MODERN MAGNUM INTO DART #1226979
05/03/12 10:19 PM
05/03/12 10:19 PM
NEW JERSEY
TLEARN 23 Offline OP
NEW JERSEY
HEY, MY LA ENGINE WENT SOUTH. I WOULD LIKE TO PUT IN A 2000 5.9 MAGNUM USED ENGINE IN MY 71 DART. I SEE FLEX PLATES OFFERED UP TO 1999.
TO BOLT TO MY 727 WITH A NEUTRALLY BALANCED CONVERTOR. I KNOW THE FRONT OF THE ENGINE INFO UP TO 1999. IS THE 2000 YEAR MOTOR A DIFFERENT ANIMAL? WILL THIS ENGINE BOLT UP?
Re: MODERN MAGNUM INTO DART [Re: TLEARN 23] #1226980
05/03/12 10:30 PM
05/03/12 10:30 PM
Andrewh Offline
Andrewh  Offline
I used the b&m flex plate for my 65 coronet with 727 and a 2000 5.9 magnum from a durango.
I believe they are the same 98 and up till they stopped making them.
earlier ones used a different flex plate.
Re: MODERN MAGNUM INTO DART [Re: Andrewh] #1226981
05/03/12 10:34 PM
05/03/12 10:34 PM
NEW JERSEY
NEW JERSEY
THANKS FOR REPLYING. DID YOUR CAR HAVE A WEIGHTED OR BALANCE CONVERTOR
Re: MODERN MAGNUM INTO DART [Re: TLEARN 23] #1226982
05/04/12 08:24 AM
05/04/12 08:24 AM
Andrewh Offline
Andrewh  Offline
neutral converter.
was a 318 car, so the flex plate did the balancing.
Re: MODERN MAGNUM INTO DART [Re: Andrewh] #1226983
05/04/12 09:23 AM
05/04/12 09:23 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Late 90s+ teh Mags got a 1-piece damper/crank pulley, so you'll need to swap to an earlier 5.9 damper if you want to swap to V-belts. Timing cover and water pump and pulleys must be swapped as a system, don't mix-match parts.
There are a lot of subtle tricks on swapping Mags, and 5.9s are a little trickier than 5.2s. nothing that can't be overcome, you just need to know what parts to buy.
Look at Dippy.org, I've posted a bunch of Mag swap details over there (and here too, but not as much).
Re: MODERN MAGNUM INTO DART [Re: Fury Fan] #1226984
05/04/12 12:08 PM
05/04/12 12:08 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
The support systems are where you are going to spend some time. Cooling and fuel.
A 71 should have the same pump inlet as the magnum, but the new motor runs hotter and will probably require a bigger/better radiator. You will probably need a shroud to go along with the magnum fan.
Re: MODERN MAGNUM INTO DART [Re: TLEARN 23] #1226985
05/04/12 07:39 PM
05/04/12 07:39 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Somewhere around 99 they moved the weight from the converter to the drive plate (and changed the drive plate to a symmetrical bolt pattern; easy to oval out the one hole). Use the weighted plate and any zero-bal converter.
Might I suggest using the whole donor truck's SMPI system? Awesome swap done that way.
Rick
Re: MODERN MAGNUM INTO DART [Re: Rick_Ehrenberg] #1226986
05/04/12 08:37 PM
05/04/12 08:37 PM
NEW JERSEY
NEW JERSEY
thanks rick,
do you know about the balancer and pulley situation? I am aware that the timing cover can be swapped out so to utilize my accesories. is the magnum balancer an issue to use with the la timing cover? Also
the la block has its dipstick in the block. where is the magnum dip tube?
thanks
Re: MODERN MAGNUM INTO DART [Re: TLEARN 23] #1226987
05/05/12 05:35 PM
05/05/12 05:35 PM
mass,usa
sickhemi Offline
sickhemi  Offline
mass,usa
don't forget you will have to run a electric fuel pump unless you bolt the adapter on the front of the cam to bolt the fuel pump eccentric on!
1968 gts 355 r3 six speed efi with irs in progress and 1969 convt 440 stage 6 efi 5spd dana
Re: MODERN MAGNUM INTO DART [Re: sickhemi] #1226988
05/07/12 09:34 AM
05/07/12 09:34 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
If you do swap to the factory EFI, there's a sensor that reads off the flexplate (bolts to the pass-side rear of cyl head). You'd need the sensor and flexplate setup and also to cut a notch into the trans bellhousing for the sensor to read thru. Make sure to round the corners/edges of the slot to prevent cracking.
Re: MODERN MAGNUM INTO DART [Re: TLEARN 23] #1226989
05/07/12 10:25 AM
05/07/12 10:25 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
good friend of mine is finishing up a complete 5.9 efi and A500 OD trans isntall now. all in a 1972 Dart.
pm me and I'll get you his email address if you want
