Bellhousing question? #1228059
05/06/12 06:41 PM
05/06/12 06:41 PM
Mi
mklott Offline OP
mklott  Offline OP
Mi
I picked up a BB bellhousing from a buddy the casting number is the specs below
 2892262    11" clutch A-833   1968 B-body C-body 383 440 4.80" IBR (cast dates include 9/5/67 10/20/67)  Cast Iron. My question is can I use this in a 70 challenger?
Mike
Re: Bellhousing question? [Re: mklott] #1228060
05/06/12 07:10 PM
05/06/12 07:10 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I want to say yes you can, but I am not sure is the Z bar dimension is the same between it and the correct 513 alum you car would have used . A friend , RIP , put a lakewood blowsheild in a 71 Challenger and had to trim the Z bar a little.
That bellhousing uses a 143 tooth flywheel.
Re: Bellhousing question? [Re: mklott] #1228061
05/07/12 10:09 AM
05/07/12 10:09 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Mike
Will work just fine. You need to use a 66-70B, E small block z-bar and adjuster rod to clear the larger bell.
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Bellhousing question? [Re: 64dodge572] #1228062
05/07/12 03:46 PM
05/07/12 03:46 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Unfamiliar with using the stock bell,but I will throw out that using a Lakewood 143 tooth bell was an utter Son of a Bear in an e- body.Right up against the floor tunnel, and you could not get the motor high enough off the mounts to remove the engine the time honored way, had to unbolt mounts from block and pull motor straight forward,
AMHIK
