Mopar Action article 9 1/4 #1227943
05/06/12 10:45 AM
05/06/12 10:45 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Does anyone have the June 2012 mag about the 9 1/4 buildup and if so what was said?
Any groung breaking info? Thanks Matt
Re: Mopar Action article 9 1/4 [Re: MattW] #1227944
05/06/12 11:19 AM
05/06/12 11:19 AM
Az
Crizila Offline
Crizila  Offline
Az
Looking for the same thing
Fastest 300
Re: Mopar Action article 9 1/4 [Re: Crizila] #1227945
05/06/12 11:34 AM
05/06/12 11:34 AM
mid-mich
turboplymouth Offline
mid-mich
They put some special c-clip Eliminator bearing in it which required a retube with special housing ends. Used a trutrac diff. Apparently you can use 8.75/Dana adjustable bearings with custom tubes also.
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj. 9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
Re: Mopar Action article 9 1/4 [Re: turboplymouth] #1227946
05/06/12 07:12 PM
05/06/12 07:12 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I was thinking of cutting the ends an using a sealed Bearing BR20 with the appropriate housing ends.
Wonder why the retube it.
Re: Mopar Action article 9 1/4 [Re: MattW] #1227947
05/07/12 10:43 AM
05/07/12 10:43 AM
Az
Crizila Offline
Crizila  Offline
Az
I've been running my 9 1/4 for about 5 years now with no problems ( mid 11 second car ). Heard all the "C" clip horror stories - and maybe some are true . Obviously thats a drawback to using that diff ( along with the fact that they don't make a spool for it ). Otherwise, it's a very strong diff and would easily handle a 10 second car IMO. Just seems to me that the cost to have it modified for bearing retained axles would be more than just switching to a Dana or a Ford 9"? I'm in the process of updating my drive shaft to use 1350 joints ( replacing the existing 7260 joints - which have also been trouble free for 5 years )and gotta make a diff decision.
Fastest 300
Re: Mopar Action article 9 1/4 [Re: Crizila] #1227948
05/07/12 11:22 AM
05/07/12 11:22 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I believe a spool is in the works.
Re: Mopar Action article 9 1/4 [Re: Montclaire] #1227949
05/07/12 11:31 AM
05/07/12 11:31 AM
Az
Crizila Offline
Crizila  Offline
Az
From who? Also don't think anyone is making a 9 1/4 diff yoke that will accept a 1350 U-joint ( just got a "no" reply from "Moser" ).
Fastest 300
Re: Mopar Action article 9 1/4 [Re: Crizila] #1227950
05/07/12 11:56 AM
05/07/12 11:56 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Sounds like you're dealing with the wrong company.
Forged steel 1350 U-bolt yoke kit $70
Custom 31 spline axles $385 pair assembled
Billet housing ends $70 pair
Crush sleeve eliminator kit $25
Please E-mail for more information doctordiff@gmail.com
Thanks,
Cass
Re: Mopar Action article 9 1/4 [Re: DoctorDiff] #1227951
05/07/12 12:45 PM
05/07/12 12:45 PM
Az
Crizila Offline
Crizila  Offline
Az
Thanks,
Cass
I guess so. E-mail heading your way.
Fastest 300
Re: Mopar Action article 9 1/4 [Re: DoctorDiff] #1227952
05/07/12 01:01 PM
05/07/12 01:01 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Thanks,
Cass
How bout a spool?
Re: Mopar Action article 9 1/4 [Re: goldmember] #1227953
05/07/12 01:35 PM
05/07/12 01:35 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Lots of 11 second 4,000 lb Dakota's running a stock 9 1/4 axle. even a handful of 10 second trucks with the factory axle. Moser shafts are only a few hundred bucks.
**Photobucket sucks**
Re: Mopar Action article 9 1/4 [Re: Crizila] #1227954
05/07/12 03:58 PM
05/07/12 03:58 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I like the 9 1/4 rear plenty out there but do not know if it is worth the hassle.
Seems like Cass has some good info.
Re: Mopar Action article 9 1/4 [Re: MattW] #1227955
05/07/12 07:17 PM
05/07/12 07:17 PM
Az
Crizila Offline
Crizila  Offline
Az
Just bought a 1350 u-joint size 9 1/4" pinion yoke from him to upgrade my driveshaft. I'm might by the upgraded "C" clip axles from him also. Wish they made a spool for it. I'm presently running a detroit locker in mine - and I don't like it much. Car does "odd" burnouts at times - like both sides aren't locked in. Car launches ok though ( both sides locked ). The locker is new and I had it checked out - it's in good working order. I also have a spicer clutch style sure grip that I had rebuilt extra tight. I might put that back in.
Fastest 300
Re: Mopar Action article 9 1/4 [Re: Crizila] #1227956
05/07/12 08:24 PM
05/07/12 08:24 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
A spool would really make this a good unit,very common and inexpensive. My friend ran one for years in his bracket Stude (SBM powered) with good results. Recently put a Dana in it but would have stayed with the 9 1/4 if a spool was available.
Re: Mopar Action article 9 1/4 [Re: goldmember] #1227957
05/07/12 08:36 PM
05/07/12 08:36 PM
Guitar Jones Offline
A spool and some pro gears would make that thing a pretty nice unit and cheaper than a 9" and lighter than a Dana.
Re: Mopar Action article 9 1/4 [Re: goldmember] #1227958
05/08/12 02:44 AM
05/08/12 02:44 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
No one carries an off-the-shelf 9.25" spool.
Supposedly, Summers Bros will make a custom spool for $500-$600, however.
Re: Mopar Action article 9 1/4 [Re: DoctorDiff] #1227959
05/08/12 09:16 AM
05/08/12 09:16 AM
gregsdart Offline
gregsdart  Offline
Or in a pinch if the posi unit is built like the one I had in a Dana years ago, (two halves, bolts together, friction plates) you can figure out just how thick an extra shim it takes to in effect, lock it up. In the case of the Dana, it took one cut up 3lb coffee can lid!
Re: Mopar Action article 9 1/4 [Re: gregsdart] #1227960
05/08/12 10:01 AM
05/08/12 10:01 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I ran one weleded in a 4000 lb truck for years, It ran 11.50's with a big block on a 150 shot. Still have it sitting out back!
67' charger 499 RB 10.57 at 127
Re: Mopar Action article 9 1/4 [Re: gregsdart] #1227961
05/08/12 12:49 PM
05/08/12 12:49 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
why not just weld the spiders together?
Re: Mopar Action article 9 1/4 [Re: 70Cuda383] #1227962
05/08/12 01:14 PM
05/08/12 01:14 PM
Az
Crizila Offline
Crizila  Offline
Az
That has crossed my mind. Just a little "wossed out" to try it.
Fastest 300
