MODERN MAGNUM INTO DART
#1226979
05/03/12 10:19 PM
05/03/12 10:19 PM
Posts: 7 NEW JERSEY
TLEARN 23
NEW JERSEY
HEY, MY LA ENGINE WENT SOUTH. I WOULD LIKE TO PUT IN A 2000 5.9 MAGNUM USED ENGINE IN MY 71 DART. I SEE FLEX PLATES OFFERED UP TO 1999. TO BOLT TO MY 727 WITH A NEUTRALLY BALANCED CONVERTOR. I KNOW THE FRONT OF THE ENGINE INFO UP TO 1999. IS THE 2000 YEAR MOTOR A DIFFERENT ANIMAL? WILL THIS ENGINE BOLT UP?
Re: MODERN MAGNUM INTO DART
[Re: Fury Fan]
#1226984
05/04/12 12:08 PM
05/04/12 12:08 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
The support systems are where you are going to spend some time. Cooling and fuel. A 71 should have the same pump inlet as the magnum, but the new motor runs hotter and will probably require a bigger/better radiator. You will probably need a shroud to go along with the magnum fan.
[Re: TLEARN 23]
#1226987
05/05/12 05:35 PM
05/05/12 05:35 PM
Posts: 210 mass,usa
sickhemi
mass,usa
don't forget you will have to run a electric fuel pump unless you bolt the adapter on the front of the cam to bolt the fuel pump eccentric on!
1968 gts 355 r3 six speed efi with irs in progress and 1969 convt 440 stage 6 efi 5spd dana
