the stove is an EXCELLENT idea (wish I thought of it) The stat gets the motor up to temp quick and stabilizes temp for break in, which the motor WANTS! All the stuff we have is designed to run at 180' for clearances, oiling, metallurgy etc.
[Re: bobs66440]
#1228352
05/07/12 06:52 PM
05/07/12 06:52 PM
Posts: 1,770 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I wish I used a NEW 'fail-safe' thermostat with the above mentioned 1/8" air purge holes on my new startup. What happened is that the thermostat either got stuck, or there was some air trapped underneath because with the rad pressure cap off (I kept it off to make sure coolant was circulating properly, etc, etc...may not have been the smartest thing to do in hindsight) all of a sudden I got a huge geiser shoot up!!! Nasty nasty...what a mess...not the sort of a thing you want to encounter during a fresh engine startup...certainly not after months and months of work to put the combo together, get it into the car, etc, etc...ahh...lessons learned!
[Re: DaytonaTurbo]
#1228354
05/08/12 12:09 AM
05/08/12 12:09 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
whether you have a thermostat in or not..
Just have the hose with a sprayer available to hose the radiator down if it starts to run hot..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1228357
05/08/12 07:40 PM
05/08/12 07:40 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
Thanks for the help guys. It all went very well. The cam break in went perfectly! It started right up after cranking a few times and immediately ran it up to 1800-2200rpm and kept it there, varying it up and down for about 30 minutes (that was a LONG 30 minutes!). I was shocked how smooth it ran immediately and didn't skip a beat the whole time. I set the total timing at about 34* and initial is 10-12*. I ran it with straight water and no thermostat. I also had a box fan blowing into the grill. The temp stayed very cool for about the first 15 minutes, then it slowly creeped up to 195, almost 200. At that point I misted the rad with a garden hose and that brought it right down. The oil pressure stayed at 50 cold and 45 hot. I let it cool, pulled all the spark plugs and they looked real good. Then changed the oil and filter, double checked everything and ran it a little more...idle, mid-range, blipping. It seems very responsive and sounds great out of the exhaust. The amazing thing is that there are NO leaks at all! Even the valve covers were dry! Amazing! Quote:
The hose trick worked well. I'll have to see how it runs on the first road test Friday. Hopefully it will stay cool.
